TR4/4A Alternator
jimstr4
Happy New Year everybody. I'm in the middle of changing to an alternator and have struck an unforeseen problem.
My mechanic friend got me a new Lucas alternator but I didn't realise that the post that alternator's post that's attached to the belt adjustment link is not high enough.
See attached photo.
I see that Moss Europe has fitting kits so unless I can locate an alternator with a tall enough post I'll have to order a kit.
DavidApp
Happy New Year.
I presume that the adjustment link is fouling on the alternator casting. I had to file a bit off my adjustment link to get the bolt to go in on my TR3.
Even having a new link made would be cheaper than shipping the kit out from Moss.
David
trrdster2000
How about heating it and bending the one you have. Bend from close to the end that goes on the block.
J
jimstr4
There's a 10mm difference between the alternator and the generator which means that grinding the link is out of the question as it's not that thick.
Heating and bending is probably the only other option.
dklawson
I don't know the shape of the alternator or generator brackets on the TR4. However, a lot of alternator conversion articles used to mention buying the generic Chevy upper alternator bracket arm which is then cut to length and drilled out as necessary. Unfortunately, while this part is typically available at the local parts store, it will be chrome plated which may look out of place.
https://www.cfrperformance.com/v/vspfiles/photos/HZ-9079-C-2.jpg
poolboy
I had to make a dog leg bend for the alternator on my TR6.Alternator Bracket # 1 thru 6 002.jpg
dklawson
If the problem is just the gap between the bracket and the alternator case... why not add a stack of washers or a shaft collar to fill the gap?
J
jimstr4
Thankyou for the replies.
The problem is that the adjustment link is not curved enough and the alternator post is too low.
The link fouls on the alternator body.
The distance from the generator body to the middle of the hole is 10mm more than on the alternator.
The problem is not the horizontal distance between the bracket and the alternator, I should have taken a better photo.
if you look at the bottom of the photo the black bracket doesn't line up with the alternators hole as it hits the alternator body.
I think that I'll have a go at turning it upside down first.
It would never have occurred to me that the alternators lobe was lower than the generators and that a different bracket was needed.
The background to swapping to an alternator is that my generator has a loose connector and hence doesn't work, also when I had the radiator recored I was silly enough to put the crank hole back hence losing about 17% of my cooling. In stop start traffic (pre recoring) the TR used to chronically overheat, which meant that I'd have to switch the engine off whilst waiting so I added an electric fan which the generator couldn't keep up with at low revs.
charleyf
WHAT IF--you were to cut the existing bracket below where the slot is for the bolt and then weld it back together with that slotted end at a different more appropriate angle? With the cutting and welding you could also likely change the angle to get the bracket closer to the alternator.
By the way I really liked your part of the country when I visited a few years ago.
J
jimstr4
Well I'm going to make up a template of the correct angle for my friend to bend the bracket.
What part of New Zealand did you visit?
At the moment we're having strange very very hot weather, combined with our very high levels of UV, if you drove a convertible in Wellington you'd end up fried with sunburn and melanoma.
We're getting very few days to drive a convertible. We normally have very temperate weather.
Global warming?
charleyf
Global warming?
Jim,
I was very fortunate to have booked a tour that went from the very north tip to about 15 miles from the south tip of the south island. Beautiful country. If I had a bucket list, touring your country would have been at the top of it.
J
jimstr4
The wide belt alternator pulley I purchased from ASE-SUPPLY has a smaller diameter than the generator pulley, hence I run out of bracket when trying to tighten.
Which means that turning it upside down and heating and bending it won't work with the bracket and the Lucas 17ACR.
I've ordered an alternator bracket from Rimmers designed for fitting alternators onto TR2, 3 ,4's.
https://rimmerbros.com/Item--i-142134
I then have to unscrew the front alternator posts and turn them back towards the engine as the bracket looks alot shorter than the original.
Here's hoping that this works.
charleyf
Have you looked into a different size / length of belt? I have a small pulley on one of my TR4's and run a different size belt I got from a local parts dealer. The belt is from NAPA size 25-28400 . The numbers should lead you to the size of the belt. It is the wide belt the same as the original. Just a different length.
I MGB Alternator help MG 0
P Alternator Installation Pic Austin Healey 4
P Generator to Alternator Swap Austin Healey 2
W Generator or Alternator? Austin Healey 18
Writer2022 GT6 GT6 MK3 Alternator Problem Triumph 4
K TR2/3/3A Is it time for a new alternator??? Triumph 8
M Smog pump and alternator brackets Spridgets 0
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
E MGB external alternator regulator MG 2
DrEntropy MGB Generator to alternator swap MG 1
M TR2/3/3A Generator Warning Light on with the Alternator Charging the Battery Triumph 4
K TR2/3/3A Overtightening the alternator belt? Triumph 14
B TR6 Swapped Lucas to GM alternator Triumph 9
M TR6 Alternator Issue for 72 TR6 Triumph 7
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
K TR2/3/3A Red ignition light stays on...car has alternator not generator. Triumph 17
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
G Spitfire Alternator troubles Triumph 2
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
TheRealDestrux MGB Unknown connector on alternator MG 6
R TR2/3/3A Amp Gauge-erratic reading after alternator conversion Triumph 39
lilifer_13 Spitfire New alternator doesn't fit - '78 Spit Triumph 2
AUSMHLY Generator to Alternator Swap Austin Healey 20
J TR6 1975 TR6 Alternator Advance/Retard spring(s) Triumph 1
Lin Fan belt for 1275 with alternator Spridgets 4
PAUL161 T-Series Dynamator Alternator conversion. MG 23
P '58 XK150 Dynalite Alternator swap question Jaguar 5
B Delayed charging Lucas alternator Triumph 1
Merlin63Tr4 TR4/4A Alternator or alternator in a generator case? Triumph 4
Walter74 Dynamo to alternator Austin Healey 2
S Stag Lucas 18ACR alternator conversion Triumph 5
Got_All_4 TR5/TR250 Rebuilt Bosch Alternator stops charging Triumph 0
donbmw TR2/3/3A Converted to alternator Triumph 14
90dog A H Spares Alternator Bracket Austin Healey 53
R TR2/3/3A generator to alternator Triumph 5
JPSmit Alternator help - please. Spridgets 21
I Bugeye generator/alternator conversion question Spridgets 7
Ripper01 TR6 110A Alternator Triumph 7
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
Sopwith_Camel alternator eater Spridgets 20
longbridgehealey Alternator conversion and tach Austin Healey 9
S TR2/3/3A Alternator Triumph 7
apbos Positive Ground Alternator wiring. Spridgets 9
BoyRacer Wiring question for alternator conversion Austin Healey 3
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
M TR2/3/3A Water Pump Belt After Alternator Conversion Triumph 6
J MGC Lucas alternator/regulator MG 3
K TR2/3/3A Revington alternator heat shield. Triumph 0
