BN1 Front Spring Dimensions
zblu
Have a pair of coilsprings been offered to me, 11.5" long, 4.75" O/D, 3/4" coil dia,7 full coils, do these suit? as I dont have my BN1 close by to check
zblu, i have a set of original springs that come off a bn-2, they should be the same as those for bn-1 they measure 11-3/4 long, 4-5/8 diameter, and 17/32, thick. have your friend remeasure his. :savewave:
Z
zblu
thanks anthony7777, I measured quickly with a tape 290mm, 120mm, 17mm, will recheck tomorrow, all but coil dia sound close enough
zblu, ya good idea, mine naturally have some rust but i cant see how 7/32 wasted away, perhaps while building these cars they pulled them out of bins from different vendors? maybe you got the "low rider" version. :jester:
Z
zblu
Just checked my parts book anthony7777, BN1 and BN2 have different part numbers, or maybe i got the uprated stiffer comp ones on offer, nothing a spacer cant fix :smile:
zblu, its good to have a parts book! moss says bn-1 and bn-2 use the same spring, they do list a repro set for bn-1, bn-2 and bn-4 that must be changed in pairs, p/n 661-910 there using the same p/n for all of these, im sure the ones you have will be fine, i like the fact there a little "chunkyer". :yesnod:
Z
zblu
BN1 is part No. 1B 4315, and BN2 part No. is 4484, wonder if the height diff is taken up on install then the action should be a stiffer ride with same height due to larger dia coils not settling as much on install? Have to wait until someone with BN1 coils chimes in!
Z
zblu
Well, remeasured and got 11" 17/32 high, 4" 27/32 outside spring dia, and 5/8" coil dia, number of coils matches pic in parts book, Hmmm!, might grab them
C BN1 Front Spring Advice Austin Healey 0
BoyRacer BN4 Front Wings on a BN1 Austin Healey 9
Jake BN1 Front Shroud Badge - What is original? Austin Healey 4
C For Sale BN1 Front Drum Brakes assemblies and hubs for sale Austin Healey Classifieds 0
Z Early BN1 front stub axle castellated nut Austin Healey 3
pan Front wheel bearings [BN1] Austin Healey 6
M BN1 front wheel bearings Austin Healey 5
C Value of BN1 Original Front Drum Brakes? Austin Healey 4
T 1955 BN1 front shroud Austin Healey 3
T BN1 Front Sway Bar Austin Healey 0
L BN1 front timing cover seal Austin Healey 2
healeynut Front Oil Seal - BN1 box - worth it? Austin Healey 4
I Front Brake Cylinders for BN1 -- odd sizes ? Austin Healey 10
D BN1 Front suspension Austin Healey 2
jtb55 Conversion of front brakes from BN1 to Bn2 Austin Healey 9
S Wanted Windscreen Wiper Arm for BN1 wanted Austin Healey Classifieds 2
J For Sale BN1 project car (price reduction) Austin Healey Classifieds 0
W BN1 Steering Box Removal Austin Healey 11
W BN1 Steering Box Austin Healey 3
I Wanted BN1 with H6 carbs : bodies of TR3 Austin Healey Classifieds 1
S BN1 Wheel-Tyre Combination Austin Healey 10
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
W Healey BN1 Ignition Light Austin Healey 8
T Wanted: Early BN1 Sidescreens Austin Healey 2
Guido36 BN1 with Triumph TR 4 engine Austin Healey 1
B Austin-Healey 100 BN1 Electrical Diagram Austin Healey 0
W BN1 Gearbox First Motion Shaft Austin Healey 0
I Austin-Healey BN1 Parts List Austin Healey 4
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 25
BoyRacer Replace BN1 steering box with later version? Austin Healey 0
red57 Interesting BN1 for sale in Bellingham, WA Austin Healey 4
D BN1 Parts to Trade Austin Healey Classifieds 0
S WANTED: Healey BN1 "Smiths" Fuel Gauge (Dead or Alive) Austin Healey Classifieds 3
A BN1 Mechanical Brake Switch Austin Healey 23
P Wanted BN1 can shaft Austin Healey Classifieds 0
C BN1 Clutch Pedal Rattle Austin Healey 2
CharlesBN1 Uprated or 'umbrella' valve stem oil seals for BN1 Austin Healey 2
Guido36 BN1/BN2 Sidescreens Austin Healey 0
M BN1 Loss of Power Austin Healey 21
L Seat position for a BN1 Austin Healey 0
CharlesBN1 Wanted WTB Shelley Jack [6 INCH DL] for Early BN1 Austin Healey Classifieds 0
M BN1 with H6 carbs : what setting ? Austin Healey 56
I Ball Bearing cup for old style BN1 steering box Austin Healey 0
M Heat-related carb issue on BN1 Austin Healey 7
RCarr 1954 BN1 Wiper Wheelbox and Rack Austin Healey 3
CharlesBN1 Wanted wanted to buy - sidescreen trim/strips for early BN1 Austin Healey Classifieds 5
CharlesBN1 BN1 Soft Top installation - need advice! Austin Healey 3
Michael Oritt Optimal lighting for a BN1 Austin Healey 5
D Wanted BN1 LH Seat Cushion [Bottom] Austin Healey Classifieds 0
J 100 bn1/bn2 id Austin Healey 26
