Gauge faces - where to get
ClassicBritish
So our 1963 BJ7 is in need to either replacement or refinished faces. Where can I get replacement faces from? Or where can I get them refinished?
Duane_Rhynard
My last customer service experience with Nisonger was less than satisfactory.
I've since used both of these guys below, great customer service and high quality work! (No affiliation just a happy customer!)
West Valley Auto Electronics
19314 Vanowen Street
Reseda CA 91335
(818) 758 9500
(877) 818-9402
Maurice Mintz
https://westvalleyinstruments.com/contact.htm
MOMA Manufacturing
Joey: jlobo@momamanufacturing.com
1321 2nd St. NW Albuquerque, NM 87102
(505) 766-6661
https://www.momamanufacturing.com/about.html
Duane
'58 BN6
'61 BT7 Tri-Carb
Duane_Rhynard
Yes, but do any of these folks have a record of doing a great job restoring the gauge faces? A different specialty than overhauling the instruments or cleaning them up.
Yes they do!
Additionally, when I had by BN6 gauges re-faced at Nisonger they did not do them in-house, they sent them out to a third party.
Jim 58 BN6
Yes they do!
Duane, Thanks a lot for the MoMa lead. I'm only about 30mins east of them, and didn't even know they existed! I have the BN6 and an old Alfa that both need their gauges either rebuilt or serviced. Jim :encouragement:
mwagon
From my experience don't even consider West Valley. The refinishing of the gauges was terrible quality. Letters were blurry, incorrect #'s reprinted, main face paint looked more like a wrinkle paint was used and incorrect color. I was charged for cleaning the mechanisms, but they were never cleaned. The gauge shells original plating was ground off in places, but not replated. I ended up having Palo Alto redo the gauges & with total satisfaction. I wish that I had not tried going somewhere else then a proven source to save a couple dollars & for shorter turn around time.
blueskies
If you are like some Healey owners, you may have a box full of non-functional or spare gauges. Taking reasonable care, one can disassemble gauges and put the better parts together. Or if you aren't comfortable doing that, you could send in a non-functional donor gauge with a nice face to the experts, to do the face swap.
DTDuck
You can try Palo Alto Speedometer:
www.paspeedo.com
718 Emerson St.
Palo Alto, CA 94301-2410
info@paspeedo.com
Tel: 650-323-0243
Fax: 650-323-4632
They have been restoring guages as Long as I can remember (well over 35 years) and the work that I have seen of theirs has been excellent and on the west coast they are the place to go. Not sure why, but their website wasn't working when I just checked.
Cheers,
Dan M.
B General MG Replacement gauge faces MG 2
TR6oldtimer Decals as a means to refurbish gauge faces Triumph 7
Y Gauge faces Triumph 1
curdy General Tech Gauge Dust Reduction Triumph 4
J For Sale Gauge brackets (lot of 7) for sale Other British Classifieds 0
Rick_Thompson TR2/3/3A Overheat issue, gauge adjustment Triumph 9
G MGB ugh.....the fuel gauge went to *** again! MG 8
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
roscoe Fuel Gauge Austin Healey 0
G Smith's temp gauge repair Restoration & Tools 4
CARSINC eBay Gauge Packages Spridgets 6
Gliderman8 TR6 Excessive reading on volt gauge Triumph 17
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
Gatheringtree TR2/3/3A Gauge Set Triumph 17
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
LD-Ordie TR2/3/3A TR3 gauge service Triumph 11
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
B For Sale BaulyCars - Gauge Bezels Triumph Classifieds 0
AngliaGT MGB-GT Gauge Repair Recommendations? MG 4
BierRunner TR6 Temperature Gauge Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
Lairhead52 Wanted Oil Press Gauge Triumph Classifieds 0
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
Fanch00 Inoperative Fuel Gauge Austin Healey 10
R Coolant temperature gauge Spridgets 8
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
Editor_Reid Water Temp Gauge Austin Healey 5
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
E Gauge Lights Austin Healey 4
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
R TR2/3/3A Fuel Gauge Triumph 19
nichola TR6 Smiths volt gauge needle barely moves Triumph 25
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
