Hi Team:
A video for gearbox experts to check out.
It's been a while since I posted, but with the cold Toronto winter, I decided to tackle a rebuild of my BJ8 gearbox today. I've run into a crossroads after getting 3/4 of the way through disassembly.
The problem the prompted the rebuild, was a perpetual slipping out of second gear, when decelerating under engine brake or downshifting from third to second.
I have followed posts on the forum and Hayes manual and have gotten as far as removing the 1st motion shaft, reverse shaft and layshaft from the case.
I was pleasantly surprised at how good a condition all the components are in, with no apparent wear/chipping on the visible parts of any of the gears.
Even externally the Syncro rings look great and sharp. Now, I am pausing to see if anyone can offer some advice on the 1st motion shaft before I start taking it apart unnesesarily. I have even prepared a video to help....
https://www.youtube.com/watch?v=Dwb5YsiprSs
(excuse my comentary, I got the 1st motion shaft and main shaft mixed up)
Issue 1:
Is the movement engaging the detents in the first gear assembly normal as I move it up and down or is there too much play? Or, as an alternative explanation, is it possible that the springs in the 1st gear assembly are a tad weak? Or, is it possible that the selector springs for the selector shaft/fork assembly are too weak to hold the gearbox in second?
Issue 2: From the video, is the orbital end play of the Main shaft too much? Should that main bearing be replaced?
Thank you for having a look at the video and posting your thoughts!!!
Andrew
Issue 1:
Andrew
