tr6_easyrider
Had a fuel hose problem with new Gates 1/4" Greenshield fuel injected hose.
The inside of the hose shredded like I ran a drill bit thru it and when I pulled it off the steel line some gas leaked on the outside and my fingers turned black and the hose felt gummy. Never had this happen before. Blocked both carbs. and both needle valves, aand even made it into the float bowls. I still need to call Gates.
