HD8 SU Carburetor removal
pkmh
Hello Community!
Finally we have nice weather here today, so I decided to become more familiar with my HD8 SU Carburetors (proceeding with caution, mind you) by attempting to remove them for rebuilding purposes and while at it, gain easier access in repairing or replacing both clutch and brake master cylinders below it.
I almost was completely successful in removing all securing carburetor rear body mounting bolts to the intake (except one, of course), the one positioned below and forward on the rear SU. I experimented in removing the slip linkage between the two SU's so as to remove one carburetor (front) first, but there must be something else I am required to do in order to successfully remove the entire linkage, maybe?
I was hopeful in removing the sixth bolt so I can remove the SU's in its entirety. Does that sound like the right way to go?
If so, should I then be looking for a special tool for that hard to get to place or is there an easier way (ie.- understanding removing slip linkage)? I have no material so far on dismantling but if I could get past this hurdle, I should be in good shape to proceed.
And thoughts on this?
Thanks,
Paul
Keoke
H Paul, I have always removed those bottom bolts using a stubby standard closed end wrench . Standing at the front of the car I can usually reach under the carbs with my right arm extended and get to those buggers.Need a long arm and patience. If patience runs short CUSS.---Fwiw--Keoke-- :laugh:
Ditto from me, and my arms aren't particularly long.
You can tell a Healey owner by the scars on his/her forearms.
pkmh
pkmh
Well thanks for that advice. Sounds like I was so close to success, then. It was good practice anyway, to start removing required pieces and more importantly, putting all pieces back, which is what I did after not going any further.
That and plenty of record photos as I go.
Thanks!
Paul
Keoke
It ain't no hassle You just gotta be full grown up. You know like 6'4" tall or more--Keoke- :laugh:
pkmh
pkmh
I like the 6'-4" approach, but because of my height, maybe I'll do like what one past talk show host used to do...You know, the one who liked jump over people to get the question asked. In my case, I'll jump into the engine compartment with my mighty little wrench.
I'm getting ready!
Paul
bob hughes
It may be a bugger getting the nuts off but just you wait, you gotta put them babies back on again :yesnod:
Of course us BJ7 owners don't have that trouble, :banana: 'cause we only have little carbs, though one or two of the bottom nuts can be a tad tricky :nopity:
Keoke
:savewave:
NAA!!! Reinstallation is simply the reverse of removal.-- Keoke--- :driving:
pkmh
pkmh
Well, I got good practice for I was able to put all the other nuts back on and that includes the washers and lock washers that went with each (taking them off underneath was pretty tricky, especially the washers for me).
(But come to think of it, a little magnet would do the trick).
Johnny
Sorry about the late post Paul hope you haven't removed them already. There is a special tool for that job. First you buy a cheap 1/2" wrench then grind down the edges until they'll fit. I also cut the wrench in half to make it shorter. By standing on the drivers side I'm always able to reach under the carbs using my left hand to get that nut off. It might make it easier to remove the choke cables and the overflow tubing first.
Good luck and let us know how you did.
pkmh
pkmh
Thanks for the good idea about grinding down a 1/2" wrench! I will consider that approach. Somehow, the 7 out of 8 nuts proved not to be terribly challenging, happy to say (the first go around, anyway).
I have been using a simple 1/2" wrench for all the nuts except that special one I couldn't get to. But I am going to try to grow some arms first and dive into the engine area and see if I get lucky that way. I know my wrench will work once I get into the right position. Putting it back on...well, we shall see.
Er, better give me a few days to get ready before letting you know how things turn out.
But thanks for that tip!!
Paul
Sometimes a 'magnet on a stick" helps get the washer back on. Also you can use tape to hold the nut and washer to a wrench to get it in place. I use a set of "stubby" ratchet wrenches. I have also shortened the air cleaner studs between the two carbs cause when you tighten the out-ward nuts you can never get the inner nuts on. You will learn your own tricks. one guy i know uses tape on his finger to get the nuts in place. It does work.
pkmh
pkmh
Actually, Tahoe, I felt putting the washers on the carburetor body were easy, compared to trying to take them off and that's because the washers tend to get stuck on the bolt screw threads (and maybe because the screwthreads are on a slight incline angle, making removing a bit of a challenge with just using one's fingers).
Thank you for that advice!
Now if only I had longer fingernails.
Paul
W
Wings
Oh yes R &R on HD8's
i cant do it.. plain and simple always end up scratched & bleeding
I call my wife (smaller hands, longer fingers & skinnier forearm)
she is a good sport/ claims credit on the rebuild
oh longer fingernails also
Keoke
WOT!!!------------- :shocked:
---How much did her manicure cost you????------Keoke-- :laugh:
BoyRacer Wanted Orphan HD8 carburetor for parts Austin Healey Classifieds 6
AUSMHLY HD8 Carburetor rebuild help Austin Healey 46
D S.U. HD8 Carburetor Drawing Austin Healey 6
M New Member with an HD8 Carb Question Austin Healey 1
Zitch For Sale HD8 carbs and 2" intake Austin Healey Classifieds 9
G HD8 Carb Leak Austin Healey 7
G HD8 Carb Banjo Bolts Austin Healey 2
G HD8 Idle Adjust Screw Austin Healey 10
O HD8 carb on Healey 3000 Austin Healey 62
Patrick67BJ8 HD8 Carb Repair Austin Healey 15
ArchieMcAllister Wanted Rebuildable set of HD8's Austin Healey Classifieds 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY HD8 damper with Brass or plastic cap? Austin Healey 8
J Wanted HD8 SU carb set Austin Healey Classifieds 6
wangdango Colortune for HD8 Carbs? Austin Healey 55
B mysterious leaking of SU HD8 Jaguar 9
J HD8 carbs, what is minimum fuel rate to keep bowls full, car is dying. Austin Healey 18
vette Adjusting HD8 Carbs Austin Healey 21
S Float valves for HD8 - Grose Type Austin Healey 20
steveg HD8 high idle aggravation Austin Healey 11
AUSMHLY HD8 pin & spring assembly Austin Healey 6
Jeepster HD8 carb float bowls Austin Healey 7
Xte Needle BJ8 position in HD8 carb ? Austin Healey 4
tinman58 TR3 with a Jag HD8 carb SuperCharged Jaguar 10
tinman58 HD8 S/C carb ? Triumph 9
C Hd8 su fuel lines Austin Healey 2
D Rebuilding the SU HD8 carbs Austin Healey 24
D HD8'S Austin Healey 3
D HD8'S Austin Healey 4
W Rebuild recommendations for HD8 Austin Healey 5
AH_3000 Guys...What is this on a HD8??? Austin Healey 8
S Float Level for HD8, BJ8 carbs Austin Healey 9
macey75 Set of 2 new SU HD8 carburetors, Healey 3000 mk3 Austin Healey 0
D HD8 Carb. Value Austin Healey 7
D K&N filters for HD8 carbs Austin Healey 26
J HD8 carb float adjustment. Austin Healey 1
B HD8 SU carb suction chamber. Jaguar 0
F HD8 Carb Set Up and Adjustment Austin Healey 2
BOBBYR HD8 Carbs Austin Healey 2
AUSMHLY SU HD8 carb set Austin Healey 6
Ed_K What are the correct damper p/ns for HD8 carbs? Austin Healey 2
M Air cleaner for HD8 on BJ8 Austin Healey 5
R Help - Need SU HD8 Part [Throttle Lever] *DELETED* *DELETED* Jaguar 1
R Help! - Need SU HD8 Part [Throttle Lever] Austin Healey 5
Lin HD8 carb dashpot height Austin Healey 1
David_K Question about SU HD8 carb gasket kits Austin Healey 5
A BJ8 SU HD8 carbs for sale Austin Healey 0
J HD8 shaft bushing & king pins. Austin Healey 6
R Setting up HD8 carburetors Austin Healey 6
Lin HD8 carbs Austin Healey 2
