Grease Guns and Triumphs
JohnnyMead
The recent posts about TR3 rear axles reminded me of a question: when the TR3 manual says to give a grease fitting "5 strokes" is that measuring the quantity that comes out of a small grease gun like what was packed in the tool kit, or the standard size gun we are used to? And what's the difference in output?
Just wondering..
John
tomgt6
Good question, I would guess that it comes down to when you start to see the old grease coming out of the joint.
TR3driver
Great Pumpkin - R.I.P
Problem is, with the TR3 rear wheel bearings, you won't see the old grease come out unless your head happens to be inside the axle.
Probably they meant the gun packed with the kit. I've never tried to measure the difference, but I've read that there is a sizeable difference between guns; as much as 3:1. Still, I don't feel it's all that critical (note that the TR3 appendix to the workshop manual says 6 shots every 6000 miles, rather than the 5 shots mentioned elsewhere). Plus, modern greases are much better than what was commonly used 50 years ago, so the need to flush out old grease is less, IMO.
I've been using 4-5 strokes of whatever grease gun I'm using, approximately once a year (which for me is 10-15k miles); and it seems to work well. TS39781LO still has the same bearings & seals that it did when I got it some 25 years ago, and they were still working fine when it got wrecked. I may even move that axle into TS13571L, as it seems to have some problems.
Deleted member 8987
IF you do it on a schedule as-directed, most likely the toolkit gun.
However, if you do it when you finally remember, probably a bigger one.
One criteria I have always used on older vehicles (Willys, DumbCooks, Jags, etc) is how easy it is to find, then clean, the zerk.
If you have to look and scrape and clean to find it, use the big gun.
If it is fresh and clean, the smaller one.
(Like on my particular LBC, I don't think is 93,000 miles it had EVER been done!)
But, hey, that's only based upon what, 43 years of doing it?
So, probably doesn't count, eh?
Twosheds
I think I have it:
Studebakers?
bash Grease Guns Restoration & Tools 8
L Red Rubber Brake Grease Austin Healey 2
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
drooartz What am I seeing - oil/grease on wheel Spridgets 20
Hangtown Healey King Pin Bushings Grease Groove Austin Healey 8
K TR2/3/3A Girling red grease that used to come with brake cylinder rebuild kits? Triumph 7
K TR2/3/3A The grease gun brake caliper piston removal trick..... Triumph 6
S TR2/3/3A Putting dish soap in the radiator to remove grease Triumph 10
M TR2/3/3A Rear Axle Bearing Grease Triumph 5
Got_All_4 TR6 drill and tap for a grease fitting tr6 rear hub assembly Triumph 4
T TR2/3/3A Steering box oils - grease ? Triumph 20
Jayplum TR2/3/3A Grease cap Triumph 25
K For Sale Original Grease gun and jack....complete your TR3 collection. Triumph Classifieds 0
AUSMHLY Grease type for zerk fittings Austin Healey 7
warwick-steve Missing grease cap in front hub Austin Healey 8
warwick-steve Front hub bearing grease repacking Austin Healey 28
S Grease Gun Recommendation? Spridgets 7
steveg Recycling grease question Austin Healey 11
R grease for windshield wiper motor- BJ7 Austin Healey 4
D TR2/3/3A grease nipple/zerk Triumph 6
C TR2/3/3A Grease Zerks Triumph 7
S TR4/4A how ro grease steering box? Triumph 4
C General Tech Grease and Grease Gun recommendations Triumph 12
Martinld123 Grease Retaining Cup Not Tight Fit Austin Healey 2
CJD TR2/3/3A Grease Gun Color Triumph 9
N Lockheed brake assembly grease??? Spridgets 2
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
Popeye TR4/4A TR4A front brake caliper rebuild - grease on rubber seals? Triumph 5
P TR6 Grease job Triumph 6
Popeye TR4/4A Stub axle - grease or no grease? Triumph 4
T TR4/4A Front hub grease cap sizing - anyone had a cross reference part # for a FLAPS? Triumph 2
M Oil Gun vs Grease Gun Spridgets 21
tahoe healey dielectric grease Austin Healey 13
S How much grease for the drive [prop] shaft plunger Austin Healey 3
T TR2/3/3A Windshield Wiper Motor Grease Triumph 4
S Plugged Grease Zerks Spridgets 7
S Will copper grease work for squeeling brakes? Austin Healey 3
charleyf TR2/3/3A Rear axle grease Triumph 0
K TR2/3/3A Greasing the idler arm grease zirk??? Triumph 3
R TR2/3/3A Grease fitting list Triumph 5
simon1966 Current day grease choices? Austin Healey 3
RJS TR4/4A Grease for IRS Axle Shaft Splines Triumph 5
RJS General TR U-Joint Grease fitting interferes Triumph 4
S Correct way to remove grease retaining cup from front hub? Austin Healey 7
AUSMHLY Distributor grease Austin Healey 2
K TR2/3/3A Front wheel bearing grease seal with felt packing? Triumph 4
K TR2/3/3A Trunnion oil/grease again? Triumph 1
brohawk TR6 Grease on rear hubs Triumph 8
S TR2/3/3A grease in tr3 D2 wiper motor Triumph 2
D Grease nipples to lube the back of the rear spring, BT7 Austin Healey 7
