TR6 Follow-on question regarding new TR6 tires...
bricktop
Got plenty of solid tire recommendations for replacing the redlines from the forum. Most of them involved going with a 205/70 from the 185's. During a conversation with the mechanic while he fixed my flat michelin, he mentioned that while the 205 is a great aesthetic tire for a TR, you stand a better than average chance of tire rub in the wheel well with two adults and a suitcase in the car. He said it's not really a problem, but you WILL experience it nonetheless. Any thoughts?
Brosky
I dispute that opinion also. I have had a heavy tool box and two large passengers in car with no problems at all in front or rear. I've never seen any issues posted by owners using the 205 tires.
jerrybny
I'm running with 205/70/15 on the original rims. We just came back from driving 1000 miles along the beaches in New England and not once did I expierence any tire rub.
Ab Crevoiserat
Never had a rub from my tires, and lets be honest , how much luggage can you really get into one of these cars, an overnight bag with a change of clothes and some nighties for the Lady in the passenger seat?
TR674
I purchased a set of Yokohama A536's to replace the same sized worn ones a few years ago (size is 195/60R15), and I have no complaints. Fitted to original rims.
Regards
Craig
longbridgehealey Horn question follow up Austin Healey 12
D TR6 Follow-up question Triumph 3
G follow up question on ZDDP Triumph 12
G Follow-Up Horn Question Triumph 2
T Wedge Follow-on TR8 interior question - seats Triumph 4
jlaird Follow on question, Differintal Spridgets 3
CARSINC Follow My Spriget Blog As I Complete SpyderMite Spridgets 24
jlaird MGB Follow up to my bad post on prewar MGs MG 4
glemon TR5/TR250 Stumped TR250 Running Rough--Follow Up Triumph 3
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
P TR6 Follow-up to hard starting Triumph 4
F Follow on questions from HD6 carburetor rebuild Austin Healey 5
drooartz The teardown begins, follow along at home! Spridgets 51
P Follow up to valve job Triumph 3
drooartz MGB Follow along as Drew tears down an MGB engine! MG 21
KVH TR4/4A TR4A OD Follow Up Triumph 10
tahoe healey Gunson colortune follow-up Austin Healey 17
nevets intermittant sputtering follow-up Austin Healey 13
eschneider TR2/3/3A follow up - TR3 broken pushrod &compression test Triumph 1
tahoe healey dizzy follow up Austin Healey 7
KVH TR4/4A Tires and Wheels on a TR4--A follow Up Triumph 9
N TR6 Follow up on lean TR6 carbs Triumph 1
J Failed State inspection-tie rod end..follow up Spridgets 4
C Follow up on Datsun 5 Speed Spridgets 11
RickB MGB-GT Follow up ?... Exhaust on the MGBGT all good MG 9
X Schumacher follow up. MG 3
martx-5 TR2/3/3A Follow-up on TR3 Master Cylinder Resevoir Triumph 2
jlaird Want to follow along Spridgets 11
B Darn Things Follow Me Home. Spridgets 14
Trevor Jessie Repairing a dual gauge, follow up Spridgets 4
nevets OD follow-up Austin Healey 0
S atmospheric crankcase follow up Triumph 1
S Wedge The TR7 Fuel Gauge Follow-up Problem !?!? Triumph 12
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
