Front Suspension Bushings Question
GWL2
Anyone with experience using the poly front suspension bushings from Moss Motors. A set of mine I'm ready to install to an MG-TD (same as MGA and MGB) are a little bit loose when fitting to the suspension "A" arm. They are a snug fit on the mounted pivot but about .020" off when fitting to the "A" arm.
When tightened up they also squeak a bit when the arm is moved. Is this normal and will I hear it later?
Will I notice the lack of a tight fit in the bushing to arm fit?
Thanks, George
19_again
George,
I use em in my 67B, they are fine. They'll work a bit as you drive of course.I used red grease when installing them as recommended by someone here on this forum and no squeaks.
As for the fitting aspect, I don't have any input on that. Mine fit very well, not too tight not too loose.
Mike
Nunyas
When I installed poly bushings on my B, I used a bit of silicon/white lithium grease. They had a snug fit on the pivot, and a "perfect" fit on the arm (i.e. slide right in with no slack). The grease ensured they would not squeak.
G
GWL2
Thanks for the response. I've got a set of MGB, V-8 bushings that fit much better that I will use instead. I'll put some lubrication(anti-seize) on the pivot to avoid corrosion which Moss Motors says they are prone to do.
The poly bushings must be a bad batch for fit.
Thanks again, George
R TR2/3/3A Replace Rubber bushings in front suspension Triumph 11
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
R TR2/3/3A Front Suspension Polyurethane Bushings Triumph 2
ahealey1004 how to remove front suspension inner bushings? Austin Healey 6
tomshobby Which front suspension bushings? Spridgets 15
jlaird Oh me, The post on front suspension bushings Spridgets 7
T TR2/3/3A Poly bushings for TR3 front suspension Triumph 7
J front suspension bushings. - how big of an effort? Triumph 19
N Front End Suspension Bushings MG 7
jfslenes Front Suspension HiPo Bushings Sunbeam (Rootes) 1
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Endoscaper TR2/3/3A Lower Front Suspension Overhaul Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
crispy BJ8 Front Suspension Austin Healey 9
R TR6 Front suspension fulcrum pins Triumph 6
Upland Mark IV front suspension Spridgets 3
S TR2/3/3A Front Suspension Triumph 6
J Front Suspension Rebuild Austin Healey 16
71TR6 TR2/3/3A Right Front Suspension Damage Repair? Triumph 50
Jayplum TR2/3/3A Front suspension / springs Triumph 5
TRclassic3 TR4/4A Help with deciphering front suspension problem Triumph 11
F TR4/4A Front Suspension Triumph 3
warwick-steve Front suspension rubber trunnion bearing question Austin Healey 4
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
T TR2/3/3A Is there a reason for this large pointed piece on front suspension? Triumph 14
DrEntropy MGB Results of renewing front suspension MG 7
D Front suspension question Austin Healey 0
D back to the front suspension Austin Healey 4
D Front suspension half moon cotters Austin Healey 6
D front suspension Austin Healey 7
S TR4/4A TR4 front and rear suspension Triumph 8
M TR2/3/3A FRONT SUSPENSION: Rusted lower control arm fulcrum Triumph 17
M TR4/4A Front suspension Triumph 4
I TR6 Broken front suspension bracket Triumph 3
Scotsman TR4/4A Front Suspension Strengthening Kit assembly Triumph 2
mcmillal TR4/4A Front Suspension Re-assembly Triumph 7
K TR2/3/3A Greasing the the Idler lever on front suspension? Triumph 3
Scotsman TR4/4A Front Suspension Vertical Link Triumph 2
Popeye TR4/4A TR4A front suspension quesions Triumph 19
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
C TR2/3/3A Question on assembly of front suspension Triumph 3
W TR2/3/3A TR2/3 Front Suspension Upgrades Triumph 13
maxwedge5281 front suspension or braking improvement Austin Healey 25
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
M Adjusting Front Suspension Austin Healey 11
B TR2/3/3A Your Opinion of TRF Rubber Bushes for Front Suspension Triumph 6
