Good Quality Bias Ply Tires
LuckyLuke
After a bad experience with the 15 X 6.40 Bias ply tires made by Excelsior I’m now looking for a good quality bias ply tire of a different brand. My goal is to find a drivable tire with a diameter of 27” and relative narrow width. The handling of the Excelsior was fine with its thick side walls, the problem was a poor cast quality and being out of round by ¼ inch. Please spare me with the recommendation to use radial tires unless you know of one with the size of 15X195-80.
Thanks
Keoke
Bugeye58 said:
Gee, I just found some 775-15's for $420 EACH!---You left em right where you found em didn't Chu.--- /bcforum/images/%%GRAEMLIN_URL%%/laugh.gif
Everything I saw on the Falken site was a radial.---Well thats OK I have never sen a bias ply tire worth sod anyway. /bcforum/images/%%GRAEMLIN_URL%%/nonod.gif
See if there's anything here you may see fitting.-OK Good site.
https://www.universaltire.com/cart.php?target=product&product_id=24452&substring=640-15
Jeff
Yep I guess I better get them Verdee"s at $89.00 fore they decide to double the price on them too. /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
Johnny
Kumho makes a 165X15 that looks good and fits well. They are only $40 each at the Tire Rack. I figure your not going to be driving the car much anyway.
bob hughes
That sounds like what I have on the front, from memory, good for 130MPH ish. You can get them this side of the pond as well and they cost the same - in Pounds Stirling. /bcforum/images/%%GRAEMLIN_URL%%/nopity.gif
/bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Bob
glemon
The Kumhos are a heck of a deal and they work great.
I had dunlops RS5 or 6 on the car when I got it, very close to original spec, they looked great and had great tread, but cobined with the non-functional rear shocks on the car when I got it the bumpy corners were a little scary.
LuckyLuke
LuckyLuke
Thanks
many moons later…..the Firestone 6.40 x15 champion did it!!! . I finally found a great bias ply tire that fits for maximum diameter (27” for fast driving at low RPM) and super stiff side walls for good corner handling.
After the first month of driving I can say that interstate speeds are comfortable with out significant vibrations. Taking the car in an oversteer side slide on a dry paved road works well and even for a big Healey the transition back to a straight line is relatively smooth.
The reason why I choose the bias ply in the first place is that none of the radial tires that feature 27” diameter would fit under the Austin fenders (to wide). Contrary to common opinion I have found that the bias plies tires handle stiffer than radial (compared at the same outside diameter!! This is not true for low profile aspect ratios)
Ed Kaler
LuckyLuke:
I STRONGLY suggest you check to Date Code on EACH of those tires!!!! Where you bought them IS known to have OUT-OF-DATE product!!!!
Decode info is on my site.
:cheers:
Ed
LuckyLuke
LuckyLuke
Interesting roomer! Coker has great service an garantee. My tires were manufactured 2 mnoth before I bought them. Did you ever buy tires from coker??
My Michelins were almost two years old when Coker sent them to me. I complained and the said to sent them back for a refund. No one else had them so I kept them. My choice and I like them. I will go for cheaper and newer next time and not use Coker again although it was my choice to keep them.
oslo100
Another very nice (radial) wing/fender filling option is the Vredestein 'Sprint Classic': www.vredestein.com
Got them fitted two weeks ago and the handling and grip is great(although I guess even a cheap recycled type would have been an improvment over the 25 year old Dunlop SP previously on the car). Not too expensive either, I paid $150 each.
I bought the 165/80s but they seem to have 6 choices in 15".
Georg
LuckyLuke
LuckyLuke
Thanks for the hint about the vredestein. Dou have a picture mounted on your car? What is the exact diameter?
Rolf
oslo100
Hi, hope the attachment follows. Regarding the size I haven't measured (yet) but shouldn't this add up to 64,5 cm? (15"+ 165*0,8*2)
Georg
Shane
I have a couple of pics that I will upload when I get home. I took a shot of my Michelin 175/15's, followed by the Vredsteins 165/15's, and then finally my Dunlop spare for comparison. All of the shots were from the same angle/distance.
LuckyLuke good quality bias ply tire Jaguar 6
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
K TR2/3/3A Condenser Quality? Triumph 6
71TR6 TR2/3/3A New Windscreen Glass quality Triumph 6
B Poor quality BE replacement spring boxes Spridgets 0
Jayplum TR2/3/3A Source for quality parts Triumph 11
B Does anyone still make or sell a quality condenser? Austin Healey 14
Got_All_4 TR6 Newly purchased poor quality timing gear Triumph 5
S General Tech Electronic store for quality connectors. Triumph 9
Got_All_4 TR6 Quantum Mechanics John Esposito Quality overdrive parts Triumph 15
steveg High quality hose clamps Austin Healey 3
Jim_Gruber A Quality Piece of Kit for Bugsy IV - Creative Spridget Rear Disk Brackets Spridgets 8
T TR2/3/3A Replacement Floor and Trunk Panel Quality Triumph 14
Bob_Spidell Release Bearing Quality Austin Healey 8
GTP1960 TR2/3/3A Bonnet hinge issue/quality? Triumph 8
B TR2/3/3A Anyone have quality problems with TRF's TR2-4 ball joints? Triumph 10
R Waterpump quality Austin Healey 8
K Ignition parts quality Austin Healey 31
M TR4/4A Chromed parts quality? Triumph 1
Mink TR4/4A Dash/Crash pads - differences in quality between vendors? Triumph 8
M Door Seals: Best Quality and look Spridgets 4
HealeyRick B.M.C. Quality Austin Healey 8
N Spitfire Part quality??? Triumph 6
nevets Question about original Healey paint quality Austin Healey 20
T TR2/3/3A Moss TR3 radiator quality?? Triumph 5
I General TR Help on quality paint brand for steering wheel? Triumph 2
A TR2/3/3A TR-3A Interior Quality Triumph 7
bighealeysource Dayton Wire Wheel quality issues Austin Healey 0
T TR2/3/3A Are Classic2Current TR3 floor pans good quality? Triumph 14
5 Exhaust mount quality Austin Healey 6
I Reproduction tachometer drive quality? Spridgets 4
Mychael Where to buy quality pedal rubbers. Spridgets 2
Scott_Hower TR6 TR6 crank/timing gear quality issue? Triumph 2
T fender quality ??? Triumph 6
Nelson Moss "quality" again Spridgets 0
Stinger TR4/4A TR4A Front Badge Quality Triumph 6
TR6oldtimer TR6 TR6 lug nut quality Triumph 2
af3683 Quality Inner Tubes Austin Healey 2
M High quality window winders? Spridgets 4
W are quality trim pieces available for these cars? Austin Healey 9
bigjones Plug wires - anything of quality out there? Spridgets 27
T TR2/3/3A TR3 parts original and Repro quality Triumph 13
angelfj1 Paint Quality - Hydraulic Fluid Reservoirs Triumph 14
TR6oldtimer TR6 TR6 Rocker panel quality Triumph 7
KVH TR4/4A Quality of Crash Pads--TR4, etc. Triumph 5
B TR6 Super quality, super priced TR-6 dashboards Triumph 8
AUSMHLY Need source for a quality radiator cap Austin Healey 8
G VB poor parts quality Spridgets 39
J VB windshield quality or lack of? Spridgets 3
