General TR Spitfire/ Herald Suspension & Steering
Trevor Triumph
The Herald is on the road, sort of. I can't have the front end aligned because the balls joints and tie rod ends need to be replaced. The tie rod ends are the same part number, for the Herald and the Spitfire. The upper ball joint have the same part number. The problem is the trunnions are different parts numbers but attach to the same vertical link. The question: "Can I use the Spitfire parts on the Herald?" TRF is having a sale so I could rebuild the front end and steering at reduced price. And have the parts a little quicker than ordering from the UK.
T. T.
T
Trevor Triumph
The Triumph part number for the vertical link is 205483/ 4 for both cars. The upper ball joint is 122509 for both cars. The trunnion assembly numbers; Herald 122130 and Spitfire 32064.
TR3driver
Great Pumpkin - R.I.P
I can't find any listing for either of those numbers. But the folks at Canley usually know their stuff, and they say 140919/20 will fit.
Grantura_MKI
The first step is to strip the uprights and have them magnafluxed. These become brittle and deteriorate from lack of lubrication. If the trunnions are shot, then I bet the uprights are the same.
best,
d.
LarryK
Usually the bronze trunnions go first.
LarryK
My biggest problem on the front was the lower wishbones would oval the shock mount holes from jumping railroad tracks. I only had to replace trunnions once in each of my 2 Spits and a GT6. But, then mine were well oiled, not greased, as per specs.
Grantura_MKI
You are spot on with the oiling. Have seen too many with grease in the trunnions which is a failure waiting to happen and the cause of poor threads, etc.
LarryK
I just used motor oil 30W or 40W non-detergent. Pushed thru zert.
LarryK
90 wt sounds better. I used a lighter oil, but I oiled monthly.
TomMull Post-War Other Herald [or Spitfire] fuel pipe Triumph 5
ArcticOne Post-War Other Herald and Spitfire at Auction Triumph 5
Michael Oritt Post-War Other Triumph Herald/Spitfire steering rack Triumph 7
TR_Jim Post-War Other Safety Tip for Spitfire, GT6 and Herald Owners Triumph 9
T Post-War Other Herald to spitfire conversion parts Triumph 2
bcliff Post-War Other Need Spitfire/Herald info Triumph 2
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
