Follow up on Datsun 5 Speed
Coastalman
The Datsun 5 speed I found on https://www.car-part.com came today. It is the correct one. It does have a serial number that starts with "F" and the number "60" stamped on the casing.On a previous post we were not sure of the accuracy of the listing. The listing I responded to called the tranny a RWD 1982 B210. When I called CBASS, who had the tranny, they asked if it was a "A15". They use this identifier. Oh yes, you may have to use Nissan instead of Datsun in the search phase. The year is the key. Evidently they do not differentiate between Nissan, Datsun, 210 or a B210. I said yes to the A15 and they sold it for $125. With the freight to NC it came to a total of $190. From what I hear, that is a good price. They included the shift lever and the bearing housing which I asked for. I hope this helps anyone who might be looking for a 5 speed for their Sprite.
Charlie
drooartz
Nice find, indeed. They're still out there, just need a bit of searching.
Jayrz
Some times you just get lucky. I paid $250 for mine shipped and thought I got a pretty good deal. Congrats!
sim
Hi
I have a 58 sprite 948 first gear has a tooth or 2 missing
will this type of upgrade work for me?
What else is needed?
Thanks
sim
jlaird
Yes
Bugeye58
A Datsun 5-speed transmission from August 1979 to 1982 Datsun 210. This can be from a coupe, sedan or wagon.
All the pertinent information is on the above referenced Rivergate website.
Jeff
C
Coastalman
Sim, check out the web site I mentioned. You may need to subsitute Nissan for Datsun when you are searching, but you end up with the right tranny as long as the year and car are correct. '79 to '82 is the key. Also A15 is mentioned and will be the correct tranny.
Charlie
Billm
Called the guy today- it came out of a 620 Pick-up, won't work, but I may look at putting it into my MGB!
Bikk
CARSINC Follow My Spriget Blog As I Complete SpyderMite Spridgets 24
jlaird MGB Follow up to my bad post on prewar MGs MG 4
longbridgehealey Horn question follow up Austin Healey 12
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
P TR6 Follow-up to hard starting Triumph 4
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
drooartz The teardown begins, follow along at home! Spridgets 51
D TR6 Follow-up question Triumph 3
P Follow up to valve job Triumph 3
drooartz MGB Follow along as Drew tears down an MGB engine! MG 21
KVH TR4/4A TR4A OD Follow Up Triumph 10
tahoe healey Gunson colortune follow-up Austin Healey 17
nevets intermittant sputtering follow-up Austin Healey 13
eschneider TR2/3/3A follow up - TR3 broken pushrod &compression test Triumph 1
G follow up question on ZDDP Triumph 12
tahoe healey dizzy follow up Austin Healey 7
KVH TR4/4A Tires and Wheels on a TR4--A follow Up Triumph 9
G Follow-Up Horn Question Triumph 2
T Wedge Follow-on TR8 interior question - seats Triumph 4
N TR6 Follow up on lean TR6 carbs Triumph 1
J Failed State inspection-tie rod end..follow up Spridgets 4
RickB MGB-GT Follow up ?... Exhaust on the MGBGT all good MG 9
X Schumacher follow up. MG 3
martx-5 TR2/3/3A Follow-up on TR3 Master Cylinder Resevoir Triumph 2
jlaird Want to follow along Spridgets 11
B TR6 Follow-on question regarding new TR6 tires... Triumph 5
B Darn Things Follow Me Home. Spridgets 14
Trevor Jessie Repairing a dual gauge, follow up Spridgets 4
nevets OD follow-up Austin Healey 0
jlaird Follow on question, Differintal Spridgets 3
S atmospheric crankcase follow up Triumph 1
S Wedge The TR7 Fuel Gauge Follow-up Problem !?!? Triumph 12
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
T Datsun 210 at Pull-N-Save Mesa, Arizona Spridgets 3
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
Boink Datsun 2000 Spotted 5
T 1982 Datsun 210 near Sacramento, since March 09 Spridgets 0
shadowfever Datsun 5-speed info neede Spridgets 5
T 1982 Datsun 210 in Denver Spridgets 13
T 1981 Datsun 210 Orlando U Pull & Pay Spridgets 18
BoyRacer Nissan/Datsun engine swap into a 100/4? Austin Healey 30
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
T 1979 Datsun 210 at U-Pull in West Palm Beach, FLA Spridgets 1
Bayless Started adapting the datsun gearbox today Spridgets 46
K TR2/3/3A Datsun 240Z aluminumn brake drums? Triumph 5
Marvin Gruber Datsun 2000 Other Cars 12
Rut Datsun 210 Spridgets 5
