TR2/3/3A front suspension
flyingbp
vertical link will not screw in more than 3 to4 threads to lower trunnion tryed grease no luck, threads in fine to old trunnion. purchased part from reputable supplier.
CJD
When I restored my car 3 years ago, I had to send back 3 sets of trunions for issues like you are experiencing. My problem was the threads in the trunnion were more sloppy than the original trunnion I was replacing. It sounds like the machining precision of the new trunnions still has not been addressed...
charleyf
I just installed a new set of trunnions on a TR3. They were from TRF and fit fine onto the vertical link.
Charley
TR4nut
You may also have a bent verticle link, look closely at the shaft and see if you can detect anything. My TR4 had that issue, would not screw all the way in - it was bent.
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
R TR6 Front suspension fulcrum pins Triumph 6
Upland Mark IV front suspension Spridgets 3
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
DrEntropy MGB Results of renewing front suspension MG 7
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
D Front suspension question Austin Healey 0
D back to the front suspension Austin Healey 4
D Front suspension half moon cotters Austin Healey 6
D front suspension Austin Healey 7
S TR4/4A TR4 front and rear suspension Triumph 8
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
M TR4/4A Front suspension Triumph 4
I TR6 Broken front suspension bracket Triumph 3
Scotsman TR4/4A Front Suspension Strengthening Kit assembly Triumph 2
mcmillal TR4/4A Front Suspension Re-assembly Triumph 7
K TR2/3/3A Greasing the the Idler lever on front suspension? Triumph 3
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
Popeye TR4/4A TR4A front suspension quesions Triumph 19
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
C TR2/3/3A Question on assembly of front suspension Triumph 3
W TR2/3/3A TR2/3 Front Suspension Upgrades Triumph 13
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
maxwedge5281 front suspension or braking improvement Austin Healey 25
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
M Adjusting Front Suspension Austin Healey 11
B TR2/3/3A Your Opinion of TRF Rubber Bushes for Front Suspension Triumph 6
Got_All_4 TR2/3/3A Tr3 front suspension re-bush, what's good out there Triumph 15
BN6_2197 Reassembling front suspension of BN6 Austin Healey 31
bugedd Front suspension and oil pan Spridgets 17
aseriesspares Front Suspension & Disk Brake Kits Spridgets 3
bugedd Front suspension springs Spridgets 4
M front suspension rebuild parts list Spridgets 22
BN6_2197 How to adjust the front suspension of a BN6 Austin Healey 52
