TR2/3/3A Inner sill replacement procedure ?
JeffW
I could use some advice on how to proceed with the replacement of The inner sill and the floors along with the rusted out parts that can be seen in my pictures. I plan to make repair panels to patch the rotted areas.From what I have read here the A post is spot welded along the outside onto the Inner sill.
Where are the spot welds that attach the B post to the sill?
Do I need to remove the rear quarter panel?
I'm thinking that my plan of attack should be to remove all the rusted out Sill along with the outside edge of the floor which should allow me to fit the new sill in place and get it bolted down. Once I have that in place I would plan to remove the rest of the floor and position that. Finally I would make the patch panels and weld them in there correct position relative to the new floor and sill.
I would appreciate some advice as to if I'm heading in the right direction with my plan.
Thanks Jeff
M_Pied_Lourd
Yes, unfortunately you will need to cut an access panel in the bottom of the b post dogleg to get to the internal structure of the b post. You will then see where this attaches to the inner sill.
You can get an idea of what it looks like in my video here
https://youtu.be/V-0BE5Nno_Y
Cheers
Tush
sp53
I would get some measurements of the rough opening of the door at the top and bottom with clear reference points, the exact hole size, and then brace it with some something, but have the number also. Do one side at a time. Maybe Save the lip in the front kick panel at least for now or maybe for the whole project, so if you want, you can run some screws through it or clamp to it while you set new sill and floor. The line in the fold that goes down onto the inner sill is probably very close even with the waves; I bet it is straight and will help you line the sill and set the end. I did it that way so everything is not floating in the air. I would cut the A post free with a cutting wheel and die grinder.
The B post area sheet metal is probably very thin judging from the back. Can you sandblast that area around the B post to see what it looks like? Or very gently grind the paint off? Or even hand sand because chances are you will have to do what Tush did.
steve
M_Pied_Lourd
Whatever you do, make sure that after you tack or clamp the sill in where you think it needs to be, fit the door/front fender up to do a fit check before you weld it solid.
Cheers
Tush
J
JeffW
Thanks Steve, I'll be taking some measurements this weekend before I do any cutting. I have it pretty well braced but the measurements will be insurance for any movement. The bottom of the B pillar has some rust as does the bottom of the wheel arch. I think I will do as Tush did and cut out a piece for access and removal of the rusted part of the arch and replace with a new metal patch.
Thanks for the suggestions.
Jeff
J TR2/3/3A Body Restoration - Inner Sill Replacement Triumph 38
B TR2/3/3A Need advice TR3b inner sill replacement Triumph 16
M_Pied_Lourd TR2/3/3A TR3A Inner Sill Replacement Advice Triumph 7
T TR4/4A TR4/6 inner sill replacement - body on/off frame Triumph 1
Jim_Stevens For Sale New TR2-3A inner sill assemblies Triumph Classifieds 3
F TR2/3/3A Inner sill opinion Triumph 38
J TR2/3/3A inner sill rust prevention Triumph 1
71TR6 TR2/3/3A Inner sill or floor pan- which to replace first? Triumph 5
Scot1966 For Sale New TR6 / TR4 passenger side rocker panel & inner sill -FREE- Triumph Classifieds 2
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
K Link to pic of 4 inner sill install without floor? Triumph 0
W Inner sill panels Spridgets 3
M_Pied_Lourd TR2/3/3A TR3A Help with Resto Pics Please Front Inner Sill Triumph 19
O TR2/3/3A Help with TR3 inner sill removal - blind welds? Triumph 5
ekamm welding tr3a inner sill Restoration & Tools 2
M_Pied_Lourd TR2/3/3A TR3A Inner Sill Repair Question/Advice Triumph 95
K TR4/4A TR4A :Anyone have a pic of inner sill in place.... Triumph 2
F Inner rocker [sill] panels Spridgets 11
A TR6 TR6 B-post to inner sill connection Triumph 3
tr6web Outer and inner sill [rocker] installation Triumph 5
R Inner Sill, Which way ? Spridgets 2
J TR4/4A Strange Problem Fitting Inner Fender Triumph 18
D TR4/4A TR4 inner ball joints Triumph 8
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
SNClocks Gap between inner and outer fenders Spridgets 0
S TR2/3/3A Distributor vacuum advance hook up to the inner plate Triumph 9
M TR2/3/3A TR3 Small Mouth Inner Fender Holes Triumph 3
J Wanted WTB Triumph TR3 inner sills Triumph Classifieds 8
R GT6 GT6 Bearing Part Number Request (Front Axle, Inner Bearing)... Triumph 3
M BJ8 Inner Body Panel Repair Austin Healey 2
chicken Inner Door Seal Trim Position Austin Healey 6
S Inner Body Alignment Austin Healey 0
G 1962 TR3A inner plate # Triumph 8
rr64 Wanted Early MGB Inner Steering Track Rods Wanted MG Classifieds 1
K TR2/3/3A Inner tie rod ball joint. Triumph 6
M TR2/3/3A Front Inner Fender Doublers Triumph 2
F TR2/3/3A Front inner wing baffle measurement Triumph 7
wangdango BJ8 inner battery hold down? Austin Healey 4
K TR2/3/3A Front suspension inner Lower wishbone bush area? Triumph 3
Got_All_4 TR2/3/3A Inner tie rod ends Triumph 4
F TR2/3/3A Question: front inner wings Triumph 11
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
T TR2/3/3A Drive end of speedo inner cable to large for pinion Triumph 2
M For Sale 2006 Aston Martin DB9 - Get in Touch with your Inner James Bond Other British Classifieds 2
G TR4/4A Inner Door Reassembly Questions Triumph 4
aero3113 Front Hub Inner Bearing Seal Austin Healey 7
Feathers 289I inner tie rod end. TVR 0
D TR4/4A inner tie rod ball joint tension Triumph 0
F TR4/4A TR4 inner and outer sills Triumph 2
W TR2/3/3A Fabricating inner sills? Triumph 39
