TR2/3/3A Cranking Speed
frankfast
Recently made the transition to negative ground and added a Flamethrower distributor. Car won't start and battery seems to die almost immediately although still measuring above 14 volts. At first doesn't seem to spin the motor fast enough and dies after a few attempts. I am getting above 12 volts at distributor and solenoid. Any thoughts?
Using a 2 gauge lead from the positive terminal of the battery to the solenoid and a 4 gauge lead from the negative to the ground.
charleyf
One possibility is a poor or dirty connection. Try removing and cleaning your primary wiring to the starter and battery.
DavidApp
Remember there is or should be a ground strap from the motor to the frame when you are checking connections.
David
TR3driver
Great Pumpkin - R.I.P
I had exactly the same problem a few years back; turned out to be a flaw in the nearly-new battery. The voltage was drooping so much under load (from the starter) that the Pertronix module wouldn't work at all.
After switching back to points it would usually start within the few seconds of cranking; but the battery failed entirely (wouldn't crank at all) fairly soon after that. Even when it wouldn't turn the engine at all, the parts store battery tester showed it was "70% charged"!
F
frankfast
Found the connection to the stater motor slightly loose. Took it off and cleaned it up with some brake cleaner (although it appeared pretty clean), tightened it up and the car started right up. Success!!! Thanks for the help. Looks like Charley was right.
K TR2/3/3A Sluggish Cranking Update Triumph 3
K TR2/3/3A Sluggish cranking on start up? Triumph 5
Carlbanan56 MGB No spark and engine cranking slow MG 10
Sopwith_Camel Cranky but not cranking Spridgets 53
D TR2/3/3A Excessive cranking before it starts. Triumph 47
S Petronix ignitor for pos.ground BG8 only has 3.2 volt when cranking. Austin Healey 8
B Just keep on cranking out the oldies ! Restoration & Tools 3
Tinkerman TR2/3/3A TR3 Cranking Dog Bolt Position Triumph 6
P No spark while cranking Triumph 10
G Setting timing without cranking the engine.... Triumph 2
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
PAUL161 Jag 5 speed? Jaguar 5
T Datsun 5 speed potentially available from wrecker: Spridgets 0
Bayless What oil for Datsun 5 speed? Spridgets 7
L General MG Five speed MG 6
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G 5-Speed Conversions Austin Healey 15
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
Michael Oritt Pilot Bearing Adapter for Smitty's 5-Speed Kit Austin Healey 3
T Rut's 4 speed shifter modification - anyone have knowledge? Spridgets 3
Popeye Wanted WTB: two speed wiper motor TR4A / 75568 - Found Triumph Classifieds 2
shadowfever Datsun 5-speed info neede Spridgets 5
Michael Oritt Smitty's Five-Speed Manual Austin Healey 1
S TR2/3/3A Moss Motors Vitesse 5 Speed Conversion Kit Installation Issues Triumph 13
PAUL161 T-Series 5 Speed Road Test MG 25
PAUL161 T-Series 5 Speed Transmission MG 85
WHT Tremec T-5 Five-Speed Transmission Austin Healey 39
Michael Oritt Difficult-Shifting Toyota Five-Speed Austin Healey 17
crispy Idle Speed Variation Austin Healey 19
Cappy Toyota 5-Speed Austin Healey 3
Cappy Toyota 5 Speed transmission Austin Healey 4
T Wedge TR7 4 speed wheel cylinders on 5 speed (locating pin) Triumph 0
G TR4/4A "Engine seized after engaging overdrive at low speed. Triumph 26
T maybe a Datsun 210 5 speed available in Oakland? Spridgets 2
B 1966 TR4A two speed wiper motor Triumph Classifieds 1
I GT6 A type OD vs D type - engagement speed? Triumph 3
HealeyRick Toyota 5 Speed - Truck or Supra? Austin Healey 16
Michael Oritt Toyota 5-speed shifter bushing Austin Healey 7
roscoe 5 speed conversion question Austin Healey 9
Lin Toyota 5-speed bell housing drain hole Austin Healey 14
S For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE Austin Healey Classifieds 1
roscoe Caving In [5-speed conversion for BN2] Austin Healey 29
HealeyPassion Aftermarket heater/defroster with 3 speed fan Austin Healey 15
Editor_Reid “Healey: Cars for Speed & Glamour” Exhibition Austin Healey 5
S TR2/3/3A Speed O not working Triumph 27
M TR6 5 speed conversion Triumph 33
PAUL161 T-Series Who's still building 5 speed conversions. MG 4
Zitch For Sale TR4 - 4 Speed Triumph Classifieds 7
