TR4/4A Dropping the Engine and Transmission Back onto the Mounts
KVH
Can I slide the motor and transmission back into the car, and onto the mounts, together, engine bolted to transmission, with the transmission cover still on, or must I remove that cover? I noted reference in my manual to removal of the transmission cover. I thought that removal of the shift lever, however, should be enough. Please let me know how you feel about it. thx
TomMull
I've never tried it withe the cover on but I'm quite sure it's possible. It does come off quite easily and I would remove it. It really increases wiggle room. Tom
charleyf
I don't like messing with removing the tranny tunnel and the dash support. However, I would always take it off to remove or replace the tranny and engine. I am thinking that you will have a major hassle with the rear mounting bolts for the tranny but even more for the driveline bolts.
Charley
KVH
KVH
If I remove the cover, must I drain all the gear oil? I can't recall how high up the fluid level comes in the gearbox. I have a Type A Overdrive (Laycock) as well.
charleyf
I do not believe so. The oil level is a bit over the mid level of the tranny. It sure is a convenient time to change and refill the tranny.
Charley
sp53
You can make a temp trans cover with some tinfoil and string-- sometimes it better to put the mounts on the engine and the slip the package in to place then bolts the mount to the frame because the studs sticks up.
SteveBones
When I restored my TR4, I pulled out and later put back in the engine and transmission with the trans cover. (I actually had to do this a couple of times so I know it works). I did remove the gearshift lever. I installed the eng/trans with the help of another person. The engine hoist that I rented also came with a chain that included fasteners that bolted onto the engine head bolts. The hook on the hoist itself was placed on the chain so that the engine and transmission would be tilted when raised. This allowed the tail end of the transmission to be lower that the front of the engine. One of us moved and slowly lowered the hoist while the other person guided the transmission by grabbing the tail end where the drive shaft bolts on. I hope this helps.
Geo Hahn
I'm so confused... are we talking about the cover on the gearbox or the tunnel in the car? Sounds like both depending on whose talking.
KVH
KVH
The actual 8 bolt shifter cover of the transmission itself. Not the interior tunnel cover. The manual must assume that the extra two or three inches is important. They figured folks like me would bend up the firewall and accelerator shaft and make a royal mess. Maybe they're right.
charleyf
Sorry I was confused as well. I was believing that you were referring to the tunnel. I have ALWAYS LEFT THE TOP ON THE TRANSMISSION. The clearance issues come from the top of the bell housing and the fire wall. I do remove the gear shift and attached pieces.
Charley
KVH
KVH
I just wasted 3 hours trying the get the engine and transmission into my 4A, doing it all in one piece. No way. The oil pan kept hitting the frame member; the bell housing hit the accelerator rod, the front plate wouldn't meet the mounts; the engine hoist wouldn't reach far enough and kept hitting my front bumper. Tomorrow, the engine goes in first, then I'll horse my transmission in from the interior, and all will be well by the weekend.
Just put engine/trans back in a TR4a on Saturday. For TR4s I always remove the top of trans. I also had carbs and exhuast manifolds on on engine. I only use short chain and let it slip in hoist hook as I need to tilt engine. I also remove rear trans mount as well. Takes about ten minutes by myself to set in. I use a 2x4 under tail shaft to hold it up (once I have the engine on mounts) to set the the rear trans mount back in place.
marv
Mink
Did mine recently and don't recall any drama. My accelerator shaft was out but other than that it just popped right in. I had a friend helping guide it.
glemon
I never thought to take the top cover off the tranny, when I first started reading it I also thought the reference was to the fiberboard or plastic transmission cover. I suppose it would give more clearance. There is always something more to learn I guess.
Mink
Yep, that's what they are referring to in the procedure, not the tunnel cover (that's a separate step).
KVH
KVH
Mine is in now. All as one piece, after all. Another 3 hours, but that was all by my lonesome, under the car, back up, down under, over and over again. Issues for me were the height of the transmission overdrive tail under the car, the clutch rod "zerc" filling hitting the floor board, the accelerator shaft connecting link hitting the exhaust manifold (in addition to the shaft, itself, hitting the engine and bell housing), the angle of the drop possible with my AC Delco leveling arm (which I find quite cheap in quality, with shavings of the threaded rod spinning off, rod slipping and other issues), and the new alignment of my motor mounts due to now having a new (not bent) engine face. I also removed the front bumper and got three more inches (I see yours is off). But, yes, patience and determination, the right angle of descent, and I finally cleared the bottom cross member of the frame with the sump left intact, though I did bump it a bit hard on one too quick decent. It's all just experience, help, and patience and I sure lost the latter the first time.
Mink
Congrats!
Good point. Now that I think about it, even with the bumper off, the hoist was all the way up against the apron. It would definitely be tough to do with the bumper on and a standard engine hoist.
KVH
KVH
I've been here awhile so I know a few of you. And for that reason I corrected a spelling error above. I just want to head into the Holidays feeling proper.
I have an overhead rail hoist which gives me a little more space. Bet you will admit, if you have to do again, you will be able to do in half the time.
Marv
Joe Reed MGB Dropping out of 3rd gear... MG 2
R Dropping the rear axle, help! Spridgets 5
theleisure Trouble Dropping Motor into Mounts Spridgets 14
T Dropping the Diff Triumph 20
Steve1970 Dropping gearbox to replace fork pin, need guide Triumph 70
W Dropping the price on my 3... Triumph 12
Aldwyn ING Light on, Volts Dropping Triumph 19
J carb piston keeps dropping... no vroom vroom Triumph 19
G T-Series Dropping the oil pan on my MGTD MG 1
mctriumph For Sale Tr7 engine Triumph Classifieds 2
mctriumph TR2/3/3A Weirdest engine failure Triumph 2
sim A-series Engine Block Search Spridgets 2
H "Failure to Proceed" (Engine Won't Fire) Austin Healey 9
L Engine ID British Motor Corp 4
J Can a TF engine be installed in a TD body? MG 7
K TR2/3/3A Coil against hot engine?.....relocating the coil? Triumph 11
C Engine Operating Temperature Austin Healey 21
tinman58 TR2/3/3A Por-15 in engine block? Triumph 12
W BN4 Engine Mounts Austin Healey 2
B MGB while driving engine cuts out if I let off or push more throttle it comes right back on MG 5
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
G TR2/3/3A TS37903F Is my engine a TR3A engine because my starter says no. Triumph 3
Frameman 1949 Engine Misfiring & Starter Cranks Slowly When Hot Austin Healey 8
B Engine Stalls When Warmed Up Austin Healey 6
HealeyPassion AH Project: Cool Air to Engine Austin Healey 5
R For Sale 100 engine block w/head Austin Healey Classifieds 3
R TR6 question re: Engine Oil Triumph 3
P General TR What color is original for engine parts? Triumph 7
AUSMHLY Clutch Stalls Engine Austin Healey 16
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
MikeAH100M High Temp Engine Miss Austin Healey 2
K TR2/3/3A Replacing engine and gearbox mounts? Triumph 8
KVH General Tech Engine Misses Only at 2200 rpm Triumph 12
J For Sale Hoist and engine stand Triumph Classifieds 0
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
Carlbanan56 MGB No spark and engine cranking slow MG 10
bigjones TR2/3/3A Starting up an engine that hasn't ran for a while. Triumph 39
tr6nitjulius General TR Waterless, easy/peasy, engine cleaning Triumph 2
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
SherpaPilot TR6 Engine Mounting Question Triumph 3
KVH General Tech Loud Metallic Click Pop Every Time After Engine Off Triumph 11
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
Joel Lester TR2/3/3A Priming new engine with oil Triumph 9
BoyRacer Austin A90 mystery engine British Motor Corp 2
