E-type hood reassembly
MikeP
When I took my hood apart to clean, repair and repaint I noticed that most of the bonded on flanges were loose. I went ahead and removed them since I figured I'd need to rebond them anyway, and it allowed me to clean the surface rust under them. Now that I'm getting close to reassembly, anyone have any suggestions on what to use to reattach them to the hood center section?
LarryK
Hood (USA) or Bonnet (Eng) or Hood (Eng) or Top (USA)? If you are talking about the bonnet assembly, did you notice any kind of tach welds on the flanges? I don't remember any adhesives back then for assembly.
Roger
Bronze
Tach (USA) or Rev-Counter (Eng)?
Or maybe Tack?
Sorry, couldn't resist!
M
MikeP
OK, bonnet....
On my 3.8 E the flanges attached to the fenders for the rear wheel well panel are spot weleded on. All the flanges on the center section were bonded on. Not flush to the center but with a bead perhaps 1/32 to 1/16 thick. appears to be original, I've have the car 25 years and it doesn't seem to have been apart before. I've also see others at shows that have this feature.
jessebogan
Why not contact a body shop supply house and get some structural adhesive. I know that there are different cure times as well as different strengths. I would talk to a salesman that should know the differences, and could recommend the correct product for that use. One thing I am sure of, the stuff now will be a whole lot better than what Jaguar used. I think that the "glue" might be a great way to install repair panels on cars. No welding, and should be easier to completely rustproof the repair. Good Luck
I used a two part epoxy when I redid the bonnet on my 68 XKE. Thats been almost 10 years ago and its still holding. No signs of cracking or loose panels.
Marv
Platinum
SEM makes some stuff called "Multi-purpose Panel Adhesive". Great stuff.
H MK2 lover, but... what about an E type? Jaguar 5
D TR2/3/3A layout for lap type seat belt Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
71TR6 TR6 Type-J Overdrive identification Triumph 4
B Thread Type and Size of BN2 Intake/Exhaust Studs Austin Healey 0
Editor_Reid V-12 E-Type Body Number Location Jaguar 3
M For Sale 2017 Jaguar F-TYPE Premium 2-Door Convertible for Sale mlbirk@aol.com Jaguar Classifieds 0
K TR2/3/3A The Amco chrome tube type grille ....... Triumph 9
T TR2/3/3A A type overdrive hard engagement Triumph 36
S TR2/3/3A Wedge type and Dzus type side- curtains Triumph 1
R TR6 J-Type overdrive will not disengage when warm Triumph 8
6 E-Type brake light pressure switch location Jaguar 5
A SOLD!! TR3A Girling Type A brake caliper for right front Triumph Classifieds 0
M Front caliper rebuild 1970 Series 2 E-Type Jaguar 0
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
ROARRR Is there any problem swopping in a 3.0 in place of the 2.5 L engine in my Jag X Type? Jaguar 0
M General TR Source for J Type O/D Solenoid Circlip Triumph 0
M Wanted Wanted: Inoperative J Type OD Solenoid! Triumph Classifieds 2
V vintage glue type for veneer? Sunbeam (Rootes) 13
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
M TR6 Gear Oil Type and how to add 1973 TR6 Triumph 9
Basil Remember the Royal Electric E-Type Electric Upgrades of All Sizes 0
S TR2/3/3A lifter type Triumph 3
1 TR2/3/3A TR3 Fuel Pump Thread Type? Triumph 4
RonC TR2/3/3A J Type Overdrive in TR3A Triumph 4
M TR6 1973 TR6 Coolant Type? Triumph 5
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
S TR2/3/3A 187 NOS sleeved type thermostat Triumph 16
Basil The new Kia E-Type? Jaguar 6
H TR4/4A A-type overdrive pump Triumph 4
Got_All_4 TR6 Refurbishing gearbox with A type overdrive Triumph 7
P Wanted E type spare tire bracket Jaguar Classifieds 2
P Wanted 62 E Type spare tire bracket Other British Classifieds 1
Got_All_4 TR6 Routing Speedo cable for a J type tranny in my TR250 Triumph 4
Got_All_4 TR5/TR250 Trying to figure out rear transmission mount with a J type tranny Triumph 9
I GT6 A type OD vs D type - engagement speed? Triumph 3
J For Sale Jaguar E Type and MK2 spares Jaguar Classifieds 0
VooDooDaddy63 Basic E-Type Question: Fasteners - Metric or SAE or ...? Jaguar 15
D TR2/3/3A Type A overdrive not engaging Triumph 0
D TR2/3/3A Type A overdrive not engaging Triumph 16
S For Sale Lotus Elan Factory Workshop Manual on CD/ROM - Type 26 - 1963 - 1965 Other British Classifieds 1
B Resistor type vs non-resistor type spark plugs for 100-6 Austin Healey 17
K TR4/4A TR4 Fuel Gauge'"light bulb socket" type? Triumph 11
Martinld123 H Type Carburetors BN2 M version Leaking Fuel At Jet Bearing Area Austin Healey 18
AH67 Heat Shield finish 66 Type Jaguar 5
AUSMHLY Grease type for zerk fittings Austin Healey 7
M TR4/4A A type Overdrive Oil Leak Fix Triumph 3
M 5-speed, 1968, 4.2, E-Type, OTS Jaguar 3
