General Tech Cylinder head costs
Bob Branson
It's been a long time since I had much machine shop work done, so please lend me your experience. The meta-question is whether to have my 1500 head rebuilt or just buy one already done. I know magnaflux is around $100 here, plus it will then need new valves, hardened seats and guides. If I'm looking north of $500, it seems easier and faster just to pay a little more and buy one already done (maybe an early B.) Thoughts are appreciated.
Mickey Richaud
Several factors here: How much time will yours be in the shop? Any special work you want done (porting, polishing, decking etc.)? Is originality important to you? Do they have a suitable one on the shelf? Will they take yours as a core?
Either way, I don't think there's a wrong answer.
:cheers:
Mickey
pdplot
In 2013, I paid $917.00 for a valve job including hardened seats. In other parts of the country, it most likely would be somewhat cheaper as everything is higher around here.
Madflyer
Time and workmanship That is your choice swap out cost or time at a good shop. They have some Alum. heads but I do not think much of Alum to cast blocks. Let others add to that. And then there is options on head gaskets and shaving the head look at it all. If you do not know what you do not know you may find out the hard way. I know of people that took a night class at local college just to do a motor complete, all tools and help at one place. and they need stuff to teach on. I even know a friend that took a woodshop class in the Bay Area SF and built his sail boat. Madflyer
B
Bob Branson
Madflyer, I share your bias against aluminum heads, and there are brand new cast iron ones available for less than pdpilot was charged. I'm kind of leaning that way. Wife has approved the expenditure;-))
Madflyer
The term porting and polish come to mind Your org. head will have rough sand casting that can be smooth a bit for air flow. and gasket trim to ports also needs to be done. As a new head may need more work as to ports to manifolds ports. lips and edges hamper gas flows in and out. Will a new head have valves and spring complete or will they need to be seated also. These are questions you should ask and not just believe are correct out of the box. All added cost. This BLOG will clear up any questions as members are very knowledgeable And GOOD ON YOU with the wife Madflyer
B
Bob Branson
UPDATE and final post on this subject (I hope!) Before forking over $700-$900 for a replacement head, and since I had an extra head gasket, I aggressively cleaned and lapped the valves, chased all head bolt and nut threads, flattened the washers and reassembled it with careful increments up to specified torque (50 fp.) Number 3 came up from zero to 145 psi. I can live with that and save the money to spend on something else for the car. Thanks to all who helped.
Mickey Richaud
WELL done, Sir!
K TR2/3/3A cylinder head washer Triumph 0
K TR2/3/3A The thread pitch of the cylinder head studs? Triumph 8
K TR2/3/3A Getting a cylinder head skimmed for flatness.... Triumph 2
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
S TR2/3/3A Rebuilding a cylinder head Triumph 10
petnatcar Cylinder Head Nuts - Tightening Sequence Austin Healey 2
K TR2/3/3A Checking a cylinder head with a straight edge to see if it's warped? Triumph 22
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
Celtic 77 MGB Mystery cylinder head attachment. MG 4
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
AUSMHLY Reduced-Shank Cylinder Head Studs Austin Healey 0
AUSMHLY Cylinder Head Studs Austin Healey 3
AUSMHLY Cylinder Head Input/Exhaust Circlip/Split pin Austin Healey 3
KVH General Tech Rusted Cylinder Head Freeze Plug--WOW Triumph 16
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
T TR2/3/3A cylinder head ,valves and springs Triumph 0
K TR2/3/3A Oil leaks at two front cylinder head studs? Triumph 3
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
R TR2/3/3A Cylinder head threaded plub Triumph 6
R BJ8 Cylinder Head Gasket Austin Healey 38
M Alloy cylinder head Austin Healey 5
HealeyRick For Sale Bare 29F Block, Cylinder Head and Manifold Austin Healey Classifieds 2
J For Sale TR 2, TR 3 TR 4 cylinder head Triumph Classifieds 6
J TR2/3/3A TR 4A cylinder head on TR 3 engine Triumph 15
M Planing a Jaguar cylinder head Jaguar 4
RJS TR4/4A Cylinder Head Install - Questions Triumph 16
C Wanted - 3000 cylinder head - uk based Austin Healey Classifieds 0
E Wanted Wanted: TR6 cylinder head- '72 or before Triumph Classifieds 4
RJS TR4/4A Broken Cylinder Head Stud Triumph 10
T Wanted 3.4 Cylinder Head Jaguar Classifieds 3
T TR4/4A Can you proof read this please | TR2-4a Cylinder head stud length chart Triumph 20
T TR4/4A How do you go about reinstalling cylinder head? Triumph 7
PeterK TR4/4A Here's what my NOS 511695 cylinder head looks like, unboxed Triumph 10
HealeyBN7 Is this a 100 Cylinder Head? Austin Healey 4
T TR4/4A Does the water pump need to come off to remove the cylinder head? Triumph 5
DornTRoriginal TR2/3/3A Head Gaskets and Shaved Cylinder Head Triumph 9
SherpaPilot TR6 Cylinder Head Stud Question Triumph 6
T TR4/4A Seems like a bad cylinder head or head gasket but what do you think? Triumph 19
K TR2/3/3A Cylinder head valve springs? Triumph 3
K TR2/3/3A Aluminum plug intop of cylinder head... Triumph 5
KVH General TR Cylinder Head Gasket: Stay Simple? Triumph 9
KVH TR4/4A Cylinder Head Time For More Tools? Triumph 28
BOBBYR Cylinder head for sale on ebay Austin Healey 2
S Procedure for cylinder head removal and re-installation - BJ8 Austin Healey 11
S TR2/3/3A Cylinder head stud methodology Triumph 11
RedTR3 TR2/3/3A How to check for cylinder-to-cylinder head gasket leak Triumph 7
K TR2/3/3A Cylinder Head and Compression Ratio Triumph 0
