Alloy valve covers
Mio
I was considering the purchase and installation of an alloy valve cover for Bugeye such as that sold by Moss Motors (see: Alloy valve covers) until a long time British car enthusiast mentioned to me that they were more prone to leaking than the traditional valve covers.
Is there any truth to this assertion?
Thanks,
Mike
Platinum
If you "pre-glue" the gasket to the cover first and get good contact around the head surface they're fine. It just takes a bit more "fiddling" to initially seal 'em.
Mio
Mio
I'm familiar with the approach to sealing 'the gasket to the cover first' but appreciate your advice. Perhaps the individual that I spoke with was dealing with a defective product.
Thanks for your response.
Mike
Platinum
I've seen 'em where the installer got a bit over zealous about tightening 'em down, too. Distorts the sealing edge of the cover. Some folk have a way of introducing more problems than they cure, IYSWIM.
racingenglishcars
I always liked the look of the steel cover. I really think it looks good and there's no doubting the classic look of the engine. It doesn't pretend to be anything other than what it is. I always thought the aluminium covers were for people who use 1.5 rocker sets, which don't fit under the standard cover.
65sprite
I got one as a gift last Christmas. I installed it using a silicone gasket from Roadster Gaskets (often advertised on Ebay}. Expensive, but seamed to have a positive reputation according to a lengthy discussion on another British board. No leaks, and they are reusable, so it's nice not to have to buy a cork gasket every time you reset the rockers.
If you like the look of the aluminum valve cover, I do, then you might look into a silicone gasket. IMHO.
Ron
Bugeye58
Mike,the two major drawbacks that I've seen with the Al. covers are the lack of the gasket retaining lip on the edge, and the absence of any vent provisions. As mentioned, a properly glued gasket should present no problem, and a vent fitting is easily installed, should you desire one.
They do tend to dampen out a bit of the valvetrain music, too.
Jeff
Mio
Mio
Hi Jeff,
Your point about the retaining lip, or lack thereof, was exactly what was mentioned by the individual that I spoke with. He felt that this is what led to the increased likelihood of leaks.
I'll give this some more thought but Donn raised a great point that "there's no doubting the classic look of the engine" with the steel valve cover.
Mike
Luke_Healey
Advance Auto is able to get me (same day) Fel Pro cork gaskets for about 3 bucks a pop. I got four of them when I got my first Sprite. I used a thin bead of RTV and it doesn't leak. The one on my 'new' Sprite is not even RTVed and it's not leaking. It's about 1/4" thick I think.
MikeAH100M No Valve Cover Breather - Alloy Valve Covers Austin Healey 5
prb51 Alloy Valve Covers and breathers Triumph 11
19_again alloy valve covers MG 10
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
wangdango 6-cylinder alloy valve cover Austin Healey 53
Willie_P TR4/4A Alloy Valve cover: STUD SPECIFICATION - need help!!! Triumph 5
M TR2/3/3A Alloy valve cover--new twist Triumph 10
M TR2/3/3A Alloy valve cover. pros/cons Triumph 6
MikeAH100M Alloy Valve Cover Fasteners Austin Healey 3
jhorton3 Alloy Valve Cover Spridgets 18
texas_bugeye Slant alloy valve cover Spridgets 2
T Alloy valve cover functional, or 'just' eye candy? Spridgets 14
M Alloy Valve Cover Install Issue Triumph 2
F TR2/3/3A TR3 "NonBreather" Alloy Valve Cover Triumph 3
C Moss alloy valve cover installation MG 9
C Venting alloy valve cover MG 9
R Alloy Valve Cover Oil Baffel Triumph 23
D Alloy valve cover Triumph 3
weewillie alloy valve cover Spridgets 5
2 Torque for alloy valve cover Triumph 2
P Alloy Valve Cover 100/4 Austin Healey 5
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
9 For Sale Magnetic Aluminum Alloy Fuel Cap for TR250 and pre-1970 TR6 Triumph Classifieds 2
D MGB BWA Alloy Wheels MG 9
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
M Alloy cylinder head Austin Healey 5
M TR6 Alloy Wheel Upgrade Triumph 19
S TR2/3/3A Alloy flywheel Triumph 13
MikeAH100M Ideas for an Alloy Racer Austin Healey 13
J Alum shroud alloy Austin Healey 7
JAV New DW alloy head Austin Healey 17
E TR4/4A Cleaning of alloy parts Triumph 4
H Alloy body Healeys? Austin Healey 5
TRMark TR4/4A Alloy wheels for 165R15 Triumph 10
johnrip Wedge tr7 tr8 alloy wheel tires Triumph 3
angelfj1 Alloy wheels for that authentic steel wheel look. Triumph 11
Hap Waldrop MGB A new alloy wheel choice for MGBs MG 11
R Alloy Oil Pan from Moss Austin Healey 9
K TR3 Tire Size for Shelby 500 Alloy Racing Wheels? Racing 0
justin_mercier Wedge TR7 / 8 alloy wheel lug nut shank size / length? Triumph 13
K TR2/3/3A Tire size for 5.5x15 alloy racing wheels? TR3 Triumph 8
M What is the alloy of steel used in the A-H body? Austin Healey 2
K Alloy Wheel Lug Nuts? Triumph 3
M What is the alloy of steel used in the A-H body? Austin Healey 4
Z Alloy Wheels Austin Healey 14
R Alloy Pedals BJ8 Austin Healey 4
johnrip Wedge tr7 alloy wheel needed Triumph 3
T TR6 How many alloy locating dowels on TR6 trans Triumph 6
