froze brake drum?
mtlman8
rebuilt the entire brake system... driver side rear drum is stuck! I drove it down the street to see if it would free up.. it didn't... how can I free it up? BTW first drive in 26 yaers was short but sweet.
Tr4dude
BFH!!! :yesnod: after removing the tapered screw and loosening the adjustment screw.
Andrew Mace
First, I'd ensure that there's nothing causing the handbrake lever to be hanging up or anything that might have kept the wheel cylinder from sliding as necessary. You could crack open the bleeder to relieve pressure, just in case that might have something to do with the problem. And you could back off the adjuster as much as possible. If all that fails, I'd try working my way around the outside edge of the drum with a hammer, alternating with trying to turn the drum/hub.
With luck, it'll all come apart again, and you can more thoroughly check things out when it does.
Deleted member 8987
Does it wobble at all, or stuck solid?
BFH is the answer, except on other cars, we used a BFBP, using the ball end of the ball-peen hammer to hit once between each wheel stud location.
Hit it with ZEP45 or PBBlaster first to allow it to soak in around the edges a bit.
Always worked for me.
M
mtlman8
thanks toc. got it unstuck... drove it around the block and it feels AWSOME!
Geo Hahn
Congrats on the first drive!
I just did the shoes on the TR3A (10") using the Classic Gold from Moss (was quite pleased that 10" shoes are again available). The shoes were too thick for my drums, could not adjust them in far enough to clear (or even get the drum on w/o force).
In the end I had to take a little off each shoe with a belt sander. Hated to do it but there you are. Also tapered the leading edge a bit.
Investigating in the archives it seems this is a common problem -- they make the replacement shoes just a bit thicker than original on the assumption your drums have been turned a couple of times.
I mention this in case it is your problem.
TR3driver
Great Pumpkin - R.I.P
"Back when" it was actually common to grind a bit off of new linings. This was called "arcing" them, and there was a special tool that moved the shoe in an arc as it was ground. The result was supposed to be a friction surface that exactly matched the inside of the drum.
I only had it done once (on a car with front drums) but it sure made a big difference in how well the brakes worked!
M
mtlman8
that was the prob. the radius on the drum was not the same as the shoe. felt kinda odd grinding on a brake shoe, but whatever it worked.... runs great and stops short... i'm STOKED!
TR3TR6
I took my 10" shoes to a brake shop and they bonded on new linings. They worked perfect. It cost me $ 35.- 40.00 dollars. They've been in business for over 50 years, that was several years ago, there prices may have gone up some. They are located in Wichita, KS. If anybody wants to contact them, I can give you a telephone No..
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
B Rear Brake Cylinders Austin Healey 4
K TR2/3/3A Brand new brake caliper question... Triumph 8
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Chrisc9 TR6 TR6 brake light Triumph 6
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
bighealeysource Brake Master Cylinder Austin Healey 27
S TR2/3/3A Lockheed brake system Triumph 7
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
TomMull TR2/3/3A Parking brake: Lesson learned? Triumph 8
LAW75 BJ8 Brake Lines Austin Healey 2
A Brake Master Cylinder Freeplay Austin Healey 11
