BJ8 frame measurements
BOBBYR
Hi Gang,
I hope everyone is doing well. I was going through some of my repair manuals tonight and came across a chassis alignment diagram. The diagram was marked for a BN4 to a BJ7.Does anyone know if a 65 BJ8 frame shares the same measurements as a BJ7? As always, I appreciate your help and hope you are all having a blast with your Healeys .
Bobby R
GregW
Platinum
Hi Bobby,
Some of the measurements are shared, but the BJ8 does have some differences. Namely the rear frame rails, I think the outriggers on the exhaust side are different too.
John_Progess
Bobby,
I know that the rear of the frame is different as they increased the ground clearance on the Phase II cars. They did this by changing the frame. They also added torque boxes and did away with the pan hard rod. I believe that from the front or the rear leaf springs forward, the frame is the same but someone more knowledgeable than I should verify this. Hope this helps and have a good day!
John
BOBBYR
BOBBYR
Hi Guys,
Thanks for your input. I wish there were a print of it somewhere to copy.If anyone is aware of such a print ,please contact me.Thanks again,
Bobby R
Genos2
Hi Bobbyr, '65 MK3', were either Phase 2 or Phase3. I've owned both. Early BJ8's were the same as BJ7's. Those included '64&early '65. Phase 3's frame differed in rear as they kicked down below rear end housing for additional road clearance(body set slightly higher)& also had radius rods above leave springs.Also outriggers were cut for separate mufflers, w/ reasonaters across the rear. A few other small changes. Hope this adds clarification,cheers Genos2
JamesD BJ8 Top Frame Bumpers Austin Healey 12
P BJ8 Frame Rust Options? Austin Healey 14
M BJ8 Frame Dimensions Austin Healey 2
RAC68 Shim Adjustment of BJ8 Convertible Frame Austin Healey 5
I BJ8 soft top frame dimensions Austin Healey 4
C Top frame pinching soft top - BJ8 Austin Healey 6
CLEAH Found another number on my frame [BJ8] Austin Healey 6
P AH BJ8 hood frame spring where I got hooked Austin Healey 3
R weight of BJ8 Frame with inner body panels Austin Healey 1
Bob McElwee '66 BJ8 Phase III Top Frame Assembly Austin Healey 3
L 1966 BJ8 frame rebuilding questions Austin Healey 1
eschneider value - BJ8 frame, engine, trans w/ title? Austin Healey 8
J BJ8 1967 Carpet install under convertible frame Austin Healey 3
J Installing glass in BJ8 frame. Austin Healey 11
GregW Late BJ8 frame dimensions Austin Healey 2
B BJ8 frame,sill dimension. Austin Healey 2
Ed_K BJ8 windshield frame to scuttle gasket fun ! Austin Healey 10
R Removing 66 BJ8 Windshield frame Austin Healey 23
R BJ8 Windshield Frame Austin Healey 3
F BJ8 Exhaust Hanger Pictures Wanted Austin Healey 9
Patrick67BJ8 Custom BJ8 Dash Switch Panel Austin Healey 7
1 BJ8 History Trace Austin Healey 7
D BJ8 Top Installation Detail Austin Healey 3
AUSMHLY BJ8 Trans Cover Carpet Austin Healey 7
AUSMHLY BJ8 Carpet and Snaps Austin Healey 2
Overdrive45 BJ8 Interior Trim Austin Healey 8
nitro BJ8 Production Year Austin Healey 6
B BJ8 Seat Sliders Austin Healey 4
B For Sale 1967 Metallic Golden Beige MKIII BJ8 Numbers Matching - The Real Deal Austin Healey Classifieds 0
BoyRacer For Sale BJ8 disk wheel hubs, spindles & calipers Austin Healey Classifieds 0
S SOLD!! For Sale 1964 AH 3000 MkIII BJ8 Phase 1 Austin Healey Classifieds 2
AUSMHLY BJ8 Cylinder Head Installation Austin Healey 6
LAW75 BJ8 Brake Lines Austin Healey 2
BoyRacer For Sale BJ8 spindles & disc wheel hubs Austin Healey Classifieds 0
G Wanted BJ8 Tonneau Cover Austin Healey Classifieds 0
Cutrog1 For Sale Healey 3000 BJ8.... a restoration saga Austin Healey Classifieds 0
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
