TR2/3/3A Blinking the Brake lights?
karls59tr
Bronze
Is there a gizmo available that I can install that will blink the brake lights a few times then stay on till released? Negative Ground.
NutmegCT
You'll hate me for this, but your foot will do that very nicely.
Tom M.
TR3driver
Great Pumpkin - R.I.P
TuffTR250
Also, if you have not done it, I highly recommend putting in LED bulbs in the rear. They are so much brighter than standard bulbs. I like the ones from LiteZupp. They directly replace the old bulb. Also you would need a new turn signal flasher that supports LED bulbs. With the brighter LED bulbs you may not need them to flash.
Geo Hahn
I have used the GS-100A that sells for a couple of bucks on eBay:
https://www.ebay.com/sch/i.html?_fr...sc=0&_osacat=0&_odkw=flash+strobe+turn+module
Works fine with LEDs. I suspect that regular incandescents would light up and go out to slowly for it to be effective with them.
If you do not want to convert to LEDs an alternative is to just use the strobe to flash an LED third brake light. That is what I did on this car:
mgedit
I also used that gizmo that Geo mentioned. Worked just fine to flash an LED third brake light on both a TR6 and TR3.
Cheers, Mike
K Up-date on Blinking 3rd Brake Light Triumph 1
K Need Email for CK Technologies Re: Blinking Brake Triumph 9
K Blinking the Third Brake Light? Triumph 28
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
KVH TR4/4A Rear Turn Signals are Blinking In Reverse Triumph 2
longbridgehealey BN4 turn indicator blinking very slowly Austin Healey 2
DerekJ Indicator blinking too fast Austin Healey 13
B MGA Axle Brake line MG 0
6 Brake Fluid Spridgets 4
F Excessive Brake Pedal Travel Austin Healey 3
F Disc Brake Shimming Austin Healey 8
PDIGIO_6x3 TR6 BRAKE TUBING KITS Triumph 6
L Red Rubber Brake Grease Austin Healey 2
Martinld123 Emergency Brake Doesn't Release Austin Healey 9
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
petnatcar Aluminum Brake Fluid Reservior Austin Healey 5
M Brake Servo Austin Healey 2
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
T Spin-On Oil Filters for Cars with a Brake Servo Austin Healey 3
J MGB BRAKE VALVE ? MG 11
G Brake Light Switch Failure Austin Healey 24
B Rear Brake Cylinders Austin Healey 4
K TR2/3/3A Brand new brake caliper question... Triumph 8
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
J TR2/3/3A Brake Line Flares Triumph 8
Frameman 1949 Brake Bleeding Austin Healey 0
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Chrisc9 TR6 TR6 brake light Triumph 6
L T-Series Another brake prob. ? MG 12
S TR2/3/3A brass fitting from a steel brake line Triumph 2
Sopwith_Camel MGB pulsing brake pedal MG 10
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
bighealeysource Front Brake Adjusters Austin Healey 0
SherpaPilot TR6 Brake Fluid in Servo? Triumph 0
TAS525 TR2/3/3A Thoughts on Brake Pads Triumph 12
Gundog61 BN2 Brake Drums Austin Healey 5
KVH General TR Rear Brake Shoe Orientation Triumph 12
R TR6 Help: Brake Part Source or …. ? Triumph 1
mezy vauxhll brake pipes Other British Cars 0
KVH General Tech TR4A Brake Bleeding Triumph 5
R Brake Adjustment Spridgets 2
Walter74 Brake Servo Location Austin Healey 6
A 100-6 Brake Lights Austin Healey 2
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
prb51 Girling Brake Fluid Reservoir Cap Austin Healey 6
KVH General Tech Brake Fluid Triumph 5
Lin Brake/Clutch Fluid Austin Healey 11
AUSMHLY Castrol DOT4 Brake Fluid Austin Healey 6
