TR6 Gauge/color wire ?
ichthos
I am adding two Lucas fog lamps. Anyone know the correct color and gauge wire I should be using? Source? Thanks, Kevin
TR3driver
Great Pumpkin - R.I.P
Rut
Kevin,
Be sure to install relays while you’re installing the fog lamps.
Rut
I
ichthos
Thanks for the correct gauge and the source, Randall.
Rut, I know very little when it comes to putting in new wiring. I have the lights mounted where I want them. My next step was just getting the correct wire. Where would I get the correct relay, and what would I ask for? The purpose of the relay is to protect the light switch, correct? I was going to wire my Lucas fog light switch to my ignition switch, put in a fuse(not sure what amperage) and run the wire from my switch to my lights. How would you hook everything up?
Rut
Kevin,
Im a poor one to ask about electrickery! Bosch and Hella have very good reputations for relays and they take the load off the switch. I added a spot and fog to my MGB and followed the Moss diagram...I also added relays to the headlights for the same reason. Next up will be the wiper motor! https://www.mossmotoring.com/how-to-wire-drivingfog-lights/
Rut
poolboy
The way you have described powering the lights, the lights will be on whenever the engine is running or should I say when the ignition is ON, engine running or not....day and night.
:eek:....forget it. I misread your post....sorry
TR3driver
My suggestion is to add a separate switch for the fog lights. If you use a relay, then I suggest getting power for the switch from the taillight connection at the headlight switch. That way, you can't forget to have the taillights on when running with fogs, but can run fogs without main headlights.
Almost any modern relay will work fine, IMO. I bought a dozen cheap relays on eBay some 20 years ago and they are all still working fine.
In this situation, I would say a relay is optional. It does let you wire as I've described above, and help extend the life of the original headlight switch.
But a simple automotive rocker or toggle switch can handle the current just fine, and will probably outlast the car. Your call.
After a bad experience some years ago, I'm allergic to a single fuse that can put out the headlights if it fails. I was blowing down a mountain when the lights suddenly went out (for no apparent reason, there was no overload). Could have been a lot worse, but I did have my preteen daughter in the car. So I now have separate self-resetting circuit breakers for each headlight. A single fusible link would probably be just as good.
Rhodyspit75
That wiring diagram works fine for what you want to do. Just take the white wire to the switch and connect it to the ignition switch. I wouldn’t even bother with a fuse in that wire it only goes to the relay really no load. This will not overload the ignition switch and will only let the lights work when the switch is on. Unless you use an illuminated switch there is no reason for the black ground wire to the switch.
J For Sale Gauge brackets (lot of 7) for sale Other British Classifieds 0
Rick_Thompson TR2/3/3A Overheat issue, gauge adjustment Triumph 9
G MGB ugh.....the fuel gauge went to *** again! MG 8
RJS TR4/4A Smiths Oil Temp Gauge Triumph 11
J MGB Oil Pressure Gauge Gives Constant Reading -- Doesn't Seem Right MG 15
roscoe Fuel Gauge Austin Healey 0
G Smith's temp gauge repair Restoration & Tools 4
CARSINC eBay Gauge Packages Spridgets 6
Gliderman8 TR6 Excessive reading on volt gauge Triumph 17
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
Gatheringtree TR2/3/3A Gauge Set Triumph 17
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
D Fuel Gauge Austin Healey 7
BoyRacer Thread Pitch Gauge from "British Tool and Fasteners" Austin Healey 0
LD-Ordie TR2/3/3A TR3 gauge service Triumph 11
RJS General TR Oil Pressure Gauge - Test Triumph 11
RJS TR4/4A R&R Oil Pressure Gauge Triumph 7
RJS TR4/4A TR4A Temp Gauge Scale Triumph 6
B For Sale BaulyCars - Gauge Bezels Triumph Classifieds 0
AngliaGT MGB-GT Gauge Repair Recommendations? MG 4
BierRunner TR6 Temperature Gauge Triumph 8
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
HighAltitudeTR3 T-Series MGTD Sheet Metal Gauge?? MG 0
Lairhead52 Wanted Oil Press Gauge Triumph Classifieds 0
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
B TR4/4A Jaeger Gauge Question Triumph 16
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Retired2020 TR5/TR250 TR250 smith gauge Triumph 7
L Oil Pressure Gauge Austin Healey 5
Martinld123 Problems with my BN2 Temp Gauge reading Austin Healey 13
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
Fanch00 Inoperative Fuel Gauge Austin Healey 10
R Coolant temperature gauge Spridgets 8
EWD TR6 Temp Gauge - 74 TR6 Triumph 11
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
Editor_Reid Water Temp Gauge Austin Healey 5
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
Gliderman8 TR6 Vacuum Gauge Hookup Triumph 11
E Gauge Lights Austin Healey 4
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
K TR2/3/3A Using a dial gauge to adjust valves when rocker arm surfaces are worn? Triumph 9
R TR2/3/3A Fuel Gauge Triumph 19
nichola TR6 Smiths volt gauge needle barely moves Triumph 25
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Fuel gauge calibration procedure Austin Healey 18
D TR6 Disconnecting pipe from engine block to oil pressure gauge Triumph 6
C MGA Fuel gauge question MG 8
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
D TR2/3/3A Wing nuts for gauge panel on TR 3 Triumph 10
