Brake hose fittings for '79
Morris
I apologize if this has been covered, but I was wondering if anyone could tell me the fitting sizes for the brake houses on a '79.
Also, I am interested in opinions on whether it is cheaper to source the hoses locally than to buy them from VB/Moss.
Thanks
RobSelina
the stainless lines I received from moss were just goodrich braided lines. I've purchased jeep lines before and they all seem to come from the same supplier. If you can find out which models they are selling, I'm sure you can buy them cheaper.
SMG0500 is the Goodridge part #. My father got them for me as a Christmas gift one year, but I do not know where he bought them.
jlaird
Nice Dad, give him my reguards.
Car parts always welcome.
bighealeysource Installing stainless steel brake hose on BN2 Austin Healey 5
W Brake Hose shelf life Austin Healey 11
F Front brake hose BJ8 Austin Healey 4
F front brake hose 67 BJ8 Austin Healey 4
RJS TR4/4A Rear Brake Hose Replacement Triumph 7
R Can't remove rear flexible brake hose Spridgets 5
sundown TR6 1973 TR6 brake booster hose Triumph 7
maxwedge5281 substitute rear brake flexible hose.... Austin Healey 5
W Brake Seize Vacuum Hose Jaguar 1
M TR2/3/3A Brake hose replacement Triumph 12
Zimmycobra TR4/4A any tricks to change rear brake hose - especially on passenger side [TR4A IRS] Triumph 9
nevets Front brake hose length Austin Healey 10
J TR2/3/3A TR2 - earlyTR3 front brake hose length and photo? Triumph 1
nevets front brake hose question-BN6 Austin Healey 18
7 Brake hose lifespan?? Triumph 13
M Brake Hose replacement advice Spridgets 3
TonyPanchot TR5/TR250 250/6 replacing rear flex brake hose Triumph 5
G First time I've ever seen this [bad brake hose] Spridgets 13
S Front Brake Hose Wear Austin Healey 9
YankeeTR Brake Hose/Pipe/Line Information... Triumph 2
M TR2/3/3A TR3 brake hose too short Triumph 4
kennypinkerton Brake hose and steering question... MG 2
kennypinkerton front Brake hose question... MG 5
G XK120 Brake hose needed Jaguar 2
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
