Cold weather and oil viscosity?
RickB
I've been running Valvoline 20W-50 racing oil and it's great.
I'm wondering though if I should switch to a different viscosity for the cold 12F driving this winter?
Mickey Richaud
Rick -
My vote would be to leave well enough alone. I believe 20W50 is effective down to 0 degrees fahrenheit. If the car spends most of its down time inside, it won't see extreme temps anyway.
Mickey
RickB
RickB
Mickey Richaud said:
If the car spends most of its down time inside...
No such luck, so still stick with the 20W-50?
Mickey Richaud
Your call, really. I'm not a big fan of switching oils, if possible, but I can see how, in your case, it might be a good thing. Still, 20W is supposed to flow OK down to 0 degrees. But again, you might not want to chance it...
Gosh, did I seem wishy-washy there? :blush:
JPSmit
maybe :lol:
RickB
RickB
What does everyone think of adding some MMO in the winter?
If I'm a pint or two low, I could top it up with MMO.
Pythias
the "book" says...
down to 41 degrees F (5C) 20w40 or 20w50 ...
from 41F to -10F (5C to -12C) 10w40 or 10W30
below 10F (-12C) 10W or 5W20...
This is depending upon brand .. and is a shortened version listing oil brands specifically, such as Duckman's, Sternol, Esso, Mobil, Shell, and BP.
BugEyeBear
Typically I use 20W50 just for summer "Hot & Hard" running, then I use 10W30 or 10W40 for cold winters (freezing & below).
At freezing temps cold 20W50 is roughly twice a thick as cold 10W30or40. So turning your cold engine over will take twice the effort and oil simply won't flow as freely. Since your battery is typically also weaker in the winter this extra effort is further exagerated.
I'd recommend switching to a lower cold viscosity oil for winters, and DEFINITELY stay away from a straight 30 weight as that's stuff's like MOLASSES in the sub-freezing temps (roughly 3x as thick as a 10W oil...).
Have you tried the new 5W50s that are available? Theoretically the best of both worlds!!
"Cheers!"
-Bear-
BugEyeBear
For your reference:
SAE 10W40 at 40degreesC has a viscosity of 95.41
SAE 10W40 at 100degreesC has a viscosity of 14.0
SAE 20W50 at 40degreesC has a viscosity of 170.9
SAE 20W50 at 100degreesC has a viscosity of 18.5
So you'll really notice that the 20W is almost 2x thicker at 40degreesC, but you won't notice much difference once the engine has warmed up to 100degreesC.
"Cheers!"
-Bear-
theleisure Cold Weather, Oil Pressure Spridgets 10
R Very Difficult cold weather starting problems! Austin Healey 21
S Jag barely runs in cold weather Jaguar 7
kodanja Cold weather Effecting Performance? +- Triumph 35
MadRiver Cold weather starting Austin Healey 12
KVH TR4/4A Cold Weather TR4 Starting--Metallic Sound Triumph 2
BoneIdle cold weather starting woes MG 5
1 Cold weather stalling MG 15
drooartz Squealing brakes at startup in cold weather Other Cars 2
wkilleffer Cold weather engine tuning MG 30
jlaird For our cold weather friends Spridgets 6
nevets starting ether and cold weather starting Austin Healey 53
S Cold Weather Starting Austin Healey 6
Rick60 Coolant temperature in cold weather Austin Healey 10
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
sim oil pressure gage bad or engine needs rebuild It starts our cold at 60 psi but when warm it down to 10 psi Spridgets 21
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
F TR6 Pegged out hot while cold Triumph 7
B Cold Start Problems BN7 Austin Healey 21
RAC68 Cold Air Bilge Blower update Austin Healey 13
M TR2/3/3A TR-3A Compresson check hot vs cold Triumph 5
N Running Cold Austin Healey 12
M Cold start problems Austin Healey 33
D it's cold and i'm bored... waiting for parts... Austin Healey 11
M Starting from cold Austin Healey 2
F TR2/3/3A Starts Cold, Not Hot Triumph 12
P Healey 100M Cold Air Box Hose Fitting Austin Healey 20
Michael Oritt Replacing Cold Air Box with Velocity Stacks Austin Healey 10
M BN1 - Question about cold air box Austin Healey 6
K Hard Start, runs poorly when cold Spridgets 10
C Brakes pull to left - especially when cold. Where to start??? Austin Healey 11
S Hard starting on Webers from cold Austin Healey 12
Lutz Kramer Problem starting the cold engine Austin Healey 16
TRMark TR4/4A Cold air intake system Triumph 1
K TR2/3/3A Anyone running a cold air duct to the carbs? Triumph 15
drooartz MGB Must be the cold -- MGB will have a nice Xmas MG 7
M running cold Triumph 8
J Cold Starting on a Series II Jaguar 5
Morris Cold Air Intake Spridgets 2
S Cold galvanizing zinc spray Restoration & Tools 5
N Cold Plug site shutdown! Other British Cars 19
tahoe healey How cold would you drive? Austin Healey 16
V hard start when cold Austin Healey 7
aeronca65t TR2/3/3A TR3-cold tires Triumph 2
H Cold blooded animal Triumph 21
nevets OD sluggish when cold Austin Healey 15
S Cold Start issue MG 4
tweety Cold Start thoughts Spridgets 6
D cold air duct 100 Austin Healey 3
C Cold air box for Tri Carb 3000 BT7 ??? Austin Healey 9
