TR6 Clutch Disc---which way?? tr6
ALLAN
I manage to get this mixed up on every engine that I work on, What is the flywheel side of the clutch disc. there is one sid e that the diaphram sticks out more--- which way does it go???
The disc is not marked, I have looked at every catolog and repair manual and none of them shows a clear definate way.
This is an easy one. Kinda like pouring pee out
of a boot with the instructions written on the heel.
Even a non-mechanic such as yours truly had no difficulty
determining which side faced against the flywheel.
I just happened to have a clutch plate sitting on the
floor of my office. (don't go there) Here's photographic
instructions! /bcforum/images/%%GRAEMLIN_URL%%/computer.gif /bcforum/images/%%GRAEMLIN_URL%%/thumbsup.gif
The flat rivet heads side goes against the flywhee;
as seen in photo above. But it should be stamped.
Clean the metal surface with brake cleaner and look
for it again, just to be safe.
Do you have the plastic centering tool as well?
best of luck- if you encounter any problems,Ace
Mechanic Dave might enjoy a visit to sunny Colifor-nigh-ah.
Tinster
One side of the disc is almost flat. the other side is raised in the center. The raised side ALWAYS goes toward the pressure plate. Dave
David is THE MAN when it comes to TR clutches.
He taught me all I know about them.
Flat to flywheel
Raised to fingers
remember the disk grips the flywheel by friction,
therefore flat to flat.
d
If it is installed incorrectly the raised portion (steel)will grind into the flywheel, not the friction material.
dave
dave,
thinking more about it. I don't think it is
actually possible to assemble all the components
if the disk is reversed against the flywheel.
I don't think there is room enough with the torsion
springs reversed. The mounting bolts might not be
longen enough.
It sure would make a great grinding noise if installed
in reverse.
d
Tinster said:
dave,
One of the LBC vendors tech help sites described it this way " you can fit it in either way. but you will only put it in wrong once. Next time you will make sure it is correct before putting the transmission back in place.
Dale, it can be done. Maybe not on the TR6, but believe me, but it has been done many times. By professionals....
K TR2/3/3A TR6 Gearbox in a TR3.....Use a TR6 clutch disc and pressure plate or Triumph 7
G TR6 How thick should a clutch disc be? [TR6] Triumph 2
M TR2/3/3A HVDA Replacement Clutch Disc Available from Moss Triumph 10
M TR6 New clutch disc needed Triumph 2
B Clutch disc - which side goes towards flywheel? Austin Healey 8
K TR2/3/3A 3A Clutch Disc and 4A Cutch Disc? Triumph 3
K TR2/3/3A Clutch disc and Pressure plate differences? Triumph 3
J Smitty clutch disc Austin Healey 13
T Luk clutch disc Triumph 1
SMGoose Wrong Clutch Disc? Triumph 2
K Saving a clutch disc.....old school method? Triumph 11
bugedd Clutch disc anyone? Spridgets 0
RomanH Sachs Clutch Disc Failure Triumph 12
K TR4/4A Can I fit a TR3 clutch plate&disc in a 4A? Triumph 4
K Method of breaking stuck clutch disc free? Triumph 10
germanmichel Fly wheel -gear ring and clutch disc questions Austin Healey 13
KLUTZ T-Series Acceptable clutch disc thickness? MG 4
Stewart T-Series Which way does the clutch disc face? MG 4
J Reuse clutch disc? Austin Healey 4
MGTF1250Dave TR2/3/3A TR3 CLUTCH FRICTION DISC REPLACEMENT Triumph 9
R Midget Mark III clutch push rod lengths Spridgets 0
mctriumph TR2/3/3A The worst clutch noise ever heard Triumph 4
Ariddick TR2/3/3A Squeaking Clutch when hot Triumph 82
F TR2/3/3A Clutch Slave failure Triumph 5
Lutz Kramer Clutch Disengagement Austin Healey 15
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
Turbozinke TR2/3/3A Varying clutch engagement Triumph 6
K TR2/3/3A Pushing down the clutch pedal when starting the car? Triumph 22
DutchConnection Clutch finger problems on Powetune aftermarket clutch cover Spridgets 0
3 100 Clutch Freeplay Austin Healey 7
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
Govtslug TR6 Clutch Problem Triumph 21
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
AUSMHLY Clutch Pedal Freeplay Austin Healey 18
T General Tech Clutch trouble Triumph 12
K TR2/3/3A Gearbox clutch adjustment. Triumph 1
AUSMHLY Clutch Stalls Engine Austin Healey 16
D Wanted WTB - clutch fork and shifter from Datsun 5 speed #60 Spridgets Classified 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
T Spitfire Clutch fork and hydraulic cylinders Triumph 3
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
Lin Brake/Clutch Fluid Austin Healey 11
R TR2/3/3A Clutch Petal Adjustment Triumph 2
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
KVH General Tech New Clutch Installation--TR4A Triumph 5
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
