BJ8 OverDrive
AH67
The overdrive on my BJ8 has always worked well. Had the console and dash replaced and while out something may have happened in some wiring got messed or loose. OD is inconsistent now.
I want to try to reach in and see if I can find some loose wire somewhere. The shop that did the dash work is too far (300 Miles for me to drive to)
Any advice where or what to look for?
Thanks
TimK
More details on what the inconsistency is would be helpful. For example, does it engage all the time then disengage unexpectedly, or does it not engage sometimes? Do you have a wiring diagram? The dash switch sends power to the OD relay which then powers on the OD solenoid if the transmission is in 3rd or 4th gear. Once the solenoid is activated, hydraulic oil pressure takes over. So, please explain the symptoms more.
AH67
AH67
The latter.. it does not engage sometimes. When it does all works well and it switches on and off.
AH67
AH67
That is what I thought... When the shop put in the new dash, they must have pulled something...
Shows you much a software engineer knows about Healeys:eek:
TimK
Using a length of wire from a 12 volt battery source (negative post if you have positive ground), touch the OD relay connection where the wire from the dash switch is connected. Make sure gear shift is in 3rd or 4th. If you hear the solenoid click every time you touch the "hot" wire, then you have isolated the problem to the dash switch or the wires connecting it to the OD relay.
S BJ8 Overdrive Stays Engaged Austin Healey 35
AUSMHLY BJ8 Overdrive Accumulator Spring Tube Austin Healey 1
AUSMHLY BJ8 Overdrive Pressure Loss Austin Healey 11
AUSMHLY BJ8 Overdrive Oil Pressure Austin Healey 14
S BJ8 Overdrive Issue Austin Healey 7
S BJ8 Overdrive issue Austin Healey 10
BJ8Healeys For Sale Rebuilt BJ8 overdrive unit for sale Austin Healey Classifieds 0
Airwave BJ8 overdrive stops working after a while driving Austin Healey 17
M Overdrive In-Op AH BJ8 1967 Austin Healey 11
4tecdog BJ8 Overdrive oil leak Austin Healey 6
S Overdrive solenoid problem on a BJ8 Austin Healey 3
D Overdrive problem when raining - bj8 Austin Healey 23
S BJ8 Sputtering at High Engine Speed and in Overdrive Austin Healey 36
davidb BJ8 Overdrive Austin Healey 16
P Mysteries under the BJ8 transmission tunnel, speedometer cable, overdrive and gerabox Austin Healey 1
M correct gear oil for bj8 trans and overdrive ???? Austin Healey 5
M overdrive bj8, smoked Austin Healey 1
D BJ8 Overdrive Switch on gear leaver top Austin Healey 2
R BJ8 overdrive intermittent Austin Healey 11
bighealeysource overdrive not disengaging right on my BJ8 Austin Healey 7
Ed_K Overdrive solenoid rubber piece on a BJ8 ? Austin Healey 2
specialsports Help Healey BJ8 overdrive just stopped working? Austin Healey 5
A BJ8 Overdrive Austin Healey 3
Steve P. Value of Healey BJ8 overdrive? Austin Healey 2
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
