BJ8: Upper Trunnion Rebuild [Of Continuum]
pkmh
Dear Forum,
A few months ago, I posted a topic here about rebuilding my front upper lever shocks. Very soon after that time, I decided to ship them out for a rebuild. Everything worked out great with the shocks, of course.
The reason I labeled the above, "Of Continuum" is because the upper trunnion bushings I rebuilt myself and was done around the same time the shocks went back into the Healey. Different subject, but somewhat related and was done together.
And finally, moving forward, I want to share my completed record of what I had done, just to seek any additional thoughts or comments for future.
By the way, my approach to doing this rebuild was, of course, limited to the tools and equipment I had available to me. Thus, the reason for my notes on the removal process used. Naturally, the better the equipment, the easier the operation.
Aside from that, I accomplished what I wanted to do. One way, anyway.
Just curious to know if there are other thoughts or ideas that should be considered for future, especially on the subject of trunnion/bushing rebuilding.
Thank you all in advance!
Paul
Healey Nut
Did you use the upgrade upper trunnion bearing or just the standard bronze washer ?
Im thinking of trying the bearings out on my next restoration.
I have the torrington bearings on my BJ8. They reduce turning effort a little, which helps because I have 6" rims and 'fat' tires.
pkmh
pkmh
Healey Nut,
Thanks for asking. No, I did not upgrade the trunnion. At least not yet. I do have replacement parts, short of the swivel pin. Will need to confirm material type later (I ordered the "Kit" from Moss some years ago consisting of washers, springs and what have you--all in storage). I recently ordered and now have a "Brake Cylinder Hone" bit from NAPA when I do ream out the inside diameter of the trunnions. Doing my front end has been slow going, to say the least. I was planning on doing the lower bushings next, hopefully this fall.
When I get a bit more 'confident', then the trunnions themselves (if they need it). I feel the need to study that area better before proceeding only because I do not want to compromise my wheel settings (i.e.- camber, caster, swivel pin inclination). Ok, I understand from the manual these "settings are not adjustable" and that "the settings were determined by the machining and assembly of the component parts during manufacture." Still, I want to record, as installed, before dismantling. This will have to come later for me.
I hope this makes sense. Yes?
Jerry
I just finished this job with the bearings and adjustable camber settings. You will have to take off the arm of the shock to fit the trunnions. This is not hard and goes back on pretty easy. This is the second car I have done with the bearings and adjustable camber. I think it is an improvement, but it is hard to tell since I never drove either car prior to the rebuild. Both cars were all torn apart when I bought them.
Jerry
pkmh
pkmh
Ok, Jerry, thanks for that. You say "adjustable camber." Did the Healeys come with "fixed cambers?" The manual seems to indicate that. I must admit, this is an area I am still new in knowing all there is to know (But I will figure it out, eventually).:encouragement:
Ok, Jerry, thanks for that. You say "adjustable camber." Did the Healeys come with "fixed cambers?"...
Fixed camber AND caster. Mods include offset trunnion bushes, adjustable plates (Kilmartin) or plate inserts (Tom's Import Toys). I have the Kilmartin plates on my BN2 and the inserts (to be installed) for my BJ8. I just bought an alignment measuring kit; I'm going to experiment with the BN2--which has a heavy 'turn-in' effort--and then do the BJ8. Neither the bushings or plates allow for caster adjustment, but I plan to widen the shock bolt slots on the BJ8 to allow for a little.
pkmh
pkmh
Bob,
You seem to know your stuff. Thanks for mentioning about the alignment measuring kit. I will have to look into that. And good luck with your quest.
Thanks, but actually I don't know much about suspension and its real-world effects, but I've always been curious. I got a smaller diameter steering wheel for the BN2 and, of course, that increased steering effort. I've only driven one 100, mine, but I think this car should be more maneuverable. This is the alignment kit I ordered (their PayPal interface was broken but I found them on eBay):
https://www.wheelalignmenttools.com/product/4-wheel-alignment-system/
D Re-fitting vinyl on center upper console bj8 Austin Healey 3
A BJ8 Upper Windshield Bow - Center Hole Finisher Austin Healey 16
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
Patrick67BJ8 BJ8 Factory Hardtop Rear Window Austin Healey 6
AUSMHLY BJ8 Clutch Pressure Plate, Old vs New Austin Healey 4
AUSMHLY BJ8 Clutch Fork Bush Replacement Austin Healey 5
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
AUSMHLY BJ8 Clutch Pressure Plate Brand Preferences Austin Healey 3
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
AUSMHLY BJ8 Overdrive Oil Passages Austin Healey 2
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
A For Sale 1966 3000 Healey Blue BJ8 Austin Healey Classifieds 3
B BJ8 Hood Bow and Seal Austin Healey 5
Mickey Richaud Wanted Wanted: BJ8 Seat Track Sets (Both Sides) Austin Healey Classifieds 5
Scotsman BJ8 Intake Manifold Differences Austin Healey 4
AUSMHLY Laygear End Float BN1-BJ8 Austin Healey 2
C For Sale BJ8 original dash Austin Healey Classifieds 3
LarryK BJ8 Parts or Project Car For Sale in St. Louis Austin Healey 3
Patrick67BJ8 BJ8 Intake manifold Booster & Vacuum Hookup threads sizes. Austin Healey 2
B BJ8 Centre Console Chrome Strips Austin Healey 5
B Wanted Chrome strips centre console BJ8 Austin Healey Classifieds 0
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
