Wanted Bolt on luggage rack
wrburgman
My TR4A has holes in the rear deckled for a bolt on luggage rack. They are currently filled with stainless carriage bolts.
Anyone have an old Amco bolt on rack with 24 x 17 footprint they would be willing to sell? I don't want to reskin the boot to eliminate the holes since the panels are all original.
Thanks
Rick Burgman
image.jpgRick
heres one that measures 24x17. Chrome is bad but frame is straight. $25 and shipping
Marv
Rick,
shipped one like it a few months to NC for $15, to IA probably couple dollars more. So make it $42 total and will ship Monday. I will pm you my paypal contact.
I also have plenty of TR4 parts if you were to need something else.
My email is same as paypal so if you will email me shipping address,
Marvin
Jkirchner Rocker Pedestal Banjo Bolt Thread Size Austin Healey 10
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
S TR2/3/3A old 4 bolt axle set up Triumph 12
D TR2/3/3A cylinder head oil plug bolt size Triumph 6
S TR2/3/3A old 4 bolt axle differential. Triumph 11
KVH General Tech Dog Bolt Torque—Crankshaft Triumph 11
JPSmit A fairly specific looking bolt Spridgets 10
F 59 bugeye spring bushing bolt Spridgets 8
A For Sale Rover V8 heads, 10 bolt Other British Classifieds 0
TR3MT TR2/3/3A Whitworth Threads (as on the bolt) Triumph 6
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
K TR2/3/3A Brake caliper brake pad retaining plate bolt hole? Triumph 16
R difficult bolt access Spridgets 8
steveg TR6 Question - which bolt for heater return pipe bracket Triumph 3
B TR4/4A Starter dog bolt Triumph 15
S TR2/3/3A Generator Pulley Bolt Removal Triumph 12
J Steering Box Adjusting Bolt Lock Nut Austin Healey 11
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
AngliaGT '74 Midget - Heater Box Bolt Size? Spridgets 8
P Rear Seat Pan Bolt Hole Locations on a BJ7 Austin Healey 1
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR6 Rusted Trunnion Pivot Bolt Triumph 18
KVH TR4/4A Lower Control Arm Front Pivot Bolt Triumph 9
maxwedge5281 front hubs for bolt on wheels Austin Healey 7
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
D Oil Filter Bolt Seal Austin Healey 2
C Tough Bolt on front of Crankshaft Spridgets 16
Scotsman TR4/4A Spinners for bolt on minilite wheels Triumph 0
G TR4/4A ARP Bolt Torque Specs Triumph 10
B TR2/3/3A Rear Spring front attachment bolt Triumph 23
Csarneson Connecting Rod Bolt Question Austin Healey 3
maxwedge5281 Wanted want to buy! one bolt on 3000 wheel! Austin Healey Classifieds 2
tomshobby Spitfire head size of damper pulley bolt on 78 Spit? Triumph 2
D BJ 8 Float Bowl securing bolt loose Austin Healey 6
tr3guy TR2/3/3A TR3 Fan Bolt Torque Triumph 3
Jim_Gruber Removing back Radius Arm Bolt Spridgets 12
D TR4/4A Does a bolt legend exist? Triumph 3
M Rear spring plate bolt Spridgets 1
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
GeorgeC BN1 bolt size Austin Healey 0
D TR4/4A Tr4 Vented gas tank banjo bolt Triumph 7
S Torque setting for U-Bolt nuts Austin Healey 12
F Tightening the idler pulley bolt on a 1098 Spridgets 2
C TR4/4A How to get the $&@%# filler bolt out of the side of the trans to top her off?!? Triumph 7
Got_All_4 TR2/3/3A The bolt on the back of the tr3 head Triumph 4
T TR2/3/3A coil mounting bolt oil leak Triumph 2
K TR6 Thread repair for trans cover bolt Triumph 14
Martinld123 Oil Seeping Out One Exhaust Manifold Bolt Austin Healey 8
