E type steering
davidtinker
Member
There has been some discussion on various lists about the e type steering and its tendency to have a mind of its own when cornering due mainly to the metallastic rack mounting bushes even if they are in good condition. When at the 40th E type anniversary in June I spoke to someone who had a car factory fitted ( he said ) with bushes which were placed underneath the security washers ( through the large hole in the rack mount plate) which limited the amount of movement in the flexible bushes. I have made this modification and am very pleased with the result. No need to fit rigid rack mounts.
Administrator
Boss
That sounds like a good and (cheaper) alternative. As it happens, I just recently rebuilt my front end and did use the solid Alumnimum rack mounts. Will be a while yet before I get it on the road to see how it feels. I also used the red Poly-bushes in place of the softer rubber ones that came stock.
D E-Type steering wheel Jaguar 6
TRMark TR4/4A Strengthening early type TR4 steering rack mounts Triumph 4
V 65 E-Type Steering Column Adjustment Jaguar 2
V E-Type Steering Column Adjustment Jaguar 4
bighealeysource Steering box oil - type ? Austin Healey 3
Jagboy69 E-type Series II Power Steering Pump Jaguar 0
toysrrus Orig. E-Type Steering Wheel For Sale: Jaguar 5
D E Type S1 1966 2+2 4.2L steering column Jaguar 8
S S-Type Squeakey Steering Jaguar 11
B E-Type steering rack boots Jaguar 2
H MK2 lover, but... what about an E type? Jaguar 5
D TR2/3/3A layout for lap type seat belt Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
71TR6 TR6 Type-J Overdrive identification Triumph 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
T TR2/3/3A A type overdrive hard engagement Triumph 36
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
R TR6 J-Type overdrive will not disengage when warm Triumph 8
6 E-Type brake light pressure switch location Jaguar 5
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
V vintage glue type for veneer? Sunbeam (Rootes) 13
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
S TR2/3/3A lifter type Triumph 3
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
M TR6 1973 TR6 Coolant Type? Triumph 5
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Basil The new Kia E-Type? Jaguar 6
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
I GT6 A type OD vs D type - engagement speed? Triumph 3
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
