Fuel overflowing
Leew
Hi Chaps
Back from my vacation and back to another AH problem and question.......
When I switch on the ignition on my 100/6 occasionally the overflow on one of the cars spills out fuel where obviously the float does not cut off the fuel once the bowl is full
Also my fuel pump continues to run / click
This happened the first time I switched on the ignition but on the right hand carb HD-6's ?
So I took them apart cleaned them, fitted new filters and put them back together
Been fine for a while, this afternoon switched on ignition after the car sat for three weeks........... left hand carb overflowed
Do we all think this is just cleaning?
Ta
nevets
I had similar problems. One of the floats had a leak and was partially filled with gas. Unrelated to the float bowl leak problem, I had further overflow issues and the problem was solved when I switched to Grose jet float valves. Some folks prefer to stick with the Viton needle type float valves.
Keoke
Get U some LEEW and your problems will go away--:highly_amused:
John Turney
... I had further overflow issues and the problem was solved when I switched to Grose jet float valves. Some folks prefer to stick with the Viton needle type float valves.
I'm one of those who has had better luck with the Viton needle type float valves.
L
Leew
Thank you gentleman, after much deliberation and rooting around the interweb I have decided to go with the SU uprated sprung Vitons
I'll keep you informed on my experiences
ta
RestoreThemAll
Is it the valve or a float that's starting to fail?
John Turney
I sometimes have that problem if my car has set for several months. The fuel will slowly evaporate and may leave behind some "gunk" or varnish that keeps a float from floating. I fill the carb bowls, turn off the pump and let the fresher fuel dissolve the gunk. The floats pop up and shut off the valves and I'm good to go off to the filling station to refuel.
MikeAH100M
I had the same problem on my 100. It had the older metal floats with a soldered joint and the floats filled with fuel. Interestingly, I could find no leak when the floats were cold so the joint must have expanded when heated and allowed fuel to enter. Went with the seamless black plastic floats and no problem.
DTDuck
Common problem, you can tell if it is the float or valve by rapping the offending float bowl lightly (I would use a screwdriver handle, but a light plastic hammer will do the trick as well). If the valve is sticking open, the rapping will most likely loosen is sufficeintly for the float to, well float and close the valve. If the float is sinking because it is leaking, no amout of rapping will help.
Cheers,
Dan M.
CessnaTPA
I just rebuilt my H4 Carbs and installed the grose jet valves, I notice when I turn the motor off after a few mins I get about a 1/2 teaspoon of fuel puddled in the intake after the air filters. I adjusted the float level 7/16" like the book said. Does it sound like it might be out of adjustment or the new grose valve leaking? I have a brand new set of the original valves and debating if I should just go back with the old type.
steveg
Folks have had issues with the Grose valves in recent years. If you have the viton-tipped ones, they would probably be best.
Should add I have Grose valves in my HD8s and have never had any problems - however they could be the old ones from 20 years ago.
Keoke
Once in a while the fuel will not remove an anti corrosion finish placed on Grose Jets so they need to be sloshed around in Acetone and wiped dry before reinstalling.
CessnaTPA
Removed the grose jets today and replaced with new viton valve and have no leaks. I'm not a fan of the "bulletproof" grose valves.
Patrick67BJ8
There's no "spring" in the grose jets to hold them tightly closed and sealed and the engine vibrations could allow them to leak fuel. It might not be a lot always, but the potential is there. The ones I had back in the '70's were good for several years before they started leaking. I don't use them anymore.
M Overflowing R/H Gas Tank 87 XJ6 4.2 Liter Fuel Inj Jaguar 6
AndreL TR6 Conversion to electric fuel pump Triumph 10
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
A TR6 How many fuel filters-TR6 Triumph 25
Q TR2/3/3A 61 TR3A Fuel Pump Triumph 4
A TR2/3/3A Those round fuel line clips Triumph 2
SherpaPilot TR6 Preping a New Fuel Tank Triumph 7
RJS TR4/4A Tune Up Order - Fuel and Ignition Triumph 5
G MGB ugh.....the fuel gauge went to *** again! MG 8
D Wanted Square body LCS fuel pump Austin Healey Classifieds 13
D Wanted Wanted square body fuel pump Jaguar Classifieds 0
J MGB Jet Tube to Float Chamber Fuel Leak MG 7
roscoe Fuel Gauge Austin Healey 0
D TR4/4A TR4a Fuel Pump Triumph 10
Erica MGB Carburetion and MGB fuel economy. MG 0
Frameman 1949 New Moss Motors Fuel Tank Austin Healey 10
RJS TR4/4A Fuel Pump Gasket Triumph 8
RJS TR4/4A Fuel Filters and percolation/ vapor lock Triumph 0
J TR2/3/3A Rear Fuel Line Clips Triumph 3
M TR6 Fuel return line Triumph 8
KVH TR4/4A Routing of TR4A Fuel Line Triumph 7
mctriumph TR2/3/3A Brand new fuel pumps Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
PAUL161 T-Series Fuel Pumps MG 5
D Fuel Gauge Austin Healey 7
Walter74 Fuel Line Routing Austin Healey 7
D MGB Fuel Pump MG 2
Editor_Reid Fuel Tank Interchangeability Austin Healey 2
Martinld123 Electric Fuel Pump Austin Healey 6
S TR2/3/3A Fuel Pump??? Triumph 14
D Fuel Pump Ticking but Not Pumping Austin Healey 8
A Spitfire Fuel Pump Triumph 5
A Spitfire Spitfire Fuel pump issues Triumph 5
K TR2/3/3A Fuel line routing from pump to carbs Triumph 7
BoyRacer Fuel Tank Sending Unit Austin Healey 3
D Fuel Line Clip vs Brake Line Clip Austin Healey 2
T Wanted Working Fuel Gauge for TR3A Triumph Classifieds 5
G Best fuel option for a 72 Midget Spridgets 5
A GT6 Fuel Pump Leaking at out port GT6 MK3 Triumph 0
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
S fuel pump upgrade Spridgets 0
S Sprite Fuel Pump Upgrade Austin Healey 1
G TR6 Clogged fuel line Triumph 6
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
T TR2/3/3A TR3A Fuel Gauge problem Triumph 10
M Fuel Filler Caps Austin Healey 2
F TR4/4A New to forum - Rebuilt Fuel Pump and weeping float bowl Triumph 9
Patrick67BJ8 Fuel Hose Decals Austin Healey 16
