Bugeye Fuel Pump
bberwick
I have the original manual fuel pump for my 1961 Bugeye. How do I ascertain if the diaphragm needs to be replaced? The rebuild kit is not too expensive, but it is more than a simple gasket.
Dave Russell
Yoda - R.I.P
Hi Bob,
If the diaphram has a leak, fuel will likely get into the crankcase.
A simple check is to block the inlet, apply vacuum to the outlet & see if it holds vacuum. If it doesn't, the diaphram is leaking. Another check is to apply vacuum to the inlet with the outlet open. If the pump valves are leaking, it won't hold vacuum. The first test will determine if it's the diaphram, the second test will show if the valves are leaking.
If you don't have one, hand operated vacuum - pressure testers such as Mity-Vac are readily available.
I Bugeye fuel pump help Spridgets 2
P Herko kd8016 fuel pump in bugeye??? Spridgets 5
ncbugeye Push SU fuel pump in Bugeye Spridgets 8
P Electric Fuel Pump for Bugeye??? Spridgets 12
B Electric fuel pump for a bugeye - Questions. Spridgets 13
G Bugeye fuel pump Austin Healey 4
B Fluctuating Fuel Gauge 1960 Bugeye Spridgets 4
T Wanted Smiths fuel gauge for Mk 1 Bugeye Sprite [FG2530/31] Spridgets Classified 1
S Wanted 1959 Bugeye Fuel Gauge Austin Healey Classifieds 0
Tim Hollister Wanted Need Fuel Gauge for 1959 Bugeye Spridgets Classified 2
I Bugeye fuel fitting Spridgets 3
H Bugeye fuel tank sending unit - repair or replace Spridgets 5
Rut Bugeye fuel gauge Spridgets 14
BlueMax Bugeye Fuel Gauge Spridgets 3
P Bugeye fuel line? Spridgets 3
drooartz Later fuel tank in a Bugeye Spridgets 11
AN5Sprite Anybody Have A Bugeye Fuel Gauge Core To Spare? Spridgets 3
Ohiobugeye Bugeye Fuel Line Nut & Sleeve For Gas Tank Spridgets 12
athenssprite Fuel tank - 1960 Bugeye Spridgets 12
drooartz eBay Bugeye fuel tanks, recent experience? Spridgets 8
Glen_B Bugeye Fuel Injection Spridgets 4
ncbugeye Bugeye Fuel Tank Spridgets 8
ncbugeye Can a Bugeye fuel tank sender be restored? Spridgets 7
msoylemez Bugeye Fuel Gauge Spridgets 3
ncbugeye Need immediate help with Bugeye fuel tank Spridgets 10
R Bugeye ignition switch Spridgets 2
T Music Video with a Bugeye, plus a hill climb video Spridgets 1
D For Sale 1958 A-H Bugeye Sprite Austin Healey Classifieds 3
Todd78d Bugeye carpet Spridgets 7
L For Sale original Bugeye SU H1-1 1/8 Carbs Spridgets Classified 0
Todd78d Bugeye choke linkage Spridgets 5
J Installing Adapter Hubs for Wire Wheels on a Bugeye Austin Healey 5
R Wanted Bugeye ignition switch Spridgets Classified 2
CARSINC 1965 Sprite Bugeye Spridgets 5
drooartz The great Gordon Murray has a Bugeye! Spridgets 0
W Bugeye Tudor Wash Bottle Decal Spridgets 0
R Bugeye drum brakes Spridgets 7
SNClocks Bugeye Alignment Spridgets 4
S For Sale Bugeye wheels, steel with round holes set of 5 available Spridgets Classified 0
J Finally getting (re) started on the Bugeye Spridgets 27
drooartz Restoring Penny the Bugeye Spridgets 22
drooartz Bugeye jack points to remove rear axle Spridgets 18
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
SNClocks Bugeye axle limit straps Spridgets 5
R Wanted BUGEYE SHIFT LEVER Spridgets Classified 6
