Post-War Other Hattie the Herald, again.
Trevor Triumph
We pulled the engine and replaced the clutch, fly wheel, throw out bearing. Still when I push the clutch pedal nothing seems to move. The Spitfires have sme movement in the slave cylinder mount. I have not bled the system again. I did not disconnect the slave a from the master cylinder, and both cylinders are new from the store. I wonder what I missed?
T.T.
TomMull
Did you get fluid flow at the slave when you bled it? Did you use a vacuum bleeder? If not, try loosening the nut on the master cylinder while someone depresses the clutch. repeat until you get fluid there. You could also try loosening the bleed screw on the slave with a pan underneath and wait for a drip from gravity. Then bleed normally, if necessary.
Tom
T General Tech Hattie the Herald, again and again. Triumph 6
T Post-War Other Hattie the Herald, again. Triumph 5
T Post-War Other Hattie the Herald, again. Triumph 3
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
P Spitfire Going up-Engine with my Herald Triumph 6
P Post-War Other Triumph Herald Engine ID Triumph 2
TomMull Wanted Herald Hood Frame Triumph Classifieds 9
7 For Sale Stainless trim for Herald Convertible top. Triumph Classifieds 0
B 1965 herald convertible Triumph Classifieds 1
TomMull Free Triumph Herald Headboard Triumph Classifieds 0
M For Sale 1965 Herald Convertible 1200 Triumph Classifieds 1
M For Sale 1965 Herald Convertible 1200 Triumph Classifieds 0
AngliaGT General TR Triumph Herald Being Parted Out [craigslist] Triumph 0
TomMull Wanted Triumph Herald Hood Finishers Triumph Classifieds 3
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
TomMull Post-War Other Herald [or Spitfire] fuel pipe Triumph 5
S For Sale Triumph Herald 1200 saloon and coupe spare parts catalog Triumph Classifieds 0
LarryK General TR 1962 Herald Convertible Triumph 10
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
J TR4/4A Fuel Injected Herald Triumph 1
T Wanted Herald frame Triumph Classifieds 2
bash Post-War Other Herald for racing Triumph 5
H Wanted Herald Parts Triumph Classifieds 15
H Wanted Herald headlamp Chrome Rim retaining ring Triumph Classifieds 0
H Wanted Braket that connects the boot lid to the boot lid stay strut on a Herald. Triumph Classifieds 0
P Triumph Herald Spotted 0
H Post-War Other Herald rear suspension lower block installation Triumph 3
T Post-War Other The Herald front vent windows Triumph 5
T Post-War Other The Herald front vent woindows Triumph 0
TomMull Post-War Other Herald 13/60: I didn't get the battery tray quite right Triumph 4
TomMull TR2/3/3A Herald has a friend, TS58023 Triumph 5
TomMull Post-War Other Herald: Holy Moly! [Why it took me so long to make the accelerator bracket] Triumph 2
TomMull Post-War Other Herald carpets and throttle issues Triumph 4
M Post-War Other herald 13/60 light switch Triumph 2
TomMull Post-War Other Herald Carpets, issues, and minutia Triumph 4
TomMull Post-War Other Herald seat track mount Triumph 5
T General TR Spitfire/ Herald Suspension & Steering Triumph 13
T Post-War Other Herald flywheel Triumph 3
TomMull Post-War Other Herald shift lever Triumph 3
AN5Sprite Post-War Other What's a '64 Herald Worth? Triumph 6
TomMull Post-War Other Herald starter Triumph 7
T Post-War Other Herald heater Triumph 2
PatGalvin General TR 64 Herald on Craigs List Triumph 5
7 Post-War Other Sold the Herald - surprising amount of interest Triumph 3
aeronca65t Post-War Other super low mileage Herald Triumph 2
DNK Post-War Other You "Herald Heads" Triumph 1
John_Mc Post-War Other $600 Herald Triumph 4
Mickey Richaud Post-War Other Anyone Looking For a Herald? Triumph 1
H Post-War Other Spit 1500 Engine in a Herald 1200 Triumph 1
