TR4/4A Engine Issues Again--I'm Hearing Things
KVH
It seems I regularly have the opportunity around here to show my age and declining state of mind. Here we go again:
My 4A is finally running well, and fairly smooth. However, when at operating temperature, and while idling, there is a sound coming from the engine reminiscent of a whirring cooling fan. I have such a fan on my other vehicle (also a 4A) but none on this car. The sound is coming from the upper part of the engine, maybe the valve cover. It's not a pinging, clicking or ringing sound. But more like the whirr of a fan or jet engine.
Any ideas of things not inside the confines of my mind?
TomMull
Generator? Water pump? Use a long screw driver as a stethoscope (or a stethoscope). Tom
texbears3
Dont' rule out the tensioner for the time chain. Use your stethoscope on the chain cover. Two have briken on my 4A over the years. One time is pierced the chain cover.
Geo Hahn
Easy enough to rule in / rule out the generator & water pump -- just run it briefly w/o the belt and see if the sound goes away.
I agree it could be the tensioner - did have a sort of whirring noise when it was broken and touching a stethoscope to the timing chain cover removed all doubt.
GTP1960
I was having a hard time tracking down an intermittent chirping noise that sounded something like a circular saw slightly connecting with the side of a cut.
turned out it was a harmonic vibration caused by the carburetor heat shield at certain idle speeds.
the intermittent nature of these things is the challenge. Hard to recreate the event on your terms.
M 1972 Midget Engine Issues Spridgets 10
J TR2/3/3A 60 TR3A serious engine vaccuum issues Triumph 2
Tim_Creger MGB Need help diagnosing MGB engine issues MG 24
T Issues with re-bushing suspension w/out engine Triumph 11
Brosky Anyone heard from Bill about engine issues? Triumph 7
V TR4/4A Anyone in NY have some TR4 engine issues?!? Triumph 0
S engine swap issues Spridgets 25
Bret More stuff on V6 & V8 Engine swaps "Emissions" issues MG 2
mctriumph For Sale Tr7 engine Triumph Classifieds 0
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
CARSINC WANTED: 1275 Engine Spridgets 0
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
D A distributer question on the 1275 engine. Spridgets 7
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
