Disc brake rotors
Donny_L
I was thinking, since I already have the hubs off and bearings out that I should get the rotors cut while I'm at it. so once I get all this stuff put back together I wont have to put myself through it again anytime soon. My question is; is it ok to cut the rotors and if yes should I take the splined hub off the rotor before I bring them in ? Also Whats the specs on how thick it's supposed to be and still be safe to have them turned.? I couldn't find that info in my manual.
Brinkerhoff
Re: Disc break rotors
Donny, You want to leave the rotors on the hub and have the races for the bearings installed . The lathes use cones that center on the races so the rotor spins as true as it will be mounted on the car. Kevin
You may have a problem getting the rotors turned. In CA, at least, no reputable shop will turn rotors or drums without an official spec--I hear it's a criminal offense--and no one could find a spec for my drums. You may have a problem with your rotors, too.
I'd rather turn a good rotor, too, but new aren't terribly expensive (I bought a pair on sale for $50ea., and they were Brembo). Since you have everything apart--and if you do it right you probably won't have to do this again--I'd get new rotors, esp. if you're doing everything else.
On another note, next time I have my rotors off I'm going to tack weld the hub bolts to the rotor. That way, I can torque the nuts on the hub without the bolts turning.
BlueRidge1
Bob,
I'd advise against welding studs. I tack welded the studs on my race car to keep them from turning in the axel and every one of them broke during a practice run and the rear wheel broke off. I think the excessive heat made them brittle.
Bob G
Wow. Thanks for the tip. The later BJ8s use bolts--you think they'd have a problem, too? Doesn't seem like a little tack on the bolt head would cause a problem.
dougie
I have slotted and drilled front rotors plus Denis Welch vented and balanced rear drums on my BJ8 street car. I'm very happy with these up grades.
Donny_L
You got two of these babies!!! You R too cool for school. Where'd you get the rotors from. and why only on the street car and not the racer too?
Robert560
Donny_L said:
Does anyone have slotted brake rotors on there Healey?
Donny, I've got drilled and slotted rotors on my BJ8. Bought the ones that Moss sells, which are made by Disc Brakes Australia. I added them when I had to replace my brake servo. I'm using them with Classic Gold Premium Ceramic Pads. Otherwise I've got new stock calipers and a bunch of other new parts... but all just stock replacement stuff.
I honestly can't say for certain if the drilled/slotted rotors made things a whole lot better... because my brake system wasn't working quite right before the upgrade... but I can tell you that my Healey stops <span style="font-weight: bold">incredibly</span> well. Feels as good as any modern disc front/drum rear car - probably even better than many.
I upgraded the '68 Camaro I had before the Healey with a full blown 4 wheel disc brake setup, spending probably 5 times as much as what I invested in the Healey brakes... yet the Healey feels just as good. Go figure.
~Bob
dougie
I also purchased my slotted/drilled rotors through Moss and found the quality very good. Our vintage race regulations do not allow for this modern upgrade, but I do have 4-wheel discs which was homologated for racing on the big Healey.
F Disc Brake Shimming Austin Healey 8
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
kodpkd Disc Brake Pad Installation Austin Healey 11
BN6_L1232 Rear Disc Brake Installation Instructions Austin Healey 3
K TR2/3/3A Securing new brake disc to the front hub? Triumph 4
K Disc Brake Conversation to MK1 Midget Spridgets 2
I Bug eye front disc brake conversion. Spridgets 5
A Disc Brake pictures Austin Healey 1
A AH 3000 rear disc brake conversion Austin Healey 28
BJ8Healeys Disc brake piston seals Spridgets 2
Ohiobugeye Front brakes won't release after disc brake conversion Spridgets 10
K TR2/3/3A Brake disc? Triumph 19
NutmegCT Disc brake fun Other Cars 33
B Another disc brake question Spridgets 10
B Disc brake conversion Spridgets 12
K TR2/3/3A Front disc brake squeal.... Triumph 4
Jim_Gruber Steering Arms for BE Disc Brake Conversion Spridgets 1
T Disc brake conversion questions Spridgets 5
R BJ7 Front Brake disc hitting Austin Healey 12
bugedd Disc brake conversion Spridgets 7
jaegzie Disc brake upgrade was fine now major alignment issue. Spridgets 6
DanLewis Disc brake setup on eBay for $79+shipping [NFI] Spridgets 2
Lynn Kirkpatrick MGB Disc brake pads MG 4
tahoe healey disc brake anti squel pads Austin Healey 5
AHS TR2/3/3A Disc brake line routing Triumph 0
maxwedge5281 front disc brake hubs for steel wheels Austin Healey 24
C 100 Drum Brake Keep or upgrade to disc? Austin Healey 9
steveg First drive - Toyota 4-piston Disc Brake conversion Austin Healey 5
S Rear Disc Brake Conversion Austin Healey 9
J Disc Brake Conversion on Sprite Austin Healey 1
S rear disc brake conversions brackets Triumph 9
M BJ7 Rear Disc Brake Setup Austin Healey 7
I Disc brake question Austin Healey 1
drooartz My writeup on disc brake conversion Spridgets 14
K disc brake conversion Spridgets 11
M MGA MGA Disc Brake Axles? MG 2
K Disc brake conversion Spridgets 2
E Bugeye Disc Brake Conversion Spridgets 2
livinginthepast Disc brake conversion - soft pedal Spridgets 8
J How to install disc brake seals. Austin Healey 1
19_again GT6 disc brake piston removal GT6+ Triumph 8
B TR6 TR6 Disc Brake rattle Triumph 2
Trevor Jessie Front brake line locating brackets [disc]. Spridgets 6
B Disc Brake Parts List Spridgets 13
M BN4 prob with disc brake conversion[front] Austin Healey 2
Fortius Dennis Welch Rear Disc Brake Conversion Kit Austin Healey 2
drooartz Brake hard lines, drum vs disc Spridgets 2
BIBBER Disc Brake Conversion Restoration & Tools 7
G Disc brake rotor removal Spridgets 17
Thomas591 Disc Brake conversion to BN2 Austin Healey 5
