Early 3000
Looked at an early 3000 yesterday. Did they ever come with a ridged hood. Hood looks correct to car by the paint under neath hood matching inside of engine bay. I though the car was going to be a 100/6 when I saw the hood but owner says car is all correct. It needs restoration but sheetmetal is pretty decent.
Marv
elrey
Anderson and Moment make the claim that "Hoods with the crease were almost certainly never used on 3000's." They state that during the production of the last 100-Sixes hoods were intermingled creased and not creased.
bighealeysource
Bronze
Hey Marv,
The hood with the crease was not produced for the 3000's according to Anderson/Moment and no record exists to show when they stopped being used on the 100-6's. Anders Clausager says the same thing, that no creased hoods were used on the 3000. The car you looked at probably had a creased hood put on sometime in the past and no way to know when or why. But the experts say not original.
Good luck with it,
Mike
Duane_Rhynard
Marv,
The records were not kept well in those days, and while unlikely that the ridged hood is original, it is possible on a very early 3000. (See link below.)
When you read the Concours guide, (Roger Moment and group) they are always updating the guide with newly discovered information.
https://www.healeysix.net/BN7 & BT7.htm
Duane
'58 BN6
elrey
Marvin, the body number on the hood is stamped into the outside of the left side hinge bracket, roughly centered between the hinge bolt holes. The body number is also stamped into the hood latch bracket. The body number on the boot lid is stamped into the lower side of the prop rod bracket on the left side of the boot lid, visible when you open the boot.
Marvin Gruber
I didn't get to look that long at the car. Owner has some medical issues and is not sure what he is going to do with the car. I figure I will get another chance to inspect, wanted to have more info about the car. I had been told that Healey used up all their parts (like Triumph)when ending up a model. It does have the early style (like 100/6)grill. I forgot about numbers stamped on body parts. I will remember that for the next time. I like the ridged hood but if its not correct then it will have to go if I get the car.
Marv
Bob Claffie
Marv, you might get a clue on just how early a car it is. The earliest 3000's (which used the 100/6 grille DID NOT HAVE DUST SHIELDS on the disc brakes. I don't know how long that lasted but the 3000 I bought in May 1959 had no dust shields. Too bad I can't remember the hood configuration. Bob
davidb
The Healey Restoration Guide (Anderson/Moment) also suggets that "the first hoods installed on the BN4 had an internal brace welded across the rear at the hinge points, but did not have a brace across the front of the hood, and had a styling crease running from then grille opening to the rear of the hood..."
So if your hood doesn't have a brace across the front of the hood, it is likely a replacement hood from a '57 or '58 model
The Guide goes on to say that "Subsequently, hoods were produced with both braces but without the crease..."
Personally I like the crease, if originality is not an issue. They're quite rare, and you can always pick up a correct hood on eBay for a couple of hundred dollars.
On the other hand, why would you put a 100/6 grille on a 3000? Is the grille surround from a 100/6 as well, or just the grille itself?
Sounds like a "Bitsa" - bitsa this, bitsa that..
Cheers
DB
elrey
David, BOTH the 100/6's AND early 3000's shared the same three piece grill with the horizontal wavy bars. It was not until the advent of the Mark II 3000's that the two piece vertical barred grills came into play. These vertical barred grilles remained until Austin Healey ceased production entirely in March of 1968.
davidb
Elrey
You're absolutely right. For some reason I was thinking AH3000 BJ series. In fact, my neighbour has an early 3000 with the wavy horizontal grille. I have a later MK 2 with the vertical grille.
Anyhow thanks for pointing out my error. My mouth and brain are from different bodies, but it's all they had left. I have gone to my room with no dessert.
Cheers
DB
elrey
Just thought I'd clear it up. Don't miss desert on my account. :nonod: I also have a Mark II 3000 BT7, a side shift. :cheers:
Marvin Gruber
It may take a few weeks but I'll report my findings when I do. I need another Healey like I need another wife. Hope mine's not looking at this.
Marv
Pretty sure that in one (1) of Geoff Healey's books, he tells of a crate of ridged bonnets (hoods) being "discovered" and them being fitted to cars after the non-ribbed hoods were phased in. Those guys weren't going to waste anything that could still be used.
See what the body number stamp is, and base your next move on the results.
I'd look this up, but all my Healey books have already been packed up, waiting to be moved to their new location...
... operation: No More Offsite Storing of Cars!
1000SF attached garage (3-1/2+ car) & 1050 SF detached garage (6-car?/though machine tools, etc. will take up some floor space). Planning on doing a two-post lift in each garage.
B Austin-Healey early 3000 BJ8 Electrical Diagram Austin Healey 0
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
Patrick67BJ8 Early 3000 vs BJ8 vin Austin Healey 3
BoyRacer Best street tires for early 3000? Austin Healey 21
5 Headers for BN4/early 3000 Austin Healey 10
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
drooartz Early 60's Bentley S3, maintainable? Other British Cars 13
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
V MGB Replace late intake manifold angled breather with early model straight? MG 1
Racer-X- Looking for old parts catalog(ue)s with listings/part numbers for early 1960s Vanden Plas 4 Litre Princess Restoration & Tools 3
S TR2/3/3A early tr3 and tr2 kick panels Triumph 3
S TR2/3/3A TR2 and early TR3 wipers Triumph 7
9 TR5/TR250 What is this? Appears to be aluminum fuel cap for TR250 and early TR6 Triumph 13
drooartz MGB Early tail lights on later car MG 17
T Wanted: Early BN1 Sidescreens Austin Healey 2
S TR2/3/3A Rebuilding the early tr3 starter Triumph 5
R For Sale Original AC Ace/Cobra seats. Early 60's, hand made Leveroll by A.W. Chapman, London Other British Classifieds 12
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
J Early BJ8 Armrest Latch Austin Healey 2
Boink Early Mini Fuel Gauge - adjusting it British Motor Corp 0
A Early 1967 AH Sprite - installing steering column and new directional switch? Spridgets 0
A TR2/3/3A Early TR3 starter (bomb style) bushings sizes Triumph 7
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
T Early BJ7 Vent Window Seal Austin Healey 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
Twit TR4/4A early tr4 check straps Triumph 4
oldbagpipe Wanted Early TR4 Silver [Aluminum] Dash Cluster Triumph Classifieds 1
rr64 Wanted Early MGB Inner Steering Track Rods Wanted MG Classifieds 1
oldbagpipe Located Early TR4 Glove Box Hinges Triumph Classifieds 0
PAUL161 MGB Early B Banjo Rear Gears MG 2
R TR4/4A Early TR4 seat pans Triumph 26
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
HealeyRick Early Healey History Austin Healey 2
red57 Wanted WTB Early Austin Healey Horns Austin Healey Classifieds 1
K MG Midget Early and Later model rear brake shoes.... Spridgets 2
oldbagpipe For Sale Early 1969 TR6 'Stalled Project' $4500 Triumph Classifieds 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
J For Sale Early 70s TR6 seats in new red vinyl, with new tracks, $500 OBO Triumph Classifieds 0
oldbagpipe For Sale Early 1969 TR6 Project for sale Triumph Classifieds 10
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
M Old English White Paint Code for early BE Spridgets 1
B Side window question for early Longbridge BN4 Austin Healey 4
M MGB Early MGB engine compatible with later transmission MG 2
