Any tips for fixing a bent boot lid
69MGC
Any body have an tips for fixing the dreaded tweaked boot lid. You know the one you get when the boot prop bends the lid.
I just had my 79 LE painted (looks great by the way) and I could swear that the boot lid fit nice and flush before the paint job. Now I get it back and the boot lid is bent a bit and doesn't fit flush anymore on the side where the prop is.
Any tips for fixing this? Without major surgery!
Thanks
/bcforum/images/%%GRAEMLIN_URL%%/cry.gif
rulle7
My neighbor bent my Midget boot lid slightly just a few days ago. /bcforum/images/%%GRAEMLIN_URL%%/eek.gif
I put a piece of wood in the opening to keep the lid slightly open and simply pushed down where it protruded until it fit correctly again. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Five minutes massaging is all it took.
Steve_S
With fresh paint it is easy to match color. It may be worth your while to source another boot lid. They are cheap and plentiful. I suppose you may as well get a buddy and each grab one side of the lid, and tweak it straight again. Can't make it any worse!
Guinn
The lid on my 78 was bent when I bought it. I placed two pieces of wood strategically fore and aft of the bend, then leaned on the lid over the bend point. It did not bring it back completely but it really helped.
Mickey Richaud sent be a spare he had available. I am in the process of finishing off the little dents it had and repainting, as of now.
(Thanks again, Mickey. The biggest problem I have had with the lid was filling the extra luggage rack holes. Had a friend mig them for me, finally.)
Guinn
Mickey Richaud
Glad it worked out for you, Guinn. Post a picture when you finish it.
Mickey
A good preventative for this from occurring are gas struts.
Rick_Stevens
Yup.
R.
Guinn
Got the gas struts from Rick Ingram and have them temporarily on the old lid. Work great! Also work great on the hood and give me more room to work on stuff near the firewall.
Guinn
T Tips for locating/fixing foam rings under gas tank Triumph 4
S TR2/3/3A tips for mig plug welding vertically? Triumph 11
J Tips for quarter elliiptic spring install Spridgets 3
W TR6 Anyone add Exhaust tips to standard exhaust Triumph 4
PC DIY tips from Bo his self Other Cars 0
BoyRacer Need Tips on getting wiring harness through firewall Austin Healey 4
BoyRacer Tips on gluing new fabric to dash on my BT7 Austin Healey 10
HighAltitudeTR3 TR2/3/3A Leaky Carb Tips? Triumph 11
HighAltitudeTR3 TR2/3/3A Choke setting tips? Triumph 7
drooartz Installing front hubs, tips? Spridgets 15
bugedd Bench bleed tips Spridgets 14
S TR4/4A Electrical wiring tips Triumph 2
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
TEM666666 Sprite MK1 Door liner rubber mat installation.. Need tips and recommendations. Spridgets 22
F Buying a 100.... tips Austin Healey 18
drooartz MGB Changing clutch hose - tips? MG 13
T Tips for Searching FORUM Navigation Questions 2
T TR4/4A Any tips on re-torquing TR4a head now that 500 are on the rebuild Triumph 7
T TR4/4A Tips on controlling heat coming up through shifter opening? Triumph 14
M tips please on removing starter motor on 100-6 Austin Healey 6
gbtr6 TR6 Rebuilding TR6 Engine, Tips? Triumph 7
bugedd Su adjustment tips Spridgets 7
B Seam Sealer/Caulking - Any Tips on When, Where, and What to Apply? Austin Healey 45
C Any tips on how to remove frozen pistons from drum brake Wheel Cylinders??? Austin Healey 11
PatGalvin TR2/3/3A Carpet Install Tips Triumph 12
Bob_Spidell Tips Austin Healey 6
Tinkerman TR2/3/3A Front Fender Installation Tips Triumph 3
Tinkerman TR2/3/3A Windscreen mounting tips 1960 TR3A Triumph 2
W Looking for tips: BJ8 roll up windows Austin Healey 10
I TR6 Any tips on removing flasher switch Triumph 3
M Radiator Hose tips? Spridgets 0
T TR4/4A Any tips on running the overdrive switch wiring down the steering column? Triumph 11
T TR4/4A Making an OD pressure gauge - any tips? Triumph 7
bugedd About to rebuild front end...any tips? Spridgets 5
B Spitfire Changing leaf spring bushing - any tips? Triumph 6
RedTR3 TR2/3/3A Tips for Breaking in a Rebuilt TR3 Engine Triumph 6
apbos Two Restoration Tips Spridgets 11
J Tips on Re-Assembling Lenses/Gaskets? Austin Healey 5
TulsaFred Rear Hub bearing and oil seal tips Spridgets 0
5 TR2/3/3A TR3 engine building tips needed Triumph 5
TulsaFred Bugeye rear wheel cylinder replacement tips Spridgets 10
Lbp Install l-t-d fasteners on new tonneau - Tips? Triumph 8
T Wheel cylinder fitting kit - any tips? Triumph 4
D Spitfire '65 Spit window regulator installation tips needed Triumph 0
J 67 IRS Exhaust Tips Triumph 2
RickB Painting tips anyone? Spridgets 13
RJS Water Pump Replacement Tips Triumph 8
Russ Austin TR2/3/3A TR3 Transmission Installation Hints / Tips Please! Triumph 14
aeronca65t Kasnter tips Triumph 8
Xte TIPS : Home made tool for the thermal sensor Austin Healey 7
