Ceramic Coating
Brakin80
Does anyone have any experience with ceramic coating their exhaust manifold that they could share? It seems like a simple way to reduce some heat from under the bonnet, and help increase the hp. Not to mention cleaning up the look. They seem to 'shed' their finish quickly after they've been freshened up. Thanks.
Best recent picture I could find of them since being in service:
healeynut
I put the Jet Hot coating on my A90 (same as a BN1/BN2 motor) and it has made all the difference in the world. It has NOTICEABLY cut heat in the engine compartment. I used thier extreme coating which isn't as shiny but has the maximum heat reduction rating:
If the image doesn't load you can see the header here:
A90 engine pic
I've also put the coating on my Jag Mk IX with excellent results.
I've been running the A90 now with the coating for about 1,000 miles - no change in surface quality - looks like new.
hmj6854
I had my BJ8 exhaust header porcelainized and think it came out great. I used Prairie Auto Porcelain in MN 507-645-5325-VERY good to deal with. JMH
R
RonMacPherson
I jethotted my 6 manifold around 91- been on the 6 ever since. Was my daily driver on two 6's for better than 10 years.. The gloss dulled, but the coating is still there... Tried waxing one time, but the wax gave a distinct odor when warmed up and burning off...
Would I do it again. YUP!
Editor_Reid
Platinum
I went with Jet-Hot coating the manifold to help reduce heat/fuel boiling. Also got a Denis Welch heat shield and also got it coated.
I just picked the car up yesterday so I can't give you much of a report on how well it worked, but I talked with the guys at the coating place about all the options, and they said that porcelain cracks basically no matter what you do - unless of course you never drive the car afterward.
Porcelain wasn't original on Healeys and the Jet-Hot coating is supposed to work better and it lasts indefinitely, so there was no hesitation on my part on which option to choose.
B
Brakin80
Reid, did you do both intake and exhaust manifolds? What sort of ballpark price would I be looking at? Thanks.
healeynut
Brakin -
You probably don't want to Jet hot your intake manifold as the car works best when there is some heat in the intake manifold. If it is Jet Hot Coated, the surface temp inside could very well be too cool, meaning you'd have to run the carbs too rich to keep the fuel mixture right.
You only need the coating on the exhaust manifold to control the heat.
Editor_Reid
Platinum
Only the exhaust manifold. It cost $120. Coating the Denis Welch heat shield was another $40.
They also had a variety of colors available, and reported that the black works best for suppressing heat, although I opted for a dull silver.
J Bling! New ceramic coating on exhaust manifold Spridgets 8
1965_MGB Ceramic Coating Exhaust Parts Restoration & Tools 18
danstr6 Ceramic Coating for Header Triumph 14
D Ceramic Coating Triumph 5
Lin Jet Hot ceramic exhaust coating Austin Healey 13
beez ceramic coating on headers Triumph 14
Lin Header Ceramic Coating Austin Healey 2
Got_All_4 For Sale Brake caliper pistons Ceramic Coated and more Triumph Classifieds 0
R Ceramic Finish Austin Healey 3
B Carnauba wax Vs. new ceramic paint sealants Austin Healey 35
R ceramic or semi-metallic brake pad? Spridgets 3
3798j General TR Ceramic Coated Exhaust Manifold Triumph 8
Brosky Block painted with Ceramic and curing Triumph 22
T ceramic lifters Triumph 1
S Lizard Skin Ceramic Insulation MG 0
Michael Oritt Powder Coating Temperature Limit Austin Healey 7
J Piston Coating Austin Healey 3
AUSMHLY 2nd gear should I file it? Do gears have a hard coating? Austin Healey 7
Rut TR4/4A Inner frame coating Triumph 6
Got_All_4 General TR Coating a exhaust manifold Triumph 12
D Powder coating Spridgets 20
Zimmycobra Powder Coating wire wheels? Triumph 10
dklawson Gauge Face Coating after Cleaning? Spridgets 1
dklawson Gauge Face Coating after Cleaning? Triumph 2
D Polished Metal Coating to Protect Shine Austin Healey 1
britlover TR4/4A TR4 engine rebuild best coating for fig 8 gaskets? Triumph 8
bugedd Clear coating polished aluminum Spridgets 26
Magyar Powder Coating Wire Wheels Austin Healey 19
J Wire wheel prep for powder coating? Spridgets 7
B Coating on Vicki B's replacement windshield MG 4
Tr4dude TR6 Tr6 rim before and after powder coating. Triumph 16
R powder coating Austin Healey 7
T TR4/4A TR4A wire wheel tire size & powder coating? Triumph 18
JPSmit anyone used this? Galvanized coating? Restoration & Tools 1
TRMark Shop Floor Coating Restoration & Tools 10
Tim Tucker Caswell Hi-Temp Powder Coating Triumph 1
T So let's talk about powder coating Spridgets 17
R Graphite Coating Spridgets 4
drooartz Jet Hot header coating questions Spridgets 13
jvandyke Powder coating snafu Spridgets 8
Brosky Color coating almost completed, clear is next Triumph 8
Tinkerman Powder Coating Wire Wheels? Triumph 7
S Powder Coating Temperature Triumph 17
S Powder Coating Temperatures Restoration & Tools 5
angelfj1 Liquid Powder Coating - has anyone tried this? Restoration & Tools 4
Brosky Playing with powder coating [not me...] Triumph 15
G Jet Hot coating peeling off my headers........... Triumph 9
Brosky Powder coating process [stateside, not PR] Triumph 47
Brosky Powder coating begins next week Triumph 2
Bret Manifolds Powder coating vs. Painting? MG 24
