    BCF is a resource offered at no cost to the Little British Car community. We do not require you to pay to play here. However, if you find BCF a useful resource, appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please support the forum with an "optional" low-cost (less than many car club dues) annual upgrade. There are some benefits to upgrading!
General Tech Angle Drive Came Apart
KVH
Hey, all, after 9 months I finally got the energy to remove my TR4A interior for the umpteenth time--to find out why my speedometer won't work. Attached is the photo of what I found. My angle drive seems to have just come apart. Does anyone know if this is typical or unusual? I can try to find a new one, but I could also have this repaired at my favorite shop. Any advice or clue what happened here? Hopefully it doesn't signify something more serious internal to the pinion
shaft. Thanks guys!!
sp53
I am not curtain, but I think you could run the longer OD cable and omit the angle drive. It might not be stock, but that is what a tr3 is like. Not sure why the older tr3 does not use the angle drive. If the longer cable did fail, a new can be put in without removing so much.
Steve
KVH
KVH
Before I reinstall my angle drive, I've got two questions. Should I use any lubricant on the speedo cable before putting it back in the cable housing? And, what is that little side screw for--the one on the side of the angle drive. Do I need to adjust that somehow?
Platinum
Not an uncommon problem. In the mid-90's there were a lot of them on the market that would do that. And were outrageously expensive to boot.
For the cable lube, use "Molykote" or other graphite based lube. The screw is just there to locate the worm gear. Not an "adjustment."
Stack the bits back into the housing and as Berry suggests, peen over a few places in the housing to retain the cap.
CJD
It might be a good idea to spin the cable and speedo by hand to judge if there is any binding. Many angle drive and cable issues start with a binding odometer in the speedo.
Madflyer
Try and put it back together but look for another one also. Lube cable with something that does not dry out and if there any kinks in the case replace it. I think I have one or two laying around.
DavidApp
The one that came with my OD rebuild has circlips holding he caps on. Along with a note to use the supplied washer on the gearbox side of the drive.
David
KVH
KVH
Just an update. I installed a new angle drive with the copper washer. Works great and I've got a speedometer again. I see my cable has an exhaust manifold burn on it, but I think OK. Man--it sure was a pain pulling out that interior again. I've pulled that out at least 15 times in the past 10 years. Of course I could try pulling out that access plate next time, but I needed to work on my shifter and other things as well, so all OK.
R Smitty Toyota Conversion Angle Drive Austin Healey 16
Popeye General Tech O/D right angle drive choices Triumph 10
BritBite Speedometer Right Angle Drive Austin Healey 5
KVH General Tech Angle Drive Broke (Repost) Triumph 0
T Angle Drive Lubrication Austin Healey 3
RJS TR4/4A Speedometer and Angle Drive Triumph 6
Jim_Stevens TR2/3/3A OD angle drive engaging the speedo cable Triumph 8
S Speedometer Angle Drive Austin Healey 2
P Help with Speedo Angle Drive Austin Healey 2
T TR2/3/3A Problem with angle drive for overdrive Triumph 20
T TR5/TR250 Is it good or bad idea to grease an overdrive angle drive? Triumph 2
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
T TR4/4A O-ring size on a A-type angle drive speedometer gear Triumph 10
Gerry M TR6 Speedo Angle Drive Triumph 2
Gerry M TR6 Speedo Angle Drive Triumph 9
John Turney Angle Drive Question Austin Healey 0
glemon Speedo Angle Drive Triumph 6
M Speedo Angle Drive Austin Healey 5
glemon Angle Drive Speedo Cable Different Size Ends Triumph 12
pjsmetana Slot Screw on Angle Drive. Whats it for? Triumph 7
M Speedo angle drive MG 3
livinginthepast tach angle drive grease - which one? Spridgets 2
Rob Glasgow Speedometer Angle drive Austin Healey 8
J Speedometer angle drive keeps breaking Austin Healey 10
T speedometer angle drive Austin Healey 3
B Missing Angle Drive MG 9
SwamperCa Speedo angle drive MG 8
angelfj1 Right-Angle Speedo Drive Triumph 6
R Angle Drive Repair Austin Healey 14
A Speedometer Angle Drive -Two Gone this month! Help Austin Healey 9
N Speedometer angle drive "DRVING ME NUTS" Austin Healey 9
M Right Angle Drive MG 2
RAC68 Front Seat-back Angle Austin Healey 15
C TR2/3/3A Seat back angle Triumph 8
M TR2/3/3A Engine/tranny angle with the ground? Triumph 7
steveg Fiat Master Cylinder for Healey - angle question Austin Healey 7
A Wedge SU on TR7 Float Level Engine Angle Triumph 10
brgrmyster Proper finish on luggage floor angle assembly? Triumph 0
J TR2/3/3A TR3 windshield angle and body shims Triumph 11
T pinion angle and leaf springs Other British Cars 2
T Quick fuel pump question - mounting angle MG 3
G How sensitive are SU's to bowl angle? Spridgets 12
germanmichel Engine bracket position [ angle direction] Austin Healey 8
T TR4/4A tr4-what angle is the engine at??? Triumph 7
gubba speedometer cable right angle adaptor Triumph 4
TonyPanchot "A" Type O.D. Speedo Angle Triumph 8
CraigLandrum Steering Wheel angle question Triumph 3
2wrench Speedo gear/speedo angle parts Triumph 9
19_again changing right angle drives MG 1
C BJ8 Seat back angle Austin Healey 14
