Good day, all! I have a technical question for you: What is the proper float level adjustment measure for the HD8 carburettor used on the BJ8? I have perused several manuals, including the factory workshop manual, the Haynes workshop manual and the handbook to no avail. These manuals give measurements for several other carbs used on Healeys but not the HD8 with metal floats. It appears the choice is between 5/16ths of an inch and 7/16ths of an inch..........or..???? Any help on this would be greatly appreciated. I set them at 5/16ths of an inch last night and the carbs adjusted out nicely and it seems to be running good and all, but it would be great to know I have them set properly. Incidentally, I used my new 'advance adjustable' timing light last night and it worked really great! At last, I know I have the timing set right for a change. The engine timing was about 3 degrees off.......
Thanks a lot in advance!
