Tabcon
I was hoping at least one of you well seasoned peanuts could give me a little construction advice.
I'm at a stage in the restoration where I'm still waiting on some stuff and still waiting until I can afford some other stuff, but I'd like to install the rear axle assembly without having installed the limited slip differential. The pinion is set, as are all the seals, etc., so all I really need to do is insert and install the LSD when I get one. Since the frame doesn't have a body on it yet, I figured the frame could act like a holder of sorts for the axle while I install the LSD.
If worse comes to worse, I guess I could take it all apart again, but I really want to get the rear end back together.
I await the advice of the seasoned peanuts!
