Speedometer angle drive keeps breaking
JoeT12083
Hi....I've been having a speedometer problem with my 1967 AH 3000. The angle drive keeps breaking at the pin that goes into the overdrive unit. The speedometer itself checks out OK and the cable is good as well. I put a new angle drive in today, went about a half mile and it broke again. Any ideas??? Thanks, Joe
GregW
Platinum
Hi Joe,
The only thing that comes to mind is the cable itself may be a hair too long. Is it new? Are the new angle drives any different than the original as far as the receiver for the cable?
MarkA
Hey Joe,
When you replaced the angle drive, did you also (re)install the copper washer between the angle drive and the OD unit? This washer is required for proper operation/spacing. Without it, the angle drive will bind (as I've been told).
Mark
J
JoeT12083
Hi Greg..I have the original cable and a new cable. Both break the piece. They appear to be the same length but I'll double check that later today.
J
JoeT12083
Hi Mark.....No I didn't. I didn't see any washer unless it fell out while I was removing the angle the first time and I didn't notice it. I'll go back and see if I see a washer on the floor or on the lift at my friends shop. I'll try it with a washer next time when I get another new angle drive. At $60 a pop I don't want to destroy too many more. Thanks, Joe
KevinBN7
Member
Are either of your odometers locked up? This is what caused mine to break. I took the speedo apart and freed the gears that move the Trip ODO. and it has been fine since.
To test this remove the speedo cable from the angle drive and turn the cable by hand. if it turns freeley in the speedo no problem. if it binds or stops figure out why.
Good luck
Kevin R
Ed_K
That copper washer is important.
I was missing it also and my original angle drive bound up tighter than a tic within a few thousand miles.
My speedometer needle used to swing back and forth in a 5 to 8 MPH arc before the angle drive quit.
Now it is steady as a rock with a new angle drive and the washer.
J
JoeT12083
Definitely will install the washer. The trip meter and the odometer appear to be fine but I'll recheck the speedo again before installing anything. Thanks for the help.....Joe
J
JoeT12083
Nothing appears to be locked up. I checked the speedo with a drill but maybe I better do it by hand next time. I have to wait to get access to the lift again. Shouldn't be long. Thanks for the advice, Joe
TimK
I decided to run the cable through a small hole I cut in the transmission tunnel and run the cable directly into the drive not using the angle drive. It fits under the transmission cover carpet and solves the problem.
BritBite Speedometer Right Angle Drive Austin Healey 5
RJS TR4/4A Speedometer and Angle Drive Triumph 6
S Speedometer Angle Drive Austin Healey 2
T TR4/4A O-ring size on a A-type angle drive speedometer gear Triumph 10
Rob Glasgow Speedometer Angle drive Austin Healey 8
T speedometer angle drive Austin Healey 3
A Speedometer Angle Drive -Two Gone this month! Help Austin Healey 9
N Speedometer angle drive "DRVING ME NUTS" Austin Healey 9
gubba speedometer cable right angle adaptor Triumph 4
M TR2/3/3A HVDA Speedometer Drive Triumph 10
GeorgetheTR3 TR2/3/3A Speedometer Triumph 4
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
roscoe GPS Speedometer Austin Healey 6
J 1985 TVR 280i Speedometer Cable TVR 4
F TR4/4A Speedometer cable replacement access Triumph 0
DocDup1 MGB SpeedBox Speedometer Drive MG 0
R TR2/3/3A Speedometer Reset Triumph 26
roscoe GPS Speedometer Austin Healey 10
PAUL161 T-Series TD/TF speedometer gears. MG 3
AUSMHLY Speedometer Fluctuation Austin Healey 21
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
M TR6 Speedometer Triumph 2
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
P TR6 Jumpy Speedometer cable Triumph 4
PAUL161 T-Series Interesting Speedometer Scenario MG 5
John Turney Getting Speedometer out of the Case Austin Healey 6
K TR2/3/3A Speedometer needle bounce? Triumph 1
P Speedometer confusion Spridgets 1
J TR2/3/3A Speedometer Bounce with Odometer Gear Movement - Benchtop Calibration Triumph 3
T Speedometer Repair Problem Austin Healey 5
J TR2/3/3A Speedometer Works Removal Triumph 10
R TR2/3/3A Speedometer Routing Triumph 15
KVH General Tech Speedometer Not Working Triumph 5
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
K TR2/3/3A Speedometer Error Again Triumph 8
G Spitfire gps speedometer Triumph 6
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
T Wanted WTB 100 / 4 Speedometer Austin Healey Classifieds 0
B Differences between BN2 and BN4 speedometer gears?? Austin Healey 7
F How does overdrive Annulus effect speedometer Austin Healey 10
M TR4/4A Speedometer Cable Routing Triumph 7
2 TR2/3/3A Can't get zero on speedometer 60K tr3A Triumph 6
B Speedometer Cable Routing Austin Healey 9
UmmYeahOk GT6 What do I need for a speedometer fix? Triumph 16
Michael Oritt Speedometer drive issue Austin Healey 4
R TR4/4A Speedometer off 10mph Triumph 6
R BN7 Speedometer issues Austin Healey 1
