    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
Half round tube or D tube source ??
Jerry
Group,
I will need to make a top frame for a car I am working on. Too old and not enough of them around to be able to purchase one made up. Does anyone know a source in the USA for D tubing, or half round tubing? I have been searching the internet and have not found much beyond a supplier in China.
thanks
Jerry
J
Jerry
could be, I had found their web site but without a picture, I was unsure how to use the measurements. My Morris 8 has bows that are about 1 inch wide and half inch high, hollow.
K Half-shaft wear? Spridgets 3
Got_All_4 TR5/TR250 Only half of the tack is lit Triumph 14
F TR2/3/3A back half to chassis questions Triumph 105
M TR2/3/3A Speedy Sleeve Repair Sleeves for Rear Axle Pinion and Half Shafts Triumph 1
Jim_Gruber PS Steering Rack Lower Bracket Needed - Some DA over torqued and snapped it in half Spridgets 9
B BJ8 Half-Shaft Oil Seal Austin Healey 5
SD Bugeye Half capacity of the fuel tank Spridgets 10
tahoe healey half car cover Austin Healey 3
D Front suspension half moon cotters Austin Healey 6
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
Jim_Gruber Looking for back half of PS Floorpan for my BE Spridgets 6
S TR2/3/3A Well onto the second half Triumph 2
Boggsy64 MGB Half shaft question MG 2
H brake calliper half seal size Austin Healey 4
Bremer TR2/3/3A TR3 half doors Triumph 11
G Half shaft removal Triumph 3
Jim_Gruber Progress - Suspension half done yeah! Spridgets 2
Brian_James Wire wheel half shafts and bare 1275 block Houston Spridgets 1
PatGalvin TR2/3/3A Rear Half of TR3A Tub for Parts or Scrap??? Triumph 9
hondo402000 new CV half shafts Triumph 49
KVH TR4/4A TR4A Allowable Half Axle Play Triumph 0
ScottTR6 Half shaft replacement Spridgets 7
B TR6 TR-6 U-Joints/Half-shafts Triumph 13
T Half way? Triumph 189
tweety Changing a half axle Spridgets 1
S I hope my car looks HALF as good as this one...... Jaguar 6
jvandyke weird half top, soft targa? Spridgets 10
mrv8q TR6 TR6 half-shaft removal Triumph 15
B 3.9 Diff/half shaft/spline question. MG 2
J Spitfire Spitfire Half shafts Triumph 3
F Removing Axle Half Shaft [Tube Type] MG 4
hondo402000 TR6 TR6 dropped the Diff out and half shaft question Triumph 2
beaulieu fixing a cut in half Temperature capillary gauge Restoration & Tools 13
G Cut body in half? Triumph 20
JPSmit Help #3 - diff + half shafts now Spridgets 2
G Ninety nine and a half just won't do.... Triumph 15
drooartz Tips for brake drum/diff/half shaft removal Spridgets 14
G Flag at Half Mast for a While at AAW Triumph 6
Z Axle half shafts Austin Healey 0
GB1 Half Shafts - Hardened Spridgets 18
A Introduction [half a day late] Triumph 6
bighly Dream Machines in Half Moon Bay CA Austin Healey 1
martyc Help! Stupid Half-Tonneau Question MG 3
J TR6 TR6 - half top/bikini top? Triumph 1
D Stag Stag half shaft removal Triumph 6
TypeRboy Half way there.. Lotus 1
Basil Half-axel U-joints - HELP! Jaguar 6
A TR2/3/3A Those round fuel line clips Triumph 2
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
B Wanted WTB: TR3 Late model-"Round bottom" door Triumph Classifieds 4
