General Tech Hattie the Herald, again and again.
Trevor Triumph
The Herald is coming along. We trailered the car to the Las Cruces, NM show a few weeks ago. We were pleased to be recognized with a nice photo and frame.
The problem: the gas gauge shows "full" when the ignition is on and when the car is running. I disconnected the wires at the tank and the gauge still shows full. Could this be a bad ground at the gauge, an bad voltage stabilizer, or a faulty gauge?
We can take the car on longer trips, now that the leak in the caliper is fixed, but not knowing the fuel level is not safe, either.
T.T.
number6
I suspect you have a wiring issue. Look on the Spitfire and GT6 magazine site. Gives a good explanation of the
most likely faults and how to fix them. Probably a short.
Andrew Mace
I agree with some wiring "issue" upstream of the sender; something is providing "full power" to the gauge when the ignition is on? You likely do NOT have a voltage stabiliser in your gauge circuit (if you did, the fuel gauge needle would be red instead of white), so I'm pretty sure that can't be the problem. ;)
T
Trevor Triumph
Thanks for you help. I will pull the speedometer and such out of the dash and trace wires. I thought the car had a voltage stabilizer- the current going to the temp gauge is ten volts.
T.T.
TomMull
You'll see the voltage stabilizer screwed to the back of the speedometer if it has one.
Tom
Andrew Mace
T.T.
Interesting! I thought I remembered your car being too early a Herald for the stabilizer circuit? What does the temp gauge look like: does it have a "solid" white arch between C and H or is it a "broken line"?
T
Trevor Triumph
I'm not sure the temp gauge is original to the car. It is a solid white line. Rimmer Bros. said the numbers on the car are consistent with a 1965 export car. At this point Herald work has stopped to prepare the Spitfire engine to go to the machine shop- low oil pressure, bearing noise on start-up, and black stuff on the rear valance.
T Post-War Other Hattie the Herald, again. Triumph 3
T Post-War Other Hattie the Herald, again. Triumph 5
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
P Spitfire Going up-Engine with my Herald Triumph 6
P Post-War Other Triumph Herald Engine ID Triumph 2
TomMull Wanted Herald Hood Frame Triumph Classifieds 9
7 For Sale Stainless trim for Herald Convertible top. Triumph Classifieds 0
B 1965 herald convertible Triumph Classifieds 1
TomMull Free Triumph Herald Headboard Triumph Classifieds 0
M For Sale 1965 Herald Convertible 1200 Triumph Classifieds 1
M For Sale 1965 Herald Convertible 1200 Triumph Classifieds 0
AngliaGT General TR Triumph Herald Being Parted Out [craigslist] Triumph 0
TomMull Wanted Triumph Herald Hood Finishers Triumph Classifieds 3
TomMull Post-War Other HERALD Simple Task turns into another project. Triumph 11
TomMull Post-War Other Herald [or Spitfire] fuel pipe Triumph 5
S For Sale Triumph Herald 1200 saloon and coupe spare parts catalog Triumph Classifieds 0
LarryK General TR 1962 Herald Convertible Triumph 10
dklawson Spitfire Bleeding Herald Brakes [similar to Spit] Triumph 9
J TR4/4A Fuel Injected Herald Triumph 1
T Wanted Herald frame Triumph Classifieds 2
bash Post-War Other Herald for racing Triumph 5
H Wanted Herald Parts Triumph Classifieds 15
H Wanted Herald headlamp Chrome Rim retaining ring Triumph Classifieds 0
H Wanted Braket that connects the boot lid to the boot lid stay strut on a Herald. Triumph Classifieds 0
P Triumph Herald Spotted 0
H Post-War Other Herald rear suspension lower block installation Triumph 3
T Post-War Other The Herald front vent windows Triumph 5
T Post-War Other The Herald front vent woindows Triumph 0
TomMull Post-War Other Herald 13/60: I didn't get the battery tray quite right Triumph 4
TomMull TR2/3/3A Herald has a friend, TS58023 Triumph 5
TomMull Post-War Other Herald: Holy Moly! [Why it took me so long to make the accelerator bracket] Triumph 2
TomMull Post-War Other Herald carpets and throttle issues Triumph 4
M Post-War Other herald 13/60 light switch Triumph 2
TomMull Post-War Other Herald Carpets, issues, and minutia Triumph 4
TomMull Post-War Other Herald seat track mount Triumph 5
T General TR Spitfire/ Herald Suspension & Steering Triumph 13
T Post-War Other Herald flywheel Triumph 3
TomMull Post-War Other Herald shift lever Triumph 3
AN5Sprite Post-War Other What's a '64 Herald Worth? Triumph 6
TomMull Post-War Other Herald starter Triumph 7
T Post-War Other Herald heater Triumph 2
PatGalvin General TR 64 Herald on Craigs List Triumph 5
7 Post-War Other Sold the Herald - surprising amount of interest Triumph 3
aeronca65t Post-War Other super low mileage Herald Triumph 2
DNK Post-War Other You "Herald Heads" Triumph 1
John_Mc Post-War Other $600 Herald Triumph 4
Mickey Richaud Post-War Other Anyone Looking For a Herald? Triumph 1
H Post-War Other Spit 1500 Engine in a Herald 1200 Triumph 1
