DC Power source thoughts
JPSmit
Well wide electrically experienced folk, here is tonight's thought.
I am shortly going to be reinstalling the wire harness on the Vauxhall. One thing I have long thought would be the benefit of having a variable DC power source - then I could test the circuits without either wearing out a battery or more to the point letting the smoke out of the wires. I can't imagine a lot of amperage would be needed but it would be nice to have a few things
1. variable voltage up to 12V
2. a variety of means of connecting wires including, possibly even battery posts, alligator clips or bullet connectors.
It should be easy to make with a DC transformer - though I am not sure if I could vary the voltage?
do such things exist or, could one make one economically?
thoughts?
TR3driver
Great Pumpkin - R.I.P
Rather than variable voltage, IMO what you really want is a current limiter. Current limited DC power supplies are readily available, tho perhaps more than you want to pay for a single use. But an ordinary car battery charger (rated 10 amps or so) will work quite well for most things (starters and horns are the two exceptions that come to mind).
Transformers only operate on AC, so the usual way of creating a "DC transformer" these days is to chop the DC into AC (generally at a fairly high frequency to reduce size and cost of the transformer) and then rectify the output back to DC. It can certainly be done in a variable fashion; but generally the chopper circuit is what gets varied. Variable AC transformers do exist, but usually are designed for 60 (or 50) Hz, making them big, heavy and expensive. Building your own is probably beyond most amateurs tho, unless you buy a kit. And all the kits I saw with a quick Google were only good for 2 or 3 amps, which won't be enough for many things on a car.
Another, more rudimentary approach is to just put something in series between the car and the battery, that will limit the current. An old headlight bulb works pretty well for devices that only draw a couple of amps, and you can parallel them for more current. (4 bulbs will limit to about 20 amps) Or automotive grade circuit breakers aren't too expensive either.
https://www.delcity.net/store/12V-A...KfiAJXjf96riq1elJyCeRmAk9OT2DyssBbBoCNpLw_wcB
Bayless
I think most of those older "transformer" type train power supplies (Lionel, American Flyer) will put out AC instead of DC.
Power supply out of an old computer? I think they have 12v and 5v outputs. It's not variable, but you are testing 12v circuits right?
Billm
JP
Whatever you do be sure to put a fuse or circuit breaker into the system- I always put it on the ground side of the circuit. I use a 10 amp breaker.
The "HO" style railroad transformers usually have two outputs, 12 volt AC AND variable DC.
BillM
JPSmit
JPSmit
Some great ideas - I had thought about the computer power source - but, had not considered a transformer - I might even have a couple downstairs.
I would definitely use Billm's advice, and fuse the outputs. I'm thinking very conservative, like 2-5 amp quick blow fuses... depending on the power supply's amp/watt rating, and whatever you might be testing... just to protect the power supply.
JPSmit
JPSmit
absolutely!
JPSmit
JPSmit
There are battery eliminators in science supply houses. They start at very reasonable prices. They use banana plugs to connect. The other end of the cable can be anything you want.
https://www.learningaboutelectronics.com/Articles/What-is-a-battery-eliminator.php
Now that is very cool! I went on ebay and searched - and I REALLY REALLY want something that looks like this!
https://www.ebay.com/itm/Vintage-EI...221344?hash=item43f8eeff60:g:eW8AAOSw4GVYJLX~
or this
https://www.ebay.com/itm/Heathkit-M...664534?hash=item4d52256656:g:q0IAAOSw9GhYeC37
T USB and Auxiliary Power Connections Austin Healey 6
RJS TR4/4A Power (+) Sources Triumph 7
Guido36 Electric Power Steering Austin Healey 2
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
H Loss of Power Upon Acceleration Austin Healey 8
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
JPSmit Power Pack Restoration & Tools 9
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
billspohn Engine Swapping for Straight 6 Power Other Cars 3
I Bugeye lack of power Spridgets 1
R TR2/3/3A Power Steering Triumph 2
Russ80MGB MGB 1980 MGB - No power MG 16
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
AngliaGT Olds,Power Wagon Spotted 1
B Power steering Other British Cars 33
Robert Somma power window installation TVR 3
B Intermittent Loss of Electric Power Austin Healey 18
H MGB 1980 mgb no power from ignition switch MG 23
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
M Power Loss Austin Healey 27
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
M TR6 Power Steering Rack & Pinion. Triumph 3
C MGA Where to tap into 12v for a power outlet MG 2
G Power to relays Austin Healey 10
M BN1 Loss of Power Austin Healey 21
S Power Steering Austin Healey 3
M TR6 Adding Some Power Triumph 8
nevets interesting article about converting classic cars to electric power Austin Healey 7
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
UmmYeahOk GT6 Zero acceleration power / Car’s RPMs surge when you get in it. Triumph 40
S TR2/3/3A power wirer for the heater switch Triumph 16
dougie Paddy Power Austin Healey 3
D Lilly under her own power... Austin Healey 7
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
G The Formula Power Fuel Catalyst!???????? Austin Healey 17
tomshobby TR6 power assist for clutch pedal Triumph 12
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
F 12Volt Bench Power Supply Austin Healey 4
B Power Brake Servo for a 100 Austin Healey 3
R BJ7 wiring power path Austin Healey 21
F BT7 brales poor stopping power - any advice? Austin Healey 19
KVH TR4/4A Engine Power Triumph 10
drambuie Getting more horse power from a Healey 100 Austin Healey 63
AH67 BJ8 losing power and enguine dies Austin Healey 9
L TR6 No power/not enough power to turn signals, wipers Triumph 8
KVH General TR Power Issue on Acceleration Triumph 13
Crankshaft TR2/3/3A Loss of power to wipers ad turn signals? Triumph 11
