87 XJ6 Series Three Sunroof
Michael J.
Anyone know what the 4" wide rubber flap pop-rivited to the deflector bar that pops up with the sun roof is open is for?
The loose end has lost about 3/8" that broke off.
Exotexs
isn't it part of the deflector to eliminate wind noise?, sort of like a spoiler in a sense. But if you open the sunroof all the way to the back, you get the famous "rumble" anyway. (an acoustical low frequency "rumble" which also occurs when you open the windows at high speeds). Forget about the plastic deflectors that mount with adhesive tape over the sunroof opening, they look so tacky and serve no purpose other than to ruin your paint when you try to remove it.
M
Michael J.
Thanks;
The rubber is only about 4" wide and is riveted to the pop-up wind deflector. I was trying to figure out what it does so that I can decide how "big of a deal" having some break off is, but I can't figure out what it actually does.
Thanks for the comment on the glue on wind deflector. I scratched one of those of my list. I have experienced the "rumble" first hand and have started cracking a rear window a 1/2" to make it stop.
There are some flapper valves behind the rear seat back cushion and the "parcel Shelf" that are supposed to help with that, but if the deflector bar sticks down, the valves sound like someone beating a drum. They appear to vent through the slots at the front of the trunk opening.
ROARRR Series 2 XJ6 with cert for chev eng for parts or refurb Jaguar Classifieds 4
W XJ6 Series I bumper swap to Series II Jaguar 0
T 1971 Series I XJ6 parked for 12 years - fuel pump problem Jaguar 4
J Question about Series III XJ6 Motor in E Type? Jaguar 2
D Posi-Rear end in a series 3 Jaguar xj6 Jaguar 12
D XJ6 series III front end rattle Jaguar 5
M 87 Series III XJ6 Rough Running Jaguar 16
B Lead on xj6 series 1 / Chevrolet 350 Jaguar 0
V Cd numbers for Series 1 XJ6 or 12. Jaguar 4
M 87 Series III XJ6 won't Start Jaguar 16
1 Performance up-grades XJ6 series 3?????? Jaguar 4
healeyneil series 3 XJ6 toolkit Jaguar 3
M 4.2 Liter Engine Serial Number in a Series III XJ6 Jaguar 2
eschneider what to look for when buying a '79 series II XJ6 Jaguar 39
M Alternator or Battery Problem on 87 XJ6 Series III Jaguar 5
M Tricks for Alternator Removal 87 XJ6 Series III? Jaguar 8
wkilleffer Series III XJ6 a/c amp questions Jaguar 1
bmurphy7369 Need some rust repair advice for Series III XJ6 Jaguar 8
bmurphy7369 XJ6 Series II Parts Needed Jaguar 11
S XJ6 Series 1 Jaguar 1
R For Sale For Sale 1990 Jaguar XJ6 Jaguar Classifieds 0
E 1996 XJ6 Jaguar 1
V 89 XJ6, How to adjust front camber? Jaguar 2
A For Sale 1986 jaguar xj6 Jaguar Classifieds 0
S XJ6 Mk1 clutch slave question Jaguar 0
SherpaPilot Wiring Harness for XJ6 Jaguar 1
C tachometer for XJ6 Jaguar 0
Marvin Gruber XJ6 engine swap into XK 150 Jaguar 4
krswen Looking for advice on XJ6 overdrive unit speedo drive Jaguar 2
krswen Question about XJ6 cam covers Jaguar 6
smaceng Help with a XJ6 [sort of] Clutch Jaguar 3
W Removing wiper arm on 74 XJ6? Jaguar 0
B '72 XJ6 Door Seal Installation Jaguar 2
D XJ6 SIII, idle adjustment Jaguar 7
T 10000k HIDs for 96 XJ6 Jaguar 4
D 85 XJ6 brake fluid reservoir leak Jaguar 4
D 85 XJ6 Heater Core Replacement Advice Wanted Jaguar 19
D XJ6 Seat Removal Q. Jaguar 5
D 85 XJ6 No start, coil problem. Please Help Jaguar 11
K 72 Jaguar XJ6 4.2 litre motor reliability? Jaguar 4
CZ_Dave A Redneck Jaguar XJ6 Spotted 9
CZ_Dave A Redneck Jaguar XJ6 Jaguar 2
C Remove/Install New '93 XJ6 Door Lock Actuator Jaguar 0
C 1999 xk8 steering wheel swap out '93 xj6 Jaguar 3
W Removing windows in 74 Jaguar XJ6 Jaguar 1
R Jaguar XJ6 Door Locks Jaguar 8
B 85 jag XJ6 improve it's performance ? Jaguar 4
eschneider xj6 purge valve / air bleed valve Jaguar 4
dklawson Early '80s XJ6 Speedometer Transducer? Jaguar 0
M 1985 XJ6 Drivers door lock Jaguar 5
