Coroplast Signs under Wheels
twas_brillig
Canada just had a federal election, and there are several zillion signs made out of corrugated plastic being shipped off to be recycled.
I wasn't smart enough to think of this in time, but those signs would be good for protecting surfaces.
We have three Car Capsules for storing vehicles in and I'm concerned that the fabric will suffer being laid on concrete and being driven over, and then also with the twisting action of the front wheels damaging the fabric from the inside as the vehicles are manoeuvred.
I tried laying down a sheet of plastic over the concrete sidewalk blocks at one storage spot last year, but that prevents water from draining as readily - one of the Capsules is on the concrete driveway this year, so it got the sheet of plastic.
The brainwave is to lay Coroplast signs down on the concrete slabs, as water will be able to make its way around the signs and protect the fabric from the 'grittiness' of the concrete. Then put some signs inside the Capsule where turning the front wheels would twist the fabric.
Dunno if this thought is applicable to anyone else (or if it's even a particularly good one).
One caution is from a boating friend: bugs would nest in corrugated cardboard if left on their boat in the tropics.
And I'm also curious to know how UV durable Coroplast is: shingle a shed with them? siding??
Later
Doug
RJS Signs of Water Pump Failure? Triumph 6
Tabcon First Signs of Life! ... See it on You Tube NOW! Racing 2
M Early signs of rust Spridgets 15
RJS Signs of Generator Failure Triumph 8
Webb Signs of a Broken Waterpump? Triumph 10
B Car Show Signs Spridgets 11
PATR8 The signs Autumn is coming Triumph 9
JeffR Show car signs? Austin Healey 10
mrstinson Stall at Idle [Stop Lights, Signs, End of Drive] Spridgets 9
Overdrive45 Trim Under Convertible Cap Austin Healey 11
Gatheringtree TR2/3/3A Faltering at high RPM and under load demand Triumph 34
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
DrEntropy Show this to anyone under 40... Restoration & Tools 9
M MGC New book: MGCs Down Under MG 0
R Ground wires under dash Spridgets 5
J TR2/3/3A Wooden piece under scuttle with dash Triumph 6
J TR2/3/3A Pads under new floor Triumph 7
charleyf TR2/3/3A Under dash fuse Triumph 7
F TR2/3/3A Rust under flanges Triumph 7
B Under bonnet fuel Austin Healey 15
D MGB Stopping rust under patch panels MG 1
S Meaning of the ā€˜dotsā€™ under the temperature scale? Austin Healey 3
Zitch For Sale OE Under Dash Speaker refinished new speaker installed Triumph Classifieds 0
C Under boot and under bonnet paint? Austin Healey 7
BoyRacer Ideas needed for under dash radio mount, cup holders, glove box Austin Healey 39
TR3TR6 TR6 Turn signal lights don't flash when under load. Triumph 5
W Electrics, fuel system, under bonnet temp. Austin Healey 3
S TR2/3/3A Under the dash re-assembly sequence Triumph 4
S TR2/3/3A steering bracket that fits under the dash for the end of the column Triumph 2
C TR2/3/3A Triumph Tr2 Down Under Triumph 2
K TR2/3/3A The under dash fuse on later TR3's Triumph 7
Sopwith_Camel MGB under or over MG 3
G Supplier rant from down under Austin Healey 12
D TR2/3/3A Under hood Photos Triumph 7
D Lilly under her own power... Austin Healey 7
S TR6 Position of the buffer wedges under the hood [ bonnet] on a 74 TR6 Triumph 2
G TR4/4A Under Dash Pics Triumph 2
LarryK TR2/3/3A Craigslist St. Louis under 1959 Austin, Jag, Triumph Triumph 2
PatGalvin TR2/3/3A Scraping Down Under Triumph 18
K TR3A Air vent under grille on Race Cars? Racing 5
D TR4/4A shims under axle housing Triumph 7
simon1966 BN1 Strip down well under way Austin Healey 5
M TR2/3/3A The Sequel: Water from Under the Dash Triumph 3
Simmo MGA Missing under load MG 3
cmacmillan TR6 TR6 grille - rectangular tabs under the grille finisher? Triumph 2
Joe Reed MGB Rattle under front end? MG 8
Z MGB My 5.8 OHC Rover V8 build yes this is a P76 block from do under! MG 10
2billydavies TR2/3/3A clips under the dashboard that hold the vinyl covering on Triumph 4
I TR6 Under bonnet sticker source Triumph 3
T TR4/4A Under the been there - done that school of learning: TR6 rear springs on a TR4a Triumph 12
