TR2/3/3A Fabricating inner sills?
wifegonnakillme
I'm in the middle of looking at inner sills for my '56 and after looking costs tied to shipping and exchange rates here in Canada, it struck me that these are pretty simple parts... has anyone tried fabricating?
I realize the length and maybe gauge is too much for most home shops, including mine, but if one could have the simple bends done commercially for each half and reuse the bracket for the floor, it might be worth it(?)
Cost delivered for 2 inner and 2 outer sills is around $700CAD...
Thanks,
Kerry
bobhustead
My TRF inner sills (bought about 6 years ago, dunno about quality now) were so poor a fit I junked them. I used 1x3 rectangular tube (fabbed from 1x1 and 1x2). Front and rear angles and length were taken off from the assembled tub. Mounting ears were fabbed and mounted using dimensions taken off originals. Wasn't too hard. By assembled tub, I mounted the front and rear halves on the frame temporarily to do the measurements.
Bob
charleyf
About two years ago TRF started producing their own sills. That would be as opposed to the older units that were a poor fit. Last year I used two of the newer sills. I found them to be good quality with a good fit. I would recommend them.
I had used a sill about 10 years ago and also had fitment problems with it. I do not remember who I bought that sill from.
Charley
W
wifegonnakillme
Thanks Folks,
I already had a note into rimmer, it will be the shipping that decides it, might be the best option - the US exchange at the moment is not favorable for Canadian destinations.
At the same time though, I will look into finding a local fabricator, might be fun to try and maybe cost effective, if I fab, I will post pics,
Cheers,
Kerry
TomMull
I removed one of the aftermarket sills, fortunately before it was all welded up, and replaced it with one of the newer TRF sills because the fit was so bad on the first one. The fit on the new expensive TRF sill was better but still no perfect. I don't know why these things have been so troublesome. I don't know about Rimmer's sills, perhaps they are better.
I agree also that they could be made quite easily in a decent shop. However, I've not found the shops to be very enthusiastic about helping with DIY projects and expensive if you can get them to do it. Perhaps better luck in Calgary.
Tom
charleyf
Tom,
The misfit of the new TRF sills I used I believe was primarily due to the abuse my car body has had over the years. I had to repair damage to the body and frame from a left front impact and roll over. The earlier sills that I used and were not a good fit. In particular they were off on the height of the floor attachment brace. I found the new TRF sills to be good there plus the notching for the A and B post attachment areas was very helpful. One problem I had was the front lip attachment to the firewall. This was very easily worked around.
Charley
W
wifegonnakillme
I think I am headed there. KAS came back $100 (CAD) cheaper than the UK, but still $600 for inner sills and rocker.
Am waiting to hear back from a couple of shops that have brakes long enough to bend the steel, failing that I may take Bob's approach of stacking tubular steel...
Thanks,
Kerry
TomMull
Tom,
Charley
Another issue I had was that the box section made by welding the two halves together was nearly 1/4 inch wider than original. Something to keep in mind when fabricating, if you go that route.
Tom
W
wifegonnakillme
Hi Tom,
I was actually thinking last night that if I could get the metal bent for a decent price, I could use the "savings" to go pick up a $250 spot welder - never used one before, but was thinking that could help control the overall thickness.
Kerry
TomMull
Hi Tom,
Kerry
Yes, the spot welder will make a nearly perfect job of welding things together. I was never much of a plug weld fan, although I use them wherever I can't get to both sides or can't fit the welder in. I got an old ARO welder on eBay many years ago. It's 220 and quite powerful. Timer doesn't work but I can live with that. I made a bunch of tongs, the longest 18 inches, from copper rod, also from eBay.
Tom
Edit:
Of course you could always mig weld them and you might have to mig the floors, outer sills and all to the inners anyway.
malbaby
Another consideration if you want perfect alignment of front and rear guards/fenders and doors to the outer sills.....temp fit the fenders and doors before you do the final weld in of the outer sills.
You may also have to modify the outer sill where the fenders/sill overlap.
CJD
I have followed this thread...waiting to see where it goes. I am always a "do it myself" kinda guy, but the inner sill is a very critical part. It essentially ties all parts of the body to the frame, and it has at least a dozen interfaces that can go wrong. I have no doubt it can be done home made. Just make sure you understand what every bend and seam relates too on the body. None of them can be "TLAR'd"!
W
wifegonnakillme
I (finally) heard back from one of the fabrication shops - 20-30$ for steel, $150 for labor to fold and another $150 if I want them to weld it.
I was, since I love tools, planning on buying a princess auto (our harbor freight) spot welder for $250, but its capacity is a combined thickness of 1/8 inch; if I go with 12 gauge, that's 7/64 per side - almost twice as thick as it can handle. Sooo, I am going to poke around for a little while to see if I can find a heavy duty spot welder - more to come...
As a side note, my car is missing the rear support brackets (looks like they were cut away) and on closer inspection of the front ones, they are pretty rough, so I will make these at home too.
Cheers,
Kerry
Edit - after looking around, I am not optimistic I can find a powerful enough spot welder - posted a wanted ad here in Calgary, but the larger units seem few and far between or are huge $$ industrial units...
TomMull
Cheers,
Kerry
I'm quite sure the originals were made from 18 gage and the replacement from the same. How did you arrive at 12 gage? If you make thym from 18 the 220 spot welders should do the trick.
Tom
M_Pied_Lourd
I probably have a cross section of the sill out in the garage if someone wants me to check the thickness...just let me know and I'll dig it out. I'm going to guess 16 guage.
Cheers,
Tush
PAUL161 T-Series New heater lines [Fabricating] MG 7
T TR4/4A Fabricating a metal panel in between the fuel tank and cockpit Triumph 6
J TR2/3/3A Fabricating TR3 trunk panel,looking for photo help Triumph 16
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
D TR4/4A TR4 inner ball joints Triumph 8
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
SNClocks Gap between inner and outer fenders Spridgets 0
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
M TR2/3/3A TR3 Small Mouth Inner Fender Holes Triumph 3
J Wanted WTB Triumph TR3 inner sills Triumph Classifieds 8
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
M BJ8 Inner Body Panel Repair Austin Healey 2
chicken Inner Door Seal Trim Position Austin Healey 6
S Inner Body Alignment Austin Healey 0
G 1962 TR3A inner plate # Triumph 8
rr64 Wanted Early MGB Inner Steering Track Rods Wanted MG Classifieds 1
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
F TR2/3/3A Inner sill opinion Triumph 38
K TR2/3/3A Inner tie rod ball joint. Triumph 6
M TR2/3/3A Front Inner Fender Doublers Triumph 2
J TR2/3/3A Body Restoration - Inner Sill Replacement Triumph 38
J TR2/3/3A inner sill rust prevention Triumph 1
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
J TR2/3/3A Inner sill replacement procedure ? Triumph 5
F TR2/3/3A Front inner wing baffle measurement Triumph 7
wangdango BJ8 inner battery hold down? Austin Healey 4
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
Got_All_4 TR2/3/3A Inner tie rod ends Triumph 4
F TR2/3/3A Question: front inner wings Triumph 11
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
M For Sale 2006 Aston Martin DB9 - Get in Touch with your Inner James Bond Other British Classifieds 2
G TR4/4A Inner Door Reassembly Questions Triumph 4
aero3113 Front Hub Inner Bearing Seal Austin Healey 7
Feathers 289I inner tie rod end. TVR 0
D TR4/4A inner tie rod ball joint tension Triumph 0
F TR4/4A TR4 inner and outer sills Triumph 2
chicken Healey BJ7 inner door panel fit Austin Healey 7
R TR2/3/3A Inner sils replacement Triumph 20
KVH General TR Pressing in the lower/inner control arm bushings Triumph 3
Rut TR4/4A Inner frame coating Triumph 6
B TR2/3/3A Inner wishbone bushings Triumph 5
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
T TR4/4A Removing wiper motor - inner cable Triumph 4
W Inner Tie Rod Spridgets 3
M Choosing the proper inner tube Spridgets 6
M TR4/4A Replacing inner furrey window glass seals. Triumph 4
charleyf TR6 Plate on drivers side front inner fender Triumph 6
S door glass inner seal Austin Healey 6
