alphatopher
Member
I'm in the process of installing new floor pans but I need to first address the lowest section of the b-post where it connects to the inner sill. The outer sill and floor pan have already been removed. I don't know if this was original or not, but this connection between the inner wheel well, b-post, and inner sill was packed with some kind of putty to prevent water intrusion from the wheelwell. Well the putty failed and resulting in rust in this pocket requiring the replacement of the lowest section of the B-post and some of the inner sill.
Should I patch weld the post as best I can then pack it with putty, or would it be better to re-engineer by welding a more effective joint which would drain water rather than collecting it. Any ideas would be appreciated, what have you all done to fix this area.
Also, how do you determine what is an acceptable amount of rust on the B-post seat belt nut? The nut isn't rusted but there is rust of the reinforcement plate that the nut is connected to. My plan was to remove the scaling rust then POR 15 it.
