Failing starter solenoid?
NutmegCT
Seems that the more I fix things, the more I discover more things that need fixing.
I'm sure that never happens to anyone else.
1953 MGTD. Battery fully charged at 13.1 volts.
I've got ignition disconnected while I do compression tests; plugs removed, engine is easy to turn.
This morning I tested all four cylinders. No problems with starter at all. Battery had gone from 13.1 volts to 12.6 volts during the test.
But this afternoon, after recharging the battery back to 13.1, I tried the tests again. First cylinder, starter spun nice and strong, no problems. But second cylnder, I hit the starter button, starter immediately spins nice and strong for about one second - but then immediately slows and turns very slowly.
Release starter button, starter stops turning. Battery has gone from 13.1 to 12.8 volts.
Repeat - same thing.
Is this a failing solenoid? failing starter? failing battery?
I even tried this with a second battery in parallel. Same result.
Thanks.
Tom M.
TR3driver
Great Pumpkin - R.I.P
Check the voltage at the starter when the problem is happening. If it is dropping way down, you got a bad connection or the solenoid has gone south.
But if the starter is turning slow with at least 10 volts applied, the problem is inside the starter. Might just need new bushings, or brushes, so I'd have a peek inside.
dklawson
Keep in mind that the battery will give you a false high reading immediately after charging. It may show 13.1V right after you disconnect the charger. However, if you let it rest or put a light draw on it, after a few minutes it should drop down to about 12.5V if the battery is healthy.
A test you can carry out in addition to those recommended by Randal is to bridge the large cable terminals on the solenoid with an old screwdriver or pair of pliers. There will be sparks when you bridge the threaded posts so don't let that spook you. If the starter runs at speed when the solenoid is jumpered, it suggests a problem with the contacts in the solenoid. If the starter is slow when the solenoid is bridged it could be bad connections or a bad/tired starter.
NutmegCT
NutmegCT
Thanks gentlemen.
Question: if battery has been on charger all night, and charger shows "fully charged" in the morning at 13.10 volts ... and I crank the starter four times (ignition off) for four seconds each time - should the battery then be down to 12.5? Seems like a fast drop to me.
And a related question: should the starter slow and stop when voltage drops to 12.5?
Tom M.
TR3driver
12.6 is 'nominal' for a fully charged battery. So, 12.5 is probably OK, given that your voltmeter might not be right on the money (and I don't know what temps are running in Conn, been a bit of a cold snap here). That drop is exactly what Doug was talking about, and I think I mentioned before as "surface charge".
No, the starter should run full speed on 12.5. Generally they are rated around 9 volts anyway, to account for the drop in the cables, etc in cold weather.
JPSmit
Tom, If it spun up fine before it is not likely bushes -
1. check the ground - battery and engine - and then the terminal connections. Sounds very much like something is partly loose (the most annoying kind)
2. Check with another known good battery. Eliminate the simple things first.
I think it is highly unlikely the starter is the problem - unless it just needs a good clean and lube (dry lube!)
TR3driver
Another possibility is bad ignition timing. If the timing is too far advanced for some reason, the engine can fight the starter.
I've had several starter failures where the starter would only turn very slowly and often draw way too much current. Most impressive one was where one of the brush leads got out of place and was dragging on the armature. I thought the car was on fire, but it was just the smoke from the battery cable.
NutmegCT
NutmegCT
What do you think of the possibility that the brushes are very worn, and/or no longer able to slide in their holders?
Before I head off to work, I'm going to try the starter again. If it spins fast, then slows down and stops, I'm going to tap the starter head with a hammer to see if that improves the situation. Hammer tap might loosen up sticking brushes - at least as a test.
TM
dklawson
As Randall said, high compression and advanced timing can make it hard for the starter to turn over, however, I believe you said this happened to you during compression tests while the plugs were out. Is that correct?
I cannot tell you what the symptoms are for worn, or dirty brushes. I have had one starter where the brush springs broke and therefore all the brushes did not make contact. However, I don't remember what happened except it was an obvious failure and would not turn the engine over. That is not consistent with your description of the starter slowing down.
If you don't want to try my test to jumper the solenoid with a screwdriver, try jumper cables. Use the cable from the battery hot terminal directly to the starter. If the starter still slows and stops you can feel confident the problem is in the starter. If it operates normally, the problem is in the connections (cables, cable terminals, solenoid contacts, etc).
NutmegCT
NutmegCT
Yes - all plugs are out, so starter has an easier time of it. By the way, there's no traditional "solenoid" with exposed terminals on the car. Just a pull cable to close a mechanical switch to complete the starter circuit.
This morning same symptoms, but I tried something new. I just kept the starter circuit closed even after the starter slowed and stopped.
Starter actually came back to life on its own - but again very slowly. Kept the starter circuit still closed, and the starter would seem to "catch" and turn fast, then slow again, then fast again.
I did use the "battery direct to starter" test (omitting that starter switch), and same result. Fast at first, then slow, then stop, then fast, then slow again, all the time the cable was directly connected to the starter.
The plot thickens.
Thanks.
Tom M.
dklawson
If you bypassed your starter switch (solenoid) with jumper cables and the starter behaved the same, the problem is most likely associated with the starter itself. I would remove the starter, inspect, and clean it to see what you find.
TR3driver
Sorry, I forgot about the compression test. Maybe it's different on a TD, but on an MGA, that switch still has posts sticking out. But I've never been fond of shorting them out anyway, as a bad connection can instantly damage the post.
Pretty clearly a starter problem, not much point in theorizing about it. But, they are usually a 4 pole design, meaning that if one brush quits making contact, the motor still turns just slowly. So I expect you'll find some combination of a sticking brush and/or wear making the armature not run true (so the brushes have to move to follow it).
If you don't want to disassemble it yourself, I'd say you have enough evidence to buy a new one.
NutmegCT
NutmegCT
I can handle checking and replacing brushes and brush springs if needed - I just don't look forward to removing the starter! You have to drop the entire exhaust line to get the starter out.
There a guy in town who's good at rebuilding starters and generators, if needed.
Today I'll try to check the brushes in situ, and maybe blow compressed air in there to see if that helps.
Thanks.
TM
NutmegCT
NutmegCT
Ground problem!
I ran a heavy cable from battery positive (ground) post straight down to chassis near starter.
Pulled starter knob, starter ran perfectly. Never slowed or stopped until I released starter knob.
To me that's a ground problem. According to Moss TD catalogue, there's supposed to be a ground cable (part #31) from chassis to gearbox, but I can't find one down there. Once I figure out if the cable is really missing and where exactly where it should be connected at each end, I'll get one from Moss.
Thanks all for the suggestions.
Ground problem it was indeed.
Tom M.
JPSmit
glad you found it - always the easy things first!
Bill_S TR4/4A Failing Voltage Stabilizers Triumph 1
RickB HG failing again, A15 in my Midget Spridgets 19
jdubois Hey, at least she kept failing in style! Triumph 6
mlarnoldTR6 TR6 TR6 brakes failing Triumph 12
Woodie failing condensor symptoms Spridgets 28
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
R TR6 Starter Solenoid Conection Triumph 11
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
N TR5/TR250 Starter Box Assembly Leak Triumph 14
P TR2/3/3A British High Torque starter Triumph 6
W General Tech 2500S starter motor and fuse box questions Triumph 3
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
M High-Torque Starter Austin Healey 10
W Generator and Starter Long Bolts Spridgets 0
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
R Bugeye Starter Switch Spridgets 7
B General MG Remote Starter Switch MG 6
S MGB MGB Starter Woes MG 13
M TR6 Starter Relay on a 73 TR6?? Triumph 22
edkap2002 TR6 starter motor advice Triumph 12
algot1901 1950 Prefect starter Other British Cars 1
Martinld123 High-Torque Starter Austin Healey 4
R TR6 Starter wiring question Triumph 6
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
B TR4/4A High Torque Starter Wiring Triumph 9
algot1901 1950 Prefect Starter Other British Cars 10
S Starter Solenoid Nut Size for BJ8 Austin Healey 1
B High-Torque Starter Rattling Noise Austin Healey 3
EWD TR6 ‘74 TR6 Starter & Trans Cover Triumph 13
Jim_Stevens TR2/3/3A Starter/ring gear engagement Triumph 11
J TR6 72 TR6 starter problem Triumph 10
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
C MGA Change a pull starter to a push button system MG 6
Michael Oritt Starter Button Austin Healey 19
D WOSP Starter Austin Healey 9
DrEntropy MGB Replacement starter MG 7
steveg TR6 '74 - Where is the Starter Relay located? Triumph 1
AUSMHLY Crankshaft Starter Nut Austin Healey 10
K For Sale Triumph TR3 Bullnose Starter Triumph Classifieds 0
B TR4/4A Starter dog bolt Triumph 15
D Starter Austin Healey 26
red57 What starter is this? Austin Healey 6
S TR2/3/3A Correct Starter Triumph 4
Jim_Stevens TR2/3/3A No Ignition light and no starter Triumph 11
R TR6 Is this a starter issue? Triumph 6
Got_All_4 TR2/3/3A Gear reduction starter problems Triumph 5
